Is my diesel still usable?
/ Is my diesel still usable? #1
future_vision
Gold Member
New England
DK6010SE HSA
I found out, this weekend, that I left a couple of the plastic gas cans on my property, filled with diesel. They had the caps on and were under a tarp but I am concerned for 2 reasons.
1. The diesel is probably somewhere between 6-8 months old
2. Could it be contaminated with water in those conditions?
From what I read, diesel can last 6-12 months IF stored properly. I suspect the way mine was 'stored' does not qualify. If it is still potentially usable should I treat it with something that will disperse the water? I found this product Diesel Force Comprehensive Maintenance System
/ Is my diesel still usable? #3
If youre worried about it mix it 50-50 with fresh diesel. The modern gas is supposed to have a shelf life too and I just mix fresh gas in with it with no issue
/ Is my diesel still usable? #4
If there are no signs of algae growing in the fuel, I would not hestitate to use it. I am currently running fuel in a diesel tractor that I loaded up from out in the middle of the field where the tractor sat for a minimum of 5 years. It was clear, didn't have any algae growing, and I had already gotten it running on that fuel before I even thought that I should have changed it out. That was a year ago, and since I don't run that tractor much, it is still on that tank. I pulled that tractor out last week just to drive it around and my Bride made the comment "I didn't even know that tractor ran"!!! which shows you how much it gets used.
David from jax
/ Is my diesel still usable? #5
Properly stored diesel lasts A LOT longer than 6-8 months! I currently have a drum of 5 year old diesel that I will use up this year in my diesel mowers. I store 55 gallons specifically for long term power outages in a full sealed drum in a small shed.
If there is any chance of water contamination, I would pour the fuel through a water blocking filter like a Mr Funnel.
/ Is my diesel still usable? #7
Regarding water, I would think you would be able to see the water rolling around on the bottom of the can if you were to shine a light in there.
/ Is my diesel still usable? #11
Currently burning home heating oil that I bought march of 2020. Its stored just like alot of fuel..in a 275gal tank outside and not covered.
My pump has a goldenrod filter with clear bowl..its clean and the tank is 1/2 used. I should run out of fuel in year 2031-2032.
/ Is my diesel still usable? #12
Talk about ancient diesel fuel, when they fired up the COD, which is permanently berthed in Cleveland, Ohio, they started the diesel engine on what was still left in the diesel tanks, left over from WW2. No issues other than filtering it. I have a good friend (submariner) who is a mate on the COD preservation committee. He said it still smelled like diesel exhaust.
/ Is my diesel still usable? #13
Pour some in a clear glass container to look for water. I parked my 6.5 diesel pickup for three years while I was in Japan. That tank got lousy mileage but it ran fine.
/ Is my diesel still usable? #14
The oldest diesel I use was bought about 13 years ago.
A few years ago I learned about Star Tron, but while it works wonders on gas I can't really tell if there's a difference with the diesel version.
/ Is my diesel still usable? #15
When I suspect water, I let the can sit for an hour or so (overnight even) Then, without too much agitation, I pout the lion's share off into the tractor. Holding back the last 1/2 gallon or so.
That remainder I pour out into a CLEAN drain pan. Looking for water. If I see any water at the bottom, I carefully tip off the clean fuel . When I call it good enough, the remainder goes into my "cleaning solvent" coffee can that is always out on the cleaning bench!
/ Is my diesel still usable? #16
It can last a lot longer than that. I've used diesel that was at least 3 years old. 6-8 months isn't an issue. If you're worried, use a couple gallons at a time mixed with fresh fuel.
/ Is my diesel still usable? #17
I'm never worried about the age of diesel fuel. A bit of conditioner is never a bad idea and an algae preventative--due to quality control/contamination concerns can't hurt if it's really old. From what I gather from other diesel users (I've had no issues), algae seems to be a concern only with newer, low-sulfur fuel.
/ Is my diesel still usable? #18
I normally have 250 gallon of red dyed diesel delivered when I need diesel. That will normally take me 4 years to use. I am not scared of using it even after that time
Same here. I’m still using a tank I had filled just after Covid started. Never a problem.
/ Is my diesel still usable? #19
Ge some John Deere Diesel fuel conditioner and add to the fuel. I have used 3 year old fuel stored in an aluminum tank with no problem.
/ Is my diesel still usable? #20
Pour it into a filtration unit through a filter funnel and run it through 10 and 5 micron filters then a water separator. It shouldn't blow up your tractor. Or just just use it as is. :ROFLMAO:
8 month old? I don't have any less than 2 years old.
HERD SURE FEED SEED BROADCASTER (A63745)
HERD SURE FEED...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
Ingersoll Rand 185 Compressor (A64047)
Ingersoll Rand 185...
2025 Swict 84in. Bucket Skid Steer Attachment (A61572)
2025 Swict 84in...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
