Enfly DQ404 3 point linkage question
/ Enfly DQ404 3 point linkage question #1
Marty99
Enfly DQ404
I’ve just taken delivery of an Enfly DQ404 tractor. I notice that I cannot lower the 3 point linkage arms without putting weight on them. I have fully opened the drop speed valve under the seat (which apparently is the common solution). I’d like to hear from other Enfly tractor owners whether this is “normal” for an Enfly 40hp tractor? Thanks
/ Enfly DQ404 3 point linkage question #2
Try adjusting the draft control.
Welcome to the forum!
Thank you. Apologies in advance for my ignorance. When you say adjust draft control do you mean using the lever or is there another adjustment within the 3 point linkage. I have never come across draft control before and it would appear neither has the dealer I bought the tractor from 😀. Thanks again
/ Enfly DQ404 3 point linkage question #4
A lever beside the raise/lower lever, most likely.
Thanks Hodge, my main question was whether the 3 point linkage arms should go down without adding weight to them (ie just by using the control lever). My previous tractor did but this Enfly doesn’t appear to.
/ Enfly DQ404 3 point linkage question #6
Hi, I have an Enfly DQ554, and the 3 point linkage arms do the same. I have noticed that "without" an attachment, they are super slow to lower without weight. I usually just push them down with my hand or foot. Hope this helps.
/ Enfly DQ404 3 point linkage question #7
Hi I just recently purchased a Enfly DQ554 and came across your post through searching internet. I was concerned that the 3 point linkage would not lower. Your post solves my issue.
Thanks
/ Enfly DQ404 3 point linkage question #8
Welcome to the forum, mates. 👍
Don't be strangers. 🤠
/ Enfly DQ404 3 point linkage question #9
Thanks
Hi also recently purchased a Enfly DQ554, have same problem.The flow control below seat appears to have no effect whatsoever. Also hard to distinguish 3 point float lever is it the lever closest to seat? Also not overly impressed with braking response.
No float position with bucket.
Generally disappointing purchase.
Missing my Ferguson 35.
Kubota B21 TLB (A60462)
Kubota B21 TLB...
2010 Ford Crown Victoria Sedan (A59231)
2010 Ford Crown...
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
(APPROX. 20) 4' X...
2009 Volkswagen Jetta Sedan (A59231)
2009 Volkswagen...
2020 Chevrolet Silverado 1500 (A55315)
2020 Chevrolet...
