Any mathmeticians here
/ Any mathmeticians here #41
I dunno, my trig may be rusty but 6 down the middle of the 180 length should do it. . .
1st one starts 41' from sideline and the rest are spaced 82'
I could be wrong but I think that does it
/ Any mathmeticians here #42
Again, just curious as to why you'd want so many hoses and spigots? That's bigger than a football field.
They don't seem to want to answer this question because a few have asked now :ROFLMAO:
/ Any mathmeticians here #43
Simple cheat: Download the Rainbird Sprinkler Design Software.
Let it optimize for heads with 100-ft reach. Then install quick coupling valves everywhere the software says to put a head.
As one of my engineering professors said, "Plagiarize, there are a lot of really good ideas out there that are off patent. Look into what the last guy did, so you don't waste time reinventing the wheel."
/ Any mathmeticians here #44
I thought about that as well, but I think it'll want to put them in the corners, along the edges, and down the middle, like a normal sprinkler system would do.
The OP specifically said they want them along the edges only, and, that they were going to definitely put them in the corners as well.
It sure would help to understand the intended usage. ;)
You could do what I do and just use longer length of hose. I have three hoses connected together and I can reach any spot on my 2 acre rectangle from the back of my house.
My wife is 70 years old, she has trouble with one 100 fter
/ Any mathmeticians here #46
May I suggest along with your hoses this sort of shut off valve: https://www.amazon.com/dp/B0D66GQ5Q3
It's definitely a full-flow design - the ball in the valve has a very large hole in it.
It came with the nut on very tight; comes with a ridiculous little wrench none of us need.
Great thing to put on the end of a 100' hose because you can take your time walking from the hose bib to the end and not spill tons of water in the meantime.
I've bought a few of them now and love them. With it cracked open just a bit it's got a decent spray that I use to water a spot that I used to use as a burn pile till last year and now have wildflowers growing; wide open it fills up a tub as fast as your pump and hose can manage. I bought 50' and 100' 3/4" hoses from HF a couple years ago and so far so good.
/ Any mathmeticians here #47
Who'd have ever thunk that we could fill 5 pages on "how many hose bibs do I need?" I mean, the area is a simple rectangle, not exactly complex spherical geometry.
/ Any mathmeticians here #49
My scale is a bit off...
Putting the hydrants at the border might make more sense from a land use standpoint not having them in the way but strictly based on covering the area you’re wasting half the potential radius putting them on the perimeter.
/ Any mathmeticians here #50
What is being watered is a pretty important part of this problem.
If it is grass, the spigot system would work.
If you are watering plants, you are going to destroy them as you drag the hose over them.
More details would help get a better answer.
For that large an area a permanent sprinkler system might be a better solution.
Doug in SW IA
/ Any mathmeticians here #51
Doug in SW IA
I was kind of thinking along the same lines. More information would be really nice as maybe someone here would have a better idea of tackling the issue. And if you're gonna lay that many lines, might as well put in a sprinkler system.
/ Any mathmeticians here #52
If you optimize based on coverage alone and not location, it would save 4 hydrants.
I would argue those 4 additional hydrants add better value by maximizing real space than the cost savings they would produce.
/ Any mathmeticians here #53
Doug in SW IA
I thank myself every day of summer, for having installed miles of irrigation line, drip rings, and zone valves on this property.
That thankfulness occurs while I'm dragging hoses around and cursing myself for the few areas I skipped or haven't covered with irrigation, yet.
<-- blew out a soaker hose this morning 😠
/ Any mathmeticians here #54
Over 35 years ago I started using drip irrigation for our little garden. That progressed to the flower beds.
We moved and I set it up again in our flower beds, the garden, the hanging baskets, the planters, fruit trees and bushes. Heck, it even fills the bird bath!
Every year I just add a little bit more on to the system. I have a 4 zone battery operated timer on a spigot on the side of the house and 2AA batteries will last over 2 years if I take them out during winter.
2-3 years ago we built a little green house and I add in out there as well.
Last year I added a Venturi fertilizer injector. I pre-mix the fertilizer in a 5 gallon bucket and it sucks it out of there. I hit the flowers every 2-3 weeks, and the vegetables as needed.
/ Any mathmeticians here #55
To get some decent volume from a 100' hose, I would use ¾".
Pulling a 100' hose full of water over a 90° ark, in an 88,000 sf. area and doing it 6 or more times would be very labor intensive. Think of the resistance of the hose, trying to drag it sideways.
We need more info to make a less labor intensive suggestion.
/ Any mathmeticians here #56
Absolutely.
You're going to be trenching to put in the water lines; wherever a water line is, there's very little incremental cost to add spigots along the way - go hog wild and don't try to minimize them.
I'd minimize what's in the middle and run the pipes deep there....
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
2022 EZ-GO ELITE...
1999 Ford F800 Dump Truck, VIN # 3FEXF8019XMA05457 (A65563)
1999 Ford F800...
2018 Navigator RT-6500 6,500lb Piggyback Forklift (A61567)
2018 Navigator...
New/Unused Pallet of Chains, Binders, and Chain Slings (A65583)
New/Unused Pallet...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
