Our new PT425. It’s new day…😊
   / Our new PT425. It’s new day…😊 #24
Bet you'd like a shiny new one, too.
   / Our new PT425. It’s new day…😊 #26
Congrats on the new machine.
Regarding the foot pedals being touchy: Give yourself several hours of seat time before modification. I had the same problem as you. It did not take too long to get used to the pedal's sensitivity.
   / Our new PT425. It’s new day…😊 #27
Could it be that you got used to overly hammering down on the pedals on your old machine because it really had some pump issues at the end?
Very possible! 😊
I had the wife run it for a bit, scooping up dirt on an uphill grade, then move it across the hillside and dump on downhill grade. She too was a bit nervous with the pedals—especially reversing.
I’ve found that reversing uphill is worse too, mainly in rough ground. (rough as in washboard-type surface or similar, or basically not flat yet😉) To me, it’s like a little “hump” in the pedal that goes from slow to fast immediately, no matter how I’ve tried to manipulate it. A lower throttle does help, but can kill it easily too with a little resistance. But I’ll give it some time. I did think about possibly putting some kind of “limiting block” underneath the reverse side, to keep it from getting away with us…🤔
Yes sir that hopefully will help. 😊
   / Our new PT425. It’s new day…😊 #30
Very possible! 😊
I bent the pedal on the reverse side, from a V shape to more flat on the left. It helped limit overall reverse speed, but still spins the front tires from a quick rise in torque. Maybe someday I will take the time to decrease the orfice for the line restriction.
MULCHER (A58214)
MULCHER (A58214)
2.5 POLY PIPE (A58216)
40006 (A55788)
40006 (A55788)
TANK MANIFOLD (A58216)
2009 Toro Workman HD Utility Cart (A56857)
2009 Toro Workman...
UNUSED FUTURE 36C STAND ON SKID STEER (A58375)
UNUSED FUTURE 36C...
