L5740 or some tractor
/ L5740 or some tractor #1
ArlyA
Super Star Member
Houghton MI (the Lake Superior snow belt) USA
Outlander1000 6x6, Ego lawn mower and shopping for tractor
Got a Kubota L3560 come up for sale near us for $40,000. 2021 with hours with 72 inch HD bucketL4479, 6 foot front mount snowblower 3 rear hydraulic remotes. Filled turf rear tires, Heat/AC, Bluetooth radio etc, etc.
If you have one, hows it been for you? Looks like the BH92 Backhoe got on it. If you got one, please comment on its use.
/ L5740 or some tractor #2
If you have one, hows it been for you? Looks like the BH92 Backhoe got on it. If you got one, please comment on its use.View attachment 3474334
Seems high to me. A year ago I was quoted $33,300 for a new ROPS 3560 with 805 loader. What does the cab add $8000? So that would put a new one at around $41,000. Not sure what a used snow blower and 3 remotes is worth. But it seems their asking price is awful close to new price. I would think a new one with 0% financing may actually be cheaper.
/ L5740 or some tractor #3
My cabbed l4060 was valued at the mid 30s by the dealer a year ago. A blower & a backhoe are $8k each. Not clear if a hoe was part of the deal. My l4060 is a little short on hp for serious production work, but does me fine for a side gig. At my Colorado altitude I probably have less hp than a 3560 at sea level.
And what is kubota using for bucket quick connection system? Looking on Google, I'll I see is the commonly used system. SSA?
/ L5740 or some tractor #5
SSQA Fyi. Kubota uses a 2 camlock attachmet that will engage with any (not Euro style) quick attach. While I prefer the more rubust ATI attachment fixture, I happen to have them both, the OEM Kubota unit on one tractor and the ATI on the other.
/ L5740 or some tractor #6
Arly I went on Kubota and did a “build” on that tractor, it was about $63,000. The snow blower alone is about $7k. That’s considered a Grand L and would be a nice rig.
Edit, if it has a backhoe I didn’t do that on Kubota’s build, that would add several thousand more.
/ L5740 or some tractor #7
How many hours Arly, I think that got left out in your OP. I went on Tractorhouse and looked at several. Unless it has a lot of hours that might be a great deal.
/ L5740 or some tractor #11
Kubota operator's, what quick connect system does there loader buckets use???
If you bother to read back a couple posts, I told you. Again... Kubota uses their proprietary 2 pin camlock SSQA disconnect that is compatible with all SSQA attachment plates from anyone except Deere and their 'Euro style; SSQA. I have both the Kubota 2 pin camlock SSQA as well as the ATI 2 pin camlock SSQA and they interchange 100% but I prefer the ATI as it's built stronger. Easy to tell the difference as well as the OEM will be orange and the ATI will be black.
/ L5740 or some tractor #12
35 horsepower is a little small on a machine of that size, but not so much so it should be a problem. Outside of that, it's a low hour, cab, Grand L, it's a Cadillac of a tractor.
/ L5740 or some tractor #14
That's a nice machine. My L3700 has about the same HP and has never been short on power. Maybe the hydraulic system could be stronger but if anything is too heavy for it, I use the skidsteer.. 40k and you can use it for 5-6 years and get back most of your money
/ L5740 or some tractor #16
Oh wow; that's pre-emissions, and damn near brand new!
I have no experience with the L-40, but they don't seem too different from the L3830 I grew up on, and that was one hell of a machine.
/ L5740 or some tractor #17
Gee whiz, now a L5740 just showed up with cab, blower and more extra accessories for 47K with 700 hours and in the same town.
Looks like it has loader brackets. Does it have a loader with it?
No rear remotes??
Much better tires for all-around use than the turf tires on the other one.
Look under and see if it's leaking hydraulic oil at the weep hole in the middle of the frame.
Yes and a few other attachments.
Specs are below-----------------------------------
The Kubota L5740 is a compact utility tractor with a 59 gross hp, 2.4L 4-cylinder diesel engine and a hydrostatic transmission. It features a semi-independent mid PTO linked to the rear PTO. The L5740 also offers both ROPS and cab variants (L5740HST and L5740HSTC).
Here's a more detailed breakdown of the L5740's specifications:
Engine:
  • Type: E-TVCS, indirect injection, 4-cycle 4-cylinder diesel.
  • Gross Horsepower: 59 hp.
  • Net Horsepower: 57 hp.
  • PTO Power: 50 hp.
  • Displacement: 148.5.
Transmission:
  • Type: HST Plus (3 Ranges).
Other Key Features:
  • 3-Point Hitch Capacity: Category I & II.
  • Cab Enclosure: Grand Cab Option Available.
  • Air Conditioning: Standard on Cab Models.
  • Heater: Standard on Cab Models.
  • Steering: Hydrostatic Power Steering.
  • Brakes: Wet Disc Type.
  • Clutch: Dry Type Single Stage.
  • Operating Voltage: 12 V.
  • Turning Radius: 9.2 ft.
  • Fuel Capacity: 14.3 gallons.
  • Operating Weight (with ROPS): 4,232.9 lbs.
  • 3-point hitch lift capacity: 2,976.3 lbs at 24 inches.
  • Dimensions:
    • Overall length: 10.54 ft.
    • Width (outside frame): 5.62 ft.
    • Height (to top of cab): 8.42 ft.
    • Wheelbase: 6.29 ft.
/ L5740 or some tractor #19
Wonder where the grill guard is? Would be nice if they have it.
Needs rear remotes.
I’m not sure that it’s a great price, but then I get surprised every time I buy anything lately.
/ L5740 or some tractor #20
I don’t have one, but the L3560 is probably the nicest tractor in the 35hp range. The turf tires wouldn’t be my choice, otherwise that’s a sweet machine.
2011 Nissan Murano SUV (A64557)
2011 Nissan Murano...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
2019 Autocar Xpeditor Garbage Truck (A62613)
2019 Autocar...
Peruzzo Canguro 1600 Collection Flail Mower
Peruzzo Canguro...
John Deere 4039TF001 (A64127)
John Deere...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
