What is better than a kubota GR2120?
/ What is better than a kubota GR2120? #1
TJP440
Member
Kubota b3200 & GR 2120
Possibly looking to replace my 2017 GR2120 with 600 hours. Wondering what else is out there in the mower category that has the 4WD and steering features (not gouging the lawn on tight turns) of the GR2120.
Mow about 3.5 acres some areas with steep hills which is where the 4WD is handy when the grass is wet or damp.
Also have a larger B3200 for the bigger jobs. Total Acreage is 5.5
TIA 🍻
/ What is better than a kubota GR2120? #2
John Deere makes some 4 wheel drive riding mowers. Have you thought about a Kubota BX or 1 series JD or similar. They are very common used also.
Thought about the bx but the 4wd has to be disengaged on turns and also concerned about the weight.
I like a D/A had graduated up to the b3200 and was using it until I finally figured out it was to heavy and taking it's toll on the lawn especially in the summer months. So that's how the Gr2120 came along. The lawn responded to the GR but I'm concerned with the longevity as it does not seem to be as well built and some ( mostly earlier) units have had issues mainly with the HS 🍻
Looked at the Deere's and 17K with a low trade offer was just out of budget.
So I traded for a new 2025 GR for ~ 5500 difference.
hoping they have all the kinks out of the HS as they've had plenty of time to do so
Thanks for the replies 🍻
/ What is better than a kubota GR2120? #6
If all you're using it for is mowing, you might consider a Cub Cadet ZTXS series zero turn. They have steering wheel controlled front wheels and work great on hills. Plus, it is a true zero turn mower.
/ What is better than a kubota GR2120? #9
If you turn around slowly, and learn your machine, you can remove about 98% of any tearing on turns with a zero turn. On really wet days, well you can only do so much on hills I've found. But you are just mowing your own lawn, so there never should be a wet day mow. Just get a regular mower and take your time.
/ What is better than a kubota GR2120? #10
You're mowing 3.5 acres with a garden tractor and a 54" deck? I think you just described cruel and inhumane punishment.
Scalping on tight turns is usually a symptom of incorrect gage wheel settings.
the scalping was being done on tight turns by the front tires o the b 3200,
the GR2120 had no issues ;)
You should look into............... Never mind, my advice might not be very helpful :)
I have a B3200 which is not quite as big but none the less I finally figured out it was too heavy for the lawn :eek: D/A me. that's when I bought the 2120 🍻
It's done the job for 8 years and was still going. I've considered jumping up to a small B series but we're back to disengaging the 4WD on tight turns and weight issues. The GR is ~ 950 lbs, BX 1880 ~ 1400 with the deck, also more $$ :(
My hills are quite steep and most I've talked to advised against a zero turn. I've had several regular mowers in the past and sliding down hills sideways is not something the wife would enjoy as she likes to mow. so the 4wd was almost mandatory. The weather here can be quite unpredictable precipitation wise so one doesn't always get to choose when to mow especially in the spring.
I do want to thank all that replied 🍻🍻🍻
/ What is better than a kubota GR2120? #15
You need a ventrac. It's honestly right up anyone on this forums alley, just need a reason to own one. Get the double wheels and off you go!
New ones can be remote controlled down the steep stuff even, they are really impressive machines.
/ What is better than a kubota GR2120? #18
I looked at the offerings a few years ago, had one too many slide outs on my zero turn and compact tractor was crushing the lawn. Bought the GT2120 diesel and have never regretted it. Wife likes the smoothness of the cut and can put accessories like a REAL snowblower on it. It looked me like there are three tiers of small yard mowers those being the big box throwaways, the Kubota and John Deere models, the ventrac (pricey) models. After evaluating three, I decided the Kubota was for me. (I only take care of a couple of acres that I actually mow.)
/ What is better than a kubota GR2120? #19
Im not a cub cadet fan, but that is what is needed on slopes, if that steering wheel truly operates the front tires, I like the built in headlights and the seat that holds you in place.
I just may change my mind about the cub cadet.
/ What is better than a kubota GR2120? #20
The headlights are all but useless, so if you really need to use it in the dark you would probably have add aftermarket lights. The seat is comfortable, but if you have very rough ground, you may wind up unplugging the seat switch because it is ultra-sensitive (see my thread on the CC ZTXS5 54 for good, bad and ugly report on this mower).
I will say that mine is rock-solid on slopes.
2014 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2014 Ford F-150...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
16ft x 8ft Flat Bed (A57454)
16ft x 8ft Flat...
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
