Just another junk chainsaw
/ Just another junk chainsaw #2,161
My engine guy claims the same. Only ethanol free gas in everything. Fortunly our local BP station as a specific non ethanol pump.
/ Just another junk chainsaw #2,162
It's available here as well, but a 30 mile drive so I use syn gas as there is an Echo dealer up town. Not driving 30 miles to buy it.
I know its just like any thing else, if you do it enough you get good at it, but I am always impressed with people that are good at carb work. I am a pretty handy guy. I can wrench on many things and learned as a farm kid where dad and grandpa were cheap and didn't believe in paying someone to do something they could figure out. But the fine art of carburetors I just haven't picked up yet. I have a guy that fixes atvs for me and he's amazing at it. Can take any small engine and just make it run like new.
They are easy. Just take pics while learning of the order of things. I didnt get that luxury of phone cameras on the fly.
Make sure match up each gasket and diaphragm. Sometimes 3 different ones in kit with extra hole here and there.
Very few dont take to a new kit and cleaning.
Husqvarna 564xp fuel Injection Launch date: 12 October 2025 UK
62.4cc
4kw 5.36hp
5.9kg 13lb
/ Just another junk chainsaw #2,166
Then everyone who owns huskys can complain like the stihl guys.
I haven’t had any problems (yet).
Run nothing but race fuel, Stihl fuel or non-ethanol. Worth every penny, IMO.
Saws run perfect, but all are 2022 or 2023 saws.
Even the 500i when you have a repair site is like a 50/50 gamble of getting a good one.
Some get one dont have problems. Some get them and they burn up in a month of use.
I'm going to set back and watch as guys that are running these 564 are already showing them to us there.
Husky has their problems too even on past saws. Why you think they are up to MKII and MKIII on some. :ROFLMAO:
/ Just another junk chainsaw #2,168
Fuel related?
Mine is like a great white shark. It just gnaws through wood. I love it.
It’s like a treat to run….I’m actually serious…
Ever have a saw that’s not necessarily the biggest/baddest, but it just suits you perfectly?
Just the sound of it…..:cool:
Fuel related?
For some reason when they act up they go into a lean condition.
I just read on it I aint even going to try and learn these myself.
I do have the service manual in my group though.
I can even show you the 500i they used to teach techs on at their school. It's pretty cool in itself.
/ Just another junk chainsaw #2,170
Only thing I have encountered is a ever so slight “fade” at very top of rpm band sometimes.
Before they were even released the training aid.
First 500 are the collectibles of them too.
One being run in Ausgberg
Pics of air filter, air injection etc etc
Can see the cutaway flywheel and xpG stuff.
/ Just another junk chainsaw #2,176
The Husky clutch covers are all plastic, or is that some kind of alloy for the clutch cover?
All mine been mag just like crankcases. They just went to new style without the decals.
@Hay Dude
One that went lean condition.
1 month old 500 that was posted long ago. One of many guys were posting way back.
/ Just another junk chainsaw #2,179
Most likely some sort of 'high impact' plastic. Saw builders today are employing more and more plastic parts in as much as they are less expensive to produce, are lighter and structurally are just as good strength wise as alloy.
If you want alloy parts, better be buying an older saw and most likely rebuilding it or have the OP rebuild it for you as again, you won't find very many 'modern' saws devoid of plastic parts today. Why I like my old Stihl's alloy parts but then again repairing busted alloy parts (especially crankcases) entails some rather sophisticated welding techniques. Welding aluminum or magnesium alloys require TIG welding and extreme pre prep and the filler rod is super expensive as well. Just TIG welded a Dolmar with a cracked oil tank that was peeing bar oil everywhere. I had to complete disassemble the saw, carefully prep the casting to remove any and all traces of bar oil, I had to hot tank degrease the case and then clean it again with non chlorinated brake cleaner, numerous times, pressure dry it and then weld it and the filler rod was insanely expensive as well plus I had to run straight argon on the TIG welder, bevel the crack in the case and weld it on the inside as well as the outside and take special precautions when welding it because magnesium alloy's are flammable if over heated, especially any grinding swarf. I returned the saw to the owner not assembled as I don't do that sort of thing (rebuild-reassemble) saws anyway. TIG welding aluminum or aluminum-magnesium alloys are difficult to put it mildly and only reason I did it was because it was for a friend but I still charged him for the filler rod and yes, the external weld looks 'cobbly' but the Dolmar is his baby so I did it for him.
Die cast alloys always look nice until they have to be repaired, then they don't look so pretty. Have no idea how he cracked the case in front and didn't ask either. All I know was, it was peeing bar oil everywhere and making a huge mess. Don't now or I assume it don't now as again I returned it to him in a box, not assembled.
The issue with repairing ANY failed part or die casting that has been subject to oil contamination is all in the prep. You absolutely MUST remove all traces of any lubricant or grease to effectuate a sound and non porous weld. That applies to even mild steel. That is what takes time and patience. After I welded I dye scanned the weld to make sure it was sound and had no leaks. Not something an ordinary 'Joe' can do successfully in their home shop either. I own the equipment including the hot tank degreaser.
/ Just another junk chainsaw #2,180
@Hay Dude
Looks like she got a bit overheated and an acute lack of oil as well. Alloy pistons aren't tolerant of either. How did the cylinder look???
2019 CATERPILLAR 299D3 SKID STEER (A65053)
2019 CATERPILLAR...
2019 JOHN DEERE 331G SKID STEER (A65053)
2019 JOHN DEERE...
HARDEE 16' T/A TILT BED TRAILER (A64278)
HARDEE 16' T/A...
2018 Sundowner FD-306 REV A 24ft. T/A Enclosed Gooseneck Trailer (A64194)
2018 Sundowner...
2025 Auger Drill Bit Skid Steer Attachment (A64553)
2025 Auger Drill...
2017 Ford F-150 Ext. Cab Pickup Truck (A61572)
2017 Ford F-150...
