What do you use for diesel transfer storage?
/ What do you use for diesel transfer storage?
My first filup was only 50 gallons as I wanted to see that everything worked correctly. I found out the pump is old enough that Fill-Rite does not have parts for it, but it does seem to run fine. I filled up my two tractors then tucked the tank away in the corner. I think it will work out for me. I can load the tank in my truck with forks and use the dolly to roll it out of the way when not needed. I do think I will look into a hose upgrade.
Thanks for sharing!
FWIW: At my local TSC, the cheapest Fillrite pump, a hose/nozzle, with no filter, and a 55 gallon tank is over $1,000, not including taxes. I think that you did really well.
All the best,
Peter
/ What do you use for diesel transfer storage? #42
I'm trying to figure out how to move it around and see the hooks on top like your tank has. I don't usually have forks on the front -- have you lifted your tank using the hooks and a chain?
Those are not intended to be used when the tank is full. Not strong enough. How often do you need to move it around? I have a 100 gallon tank and the only time it gets moved is when I take it in or out of the pickup when I fill it. If you have a need for it to be mobile and you don't want to keep it in your pickup, I'd set it up on a little trailer. Moving it around on forks works, but certainly wouldn't be ideal if it's something you need to move often, particularly if you're traversing uneven terrain.
/ What do you use for diesel transfer storage? #43
As I posted
I've :
Two 50 gallon steel cubes from tractor supply (got for $50 slightly used by a suburbanite with ~5 acres and a 20HP tractor)
It also is looking like I may get a shortbed diesel truck, in addition to my venerable F350.
So once again I'm looking into mounting one of the cubes (on a pallet?) so I can move it from vehicle to ground and back.
For those of you who do that what do you use for fastening it down?
I don't want a loose cannon in the bed of my truck, but I want to be able to move it from truck to truck.
Also any advances in pumps?
I want to be able to pump from the truck to the ground, figuring the cube will be in the truck bed and centered up against the cab.
/edit
Just looked up the 50 gallon transfer tanks at TSC DARN!! They are $450 now!.
/ What do you use for diesel transfer storage? #44
I bought a steel 100 gal tank and welded a couple of square tubes to the bottom for my forklift. The tank fits cross ways in the back of the truck. I use 1 " ratchet straps and drive slow. At home I built a coaster dolly for it so I can roll it around in the barn on the concrete floor a bit when needed. The tank is fitted with a 12v pump and nozzle. An old 12v battery sits on the floor next to its resting spot. It works well for me.
/ What do you use for diesel transfer storage? #45
As I posted
/edit
I use a 108 gallon transfer tank mounted to a pallet made of 4x4's on the bottom and 2x6's for the top. I set it on a large wheeled steel dollie so I can roll it around in my barn.
As far as securing it in the truck for fueling runs, I have a large 20k lb cargo net that I just throw over the whole thing and secure the 4 corners to the bed tie downs.
/ What do you use for diesel transfer storage? #46
I did something similar. Before I began using #2 ULS home heating oil in my tractors, I transported diesel in my pickup. I mounted a 100 gal steel tank to a sturdy pallet made from treated lumber. The pallet had caster wheels on the bottom so I could roll it around in the pickup bed and also in the barn. I would place it up against the cab and securely hold it in place with ratchet straps during transport. To unload, I would roll it out to the tailgate and lift it off with the forks.
I only did this to transport fuel a short distance to and from the gas station. Since it's illegal in many locations, I would NOT consider leaving the tank in the truck full time.
Since the tank was portable, I needed a pump that was also portable with it's own power supply. This made it easy to move around to locations where neither AC or DC power was available. I used a standard 12V transfer pump and powered it with 20V cordless tool batteries. I always have several charged and ready to go for my cordless tools.
I used a 20V to 12V buck converter which I still use on a small drum to fuel my other diesel equipment.
Giyi Mini Ex Attachment Set (A60463)
Giyi Mini Ex...
2024 Linx 7'x20' Trailer (A60463)
2024 Linx 7'x20'...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
Adams Under Truck Conveyor (A61307)
Adams Under Truck...
AGT Industrial STSD10 QA (A60463)
AGT Industrial...
2016 JLG 1932ES ELECTRIC SCISSOR LIFT (A59823)
2016 JLG 1932ES...
