Just another junk chainsaw
/ Just another junk chainsaw
Mad dog coarse like my old save edge ones.
Use many different handles depending on which it is. Lot of wooden and plastic ones.
Seriously if your wanting a light limber that is so nimble. Rear handle echo 2511PN with nano set up 325 043.
Full of mix and bar oil. With 12” b+c in the 7lb range.
PHO dry 5lbs 12oz
Put a Egan pipe on it for 28% gains shown on Joes dyno.
There is guys porting them and using stock mufflers modded not even seeing those numbers.
I do have one botch. Their caps suk to use. Will be upgrading those.
They want you to use the starter handle to remove.
/ Just another junk chainsaw #2,123
PHO dry 5lbs 12oz
View attachment 3269683View attachment 3269684
I will second this for sure. The 2511 is so tiny it doesn't even feel real but it is an absolute monster for its size and so much fun to use. I put the Egan pipe on mine within a week of buying the saw new. This is one saw that ALWAYS goes out with me when I am cutting.
I still cant believe it is only 25cc.
I never ran the oem one stock to even see how bad that muffler was holding it back. 😂
Mine all will be getting new caps though. I hate their 2 prong caps. Wanting us to use starter handle.
/ Just another junk chainsaw #2,125
Yeah you would never think it's only 25cc running it!! I don't have an issue with the caps, rarely do I need to use the starter handle to open them.
I wont use the starter handle. I stick scrench in to undo.
Friend has a 361 rear handle echo he said he wont even touch since buying the 2511 rear handle.
Here is what will be on it and the clone fuel cap soon.
I never check to see if the smaller oiler cap on clone was different threads or not.
But I ordered 4.
Just got a confirm that all 4 shipped yesterday. :cool:
They are like these but made for smaller huskys.
372 OE I had and sold with only 2 tanks through it. Can still buy them new from overseas dealer in my group.
Last 6 OEM poulan 475 415 pto side crank seals I know of in US. In hand now.
John got the last ones from overseas last year.
I had sold out of my last 3 like 2 years ago.
2 are spoken for already.
They will be on the shelf for folks when needed for saws you keep oem.
/ Just another junk chainsaw #2,130
Pretty sure there are more out there in fantasyland.
I see you have 62,000 subscribers. Amazing. I didn't realize there were that many ancient chainsaws in use out there.
Must be a lucrative side business for you.
Well when you find them on your little fantasy land let folks know. People been hunting these down for over 20 years now.
Nothing matches them in the seal world.
Hopefully be able to start both the 359's next week. Neither has decomps. Starting anything but smaller 2511 standing up is the limit right now.
359’s 06 09.
Took that stupid yellow warning sticker off af area.
09 is the one that come in trade as a 353 in disguise. Had 353 decal etc on recoil.
Trying to straighten it up for the testing next week.
Put some heat tape In cylinder cover where they tend to get hot at.
Also going to try that Sawsalvage chain for the testing.
06 one is ported by Corey at Fabcorp OK.
09 came in trade. Has a gasket delete. I just did a gill muffler mod and opened inside.
Those smaller husky flippy caps work no leaks.
Being gasket style newer husky style.
It works on oem echo 2511 fine. Don’t over tighten.
V-modest 2511 I knew oil one was out. But ordered 4 anyway.
Going to try small one on different saw to see.
The gasket on clone caps even more different. So definitely don’t want to over tighten.
But loving the ease of the screw in flippy over those darn 2 prong caps.
Guy overseas running the new 400.
Inside the new 400 muffler
Just like the end run of the 460. Pencil eraser size to breath through.
I bet she run lot better opened up.
/ Just another junk chainsaw #2,135
If it runs that good choked up. Imagine how it will run when opened up to breath.
/ Just another junk chainsaw #2,137
The cap on my Chinese Clone saw leaks gas pretty badly. I ordered a replacement cap from Amazon but it leaks too even worse. Will one of these "flippy" Husq caps fit ? I'll try it if even a chance it is. And looking at that restriction in the muffler you have to wonder what they were thinking in the design group. I'm gonna have to look at my Chinese saw and see what that one looks like. It did seem restricted on high RPM's so maybe something going on there. Cuts fine though with the 24" bar on it.
What saw? Most folks go to oem if they have a afm cap leaking.
I was mixing efree and vpracing yesterday. Can and combi's refills.
Did notice one thing about the aftermarket clone stihl combi. Farmertec version of their 2 they sell that I like.
Don’t like the older green cap husky version with slanted holes. Not good when using funnels like I do.
It was closest to the newer husky combi I use.
Straight up holes for funnels.
But anyhow. Don’t have the clear area for 5L to see where it’s at for fuel or oil.
Ready to go again E-free
Stumper and sidekick reporting for duty. Farmertec G466 460 and G444 440
48” across lower area I want to cut at.
525 GAL WATER TANK (A68842)
525 GAL WATER TANK...
Asphalt Roller Tire (A68134)
Asphalt Roller...
1 PALLET OF HYDRAULIC HOSES (A66091)
1 PALLET OF...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
3142 (A63117)
3142 (A63117)
CAT D9G Springs (2) (A68134)
CAT D9G Springs...
