Our new PT425. It’s new day…😊
   / Our new PT425. It’s new day…😊 #24
Bet you'd like a shiny new one, too.
   / Our new PT425. It’s new day…😊 #26
Congrats on the new machine.
Regarding the foot pedals being touchy: Give yourself several hours of seat time before modification. I had the same problem as you. It did not take too long to get used to the pedal's sensitivity.
   / Our new PT425. It’s new day…😊 #27
Could it be that you got used to overly hammering down on the pedals on your old machine because it really had some pump issues at the end?
Very possible! 😊
I had the wife run it for a bit, scooping up dirt on an uphill grade, then move it across the hillside and dump on downhill grade. She too was a bit nervous with the pedals—especially reversing.
I’ve found that reversing uphill is worse too, mainly in rough ground. (rough as in washboard-type surface or similar, or basically not flat yet😉) To me, it’s like a little “hump” in the pedal that goes from slow to fast immediately, no matter how I’ve tried to manipulate it. A lower throttle does help, but can kill it easily too with a little resistance. But I’ll give it some time. I did think about possibly putting some kind of “limiting block” underneath the reverse side, to keep it from getting away with us…🤔
Yes sir that hopefully will help. 😊
   / Our new PT425. It’s new day…😊 #30
Very possible! 😊
I bent the pedal on the reverse side, from a V shape to more flat on the left. It helped limit overall reverse speed, but still spins the front tires from a quick rise in torque. Maybe someday I will take the time to decrease the orfice for the line restriction.
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2021 Ford F-150...
2013 Ford F-150 Pickup Truck (A53422)
2013 Ford F-150...
2008 INTERNATIONAL 9200I DAYCAB (A55745)
2008 INTERNATIONAL...
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
JOHN DEERE 1705/6700 (A53084)
JOHN DEERE...
2016 CATERPILLAR 325FL CR EXCAVATOR (A52705)
2016 CATERPILLAR...
