Hydraulic SSQA idea
/ Hydraulic SSQA idea #1
JeepHead
The hills of Southern Indiana
Kubota 2502H, HSI Pinnacle grapple, LP 48" forks, LP 60" BB, KK tiller 60", KK middle buster, Pat's QH
I have been considering converting my SSQA on my Kubota to hydraulic. I have a true 3rd function operated off a Summit valve. I was thinking about using a manual splitter valve so that I switch a lever one way and it controls the SSQA cylinder, and then flip the other way and it's back to running my grapple. Anyone used one of these valves before?
/ Hydraulic SSQA idea #2
It will work just fine. You can get fancy and get the 12v solenoid powered one. That way, you don't even have to leave the seat to switch between one function or the other.
Something like this. Same 6/2 diverter valve but electrically operated. Often they pop up cheaper than the one you listed though.
to
View attachment 3490661 to
I considered an electric one but just liked the idea of a manual one. I have a place I could mount it next to the two spool valve that I use for 3rd function and top link that way I could operate from the eat. I suppose it would be pretty simple to mount an electronic valve elsewhere and just have a switch by the seat.
/ Hydraulic SSQA idea #4
Oh yeah, if you can mount it within reach from the seat, manual is the way to go for sure.
Over here, you have a couple more options available: Selector Valves | Hydraulic Valves | Hydraulics | www.surpluscenter.com
/ Hydraulic SSQA idea #7
Either manual or electric, they are both diverters. Up to what makes the most sense for you and your application. And yes Surplus Center is hard to beat for anything hydraulic.
/ Hydraulic SSQA idea #8
I made a hyd ssqa for my L3240 a couple
years ago. I used diverters for both my grapple and the ssqa, I would just mount manual diverter out on the loader arms.
It will reduce the number of hoses you'll have have to be at the front of the loader to connect the hoses when using the grapple anyways so its not like its an inconvenience.
Now if I could find a simple way to autoconnect the hyd fitting I would be very happy! (And yes I'm aware of the bobcat system).
/ Hydraulic SSQA idea #9
View attachment 3492218View attachment 3492219
I really like that hose holder in the 1st picture!! 😀
/ Hydraulic SSQA idea #10
Thanks, its still in the R&D stage, but was planning on producing them at some point.
/ Hydraulic SSQA idea #11
I would go with the manual one. You have to get off the tractor to hook the hoses for the implement up anyhow. The process would be pretty simple.
  1. Hook up and hydraulically attach implement
  2. Get off and hook up lines and switch diverter
  3. Use implement
  4. Do in reverse to remove attachment.
Simple and easy. I would avoid an electrical diverter as it adds no advantage because your never going to unhook an implement using 3rd function without unhooking the lines. For most other applications I would recommend a electric diverter, just not this one.
/ Hydraulic SSQA idea #12
Recently bought new but weathered miniclip that fits the ssqa fel. Has diverter valve remotely controlled to switch third function from clip to rotate. Weather had ruined 😠 the receiver and battery. Manufacturer OEM replacement was $400. Opted to replace with Amazon remote($21), Dewalt 20v battery mount and transformer ($23), LED switch and indicator ($14). Easy conversion you may consider or for other applications.
Remotes attached with industrial Velcro. Like not have additional wiring to FEL. Works well in brush and battery last a week of cutting easily.
/ Hydraulic SSQA idea #14
Anyone find a better deal than this on one?
Maybe. €50 or $55 in this German Hydraulic store.
/ Hydraulic SSQA idea #16
$55 seems too cheap to last? Read the reviews?
Maybe. There isn't much to it, to be fair. I'm planning on getting one of those eventually. The idea is to add another set of remotes on the cheap side.
This valve is the same exact one as the Badestnost ones, which get rebranded to Summit in the US, along with other names. In this case, it's not even branded at all I believe.
/ Hydraulic SSQA idea #17
All for a good deal. Specs and quality control does vary. Appreciate your review how this works.
/ Hydraulic SSQA idea #18
I have 2 of these cheaper European supplied diverters like posted, I haven't been very impressed. As expected, internal leak down is a bit more then I like, but the external leaks are getting annoying.
/ Hydraulic SSQA idea #19
  3. Use implement
What about changing back and forth between buckets and forks and other inplements that have no hydraulics? I would rather be able to operate it from the seat otherwise I can just flip the levers if I am up front anyway...
Yes exactly. I swap between forks and bucket attachments quite a bit and that's really what it will be used for. The valve will be mounted right by the seat for easy operation.
2008 Freightliner Allegro Bay Class A Motorhome (A61569)
2008 Freightliner...
UNUSED KUBOTA RCK60P-331Z BELLY MOWER (A62130)
UNUSED KUBOTA...
UNUSED WOLVERINE QC1-26-20G UNIVERSAL HITCH (A62131)
UNUSED WOLVERINE...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
UNUSED RAYTREE RMLL60-60" HYD POWER RAKE LAND LVL (A62131)
UNUSED RAYTREE...
New/Unused Grapple for CFG Mini Excavator (A61166)
New/Unused Grapple...
