NS series aftermarket front tie down point & Bolt on bucket hooks
   / NS series aftermarket front tie down point & Bolt on bucket hooks #1
reb0957
Kioti NS4710
Anyone running this front tie down point from JU Fabworks? Any Pros or Cons?
I am also looking for something like this that fits an NS 6010 bucket. Any o fyou have one that works on these buckets?
Thanks!
   / NS series aftermarket front tie down point & Bolt on bucket hooks #2
Will that tie-down interfere with a grille guard if you've got one? It would with their version for the CK, which is what has me eyeing the 5Eleven example.
I've not purchased a JUFW product, but I've heard good things on Green Tractor Talk and I'm looking on purchasing the rear tie-down.
   / NS series aftermarket front tie down point & Bolt on bucket hooks #3
Can't just weld the individual parts to your bucket? That way you can choose the exact location.
Probably yes!
I just wanted to make sure the width fits the bucket. Welding is an option but just wanted one that fits a Kioti bucket correctly!
   / NS series aftermarket front tie down point & Bolt on bucket hooks #5
Check your local DOT requirements for equipment tie-downs. Most states require a separate tie down for each wheel on the machine. The receiver hitch tie down could be considered a single tie down point which in some states may not meet DOT Requirements.
Straight from their website. So, I don't think it will!
Installs in combination with your factory brush guard by using the same mounting holes as your brush guard! Longer and stronger grade 10.9 bolts are included. Please note, some Kioti models use 4 bolts instead of 6. We include 6 bolts, if you only have 4 mounting holes, just use 4 bolts for the installation.
   / NS series aftermarket front tie down point & Bolt on bucket hooks #7
Haven't got around to add hooks to my CK2620's bucket yet, but did decide to put then out by the loader arms, and even there at the stronger part of it I think the bucket would need to be reinforced.
   / NS series aftermarket front tie down point & Bolt on bucket hooks #8
Thanks!
Go to your fleet store or Amazon and buy some weldable 3/8" hooks.
Then find the wettest welding rods you've got along with the oldest and lightest welder you've got and weld them onto your bucket like so.
2010 Kaufman Gooseneck Trailer (A59814)
2010 Kaufman...
Case IH 875 Disc Ripper (A59814)
Case IH 875 Disc...
2017 CATERPILLAR 305E2 CR EXCAVATOR (A60429)
2017 CATERPILLAR...
UNKNOWN  20 FLATBED GOOSENECK (A58216)
UNKNOWN 20...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A59904)
2012 INTERNATIONAL...
207270 (A52708)
207270 (A52708)
