MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 67,327
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
10 years tomorrow!Not as new as you. Just fewer posts.
Thanks for posting this! I had not seen these, but now I'm wondering about the feasibility of adding something like this to a large irrigation system, as it'd save me a lot of time on fertilizing 100+ trees 2x per year. I'm thinking a 5 gallon pail of liquid fertilizer in the basement boiler room, with a siphon located downstream of the vacuum breaker just outside.Last year I added a Venturi fertilizer injector. I pre-mix the fertilizer in a 5 gallon bucket and it sucks it out of there. I hit the flowers every 2-3 weeks, and the vegetables as needed.
That's exactly what I have it for. I have a 4-zone Orbit battery operated timer with 4 solenoids....
It'd also be nice on even smaller systems like the drip nozzles that feed our hanging baskets, using a little 1 gallon jug of liquid fertilizer for those little hose bib-mounted battery powered irrigation timers.
Most boring troll, ever, if true!I'm beginning to suspect a troll post due to lack of responding to replies requesting more information.
He's been a member for 7 years with 900 posts. I doubt he's trolling. Maybe he just doesn't live his life here 24/7.The lack of specific information muddles the design. Water pressure is also a factor, because water does not simply fall out of the hose end; it can stream 20' without any problem unless he's spraying into a 20MPH headwind.
If you have any questions about the moderation of these forums, contact the owners of TBN.Maybe you should quit deleting posts.
Spot on! I just had to draw it for myself to get my head around it.a = 100 (length of hose)![]()
Isosceles Triangle Calculator
Use our isosceles triangle calculator to find any part of an isosceles triangle. Calculate any leg, angle, perimeter, or area of a triangle.www.inchcalculator.com
h = 90 (1/2 width of plot)
b = 87.178 feet maximum distance between spigots
I like things to be symmetrical.
With spigots in the corners you'll need 7 spaced evenly along each long side, that would put them at 81' 8" apart.
If instead of placing them at the corners you put the first one 40' 10" from the corner and then spaced them the same in between (81' 8") you could get away with 6 spigots along each long side.
Please don't assume I am right, I would lay this out using survey stakes and take messurments.
And no, it's not symmetrical, but then it's just an exercise in geometry, and probably not a practical solution anyway:
A 100 ft hose would make a 200 ft circle.I need to place spigots so that a 100 ft hose will reach everywhere inside and not have any dead spots that cannot be reached?
The drawing doesn't show any "trees", remember?He said "trees" remember. Pulling a hose into a straight line will be practically impossible. I suspect in practice, 75' is more realistic.
I went by what he said, didn't want to remove any more trees, then said trees in center..The drawing doesn't show any "trees", remember?
When I planted trees I had several hoses and watered as I walked down the row. It was a workout but ended up being the easiest way to water all the trees without damaging anyThis kind of thing was never my thing.
I’ve cleared a piece of land enough to have the sized perimeter that I’ve shown.
At what intervals around this known perimeters ( length and width ) would I need to place spigots so that a 100 ft hose will reach everywhere inside and not have any dead spots that cannot be reached?
I’d rather have a little wiggle room versus stretching things to their limit.
I don’t want to have to remove any more trees ( in the center) than I’ve already done and although tree’s will change the reach of the hose we can manage that on an individual basis as it occurs.
I’ll have a spigot for sure at all 4 corners
Thanks if you can figure this out
Thanks, this is what I’ve laid out per your instruction and it’s gonna be fine.Place spigots at 80-foot intervals along the 490-foot sides (left and right, at
0,80,160,240,320,400,480 and one spigot at the midpoint of each 180-foot side or 90'. This requires 16 spigots total to ensure a 100 ft hose can reach every point inside the 180' x 490' rectangle without dead spots.
Also need to know the distance the sprinkler will eject water as well as a layout of where these trees in the middle are located.Apparently we require more details.
