Air compressor lines for stationary air compressor.
/ Air compressor lines for stationary air compressor. #41
I looked at the cheapo Chinese timed moisture drains as well, but I prefer domestic made if at all possible so I went with the Suburban Manufacturing timed drain from Compressors Direct. It cost more but it's also made here in America and being patriotic whenever possible, I bought the American made unit. Looks like the Chinses / Amazon unit but made here. I bet the Chinese bought one and copied it.
Is this the one you bought?
/ Air compressor lines for stationary air compressor. #42
The only sure fire way to remove moisture totally from your supply lines is to have a final removal at the point of use. Why I use Motorguard cannister filters on both my plasma cutters simply because even a tiny amount of moisture in the supply air does nasty things to any plasma cutter like destroy consumables quickly so it's expedient for me to remove ANY moisture at the point of use and the Motorguard filters also remove an solid contaminants like pipe scale before it can bet into the works. My entire system is in black iron so I always expect some internal pipe scale ti be present in the supply air. The Motorguard cannister filters have a 2 micron pass so they capture any solids and the moisture as well and the filters are easily replaceable and cheap too. You can even use a roll of TP in them, though I don't.
Don't matter if you drain your receivers or have timed drains like I have, a certain amount of moisture will always be present in the supply air simply because the compressed air is warmer than the supply piping and the piping being cooler than the supplied air will cause moisture drop out in the lines themselves.
Like fill a glass with a cold beverage and having the outside of the glass collect moisture. Same applies to compressor piping but the moisture condenses on the inside of the piping, not on the outside.
Why it's imperative to have a moisture separating filter at the point of use and why you can purchase an inline desiccant filter that attaches inline to a spray gun as well.
I'm a rattle can person but plasma cutter consumables are expensive to replace so it's a matter of economy for me to run Motorguard cannister filters on the inlets of the plasma cutters... and keep my air tools oiled as moisture will screw up the carbon vane air motors in them, if not kept lubricated.
/ Air compressor lines for stationary air compressor. #43
Yes, I have 2 of them actually. The Chinese ones look similar except they are Chinese...lol One thing I like about the Suburban units is the ability to blow down the units and get any receiver tank solids blown out of the air supply. Your receiver, especially if it's ren infrequently, will develop some internal rust and the Suburban units all for that. That is what the black 1/2 turn handle is for actually.
Suburban also makes a non electric version that uses the pressure differential on the compressor unloader valve to dump the moisture but it don't come with a blowdown valve so I went with the timed drain instead.
/ Air compressor lines for stationary air compressor. #44
Fo my connector hose I think I used a 3 ft piece of tractor hydraulic hose. 3,000 or 5,000 psi. Plan to get a new one like that. OK?
I think that should work. I used something very close to @WinterDeere's for the braided cover, but hydraulic hose is definitely rated for oil and pressure.
All the best, Peter
/ Air compressor lines for stationary air compressor. #45
Probably fine. Only possible down-side I can see is hydraulic lines use zinc-plated steel fittings, which aren't very corrosion-resistant when subjected to the constant high-temperature moisture coming off a compressor, so they likely will rust a bit inside. But the rust is usually a minor nuisance in most applications, unlikely to cause any mechanical failure in one lifetime. Both use reinforced rubber line that's oil resistant and crimp-type fittings designed to handle vibration on the respective hose types.
I generally use hydraulic lines for hydraulics, and air lines for air, but it doesn't mean a hydrauic line won't get the job done in a pinch. If we could fast-forward 10-20 years, I'll bet my brass-fit rubber air hose holds up better to the heat and moisture, than anyone's 3000 psi steel-fitted hydraulic hose. We've all seen the way zinc-plated steel quick couplers tend to rust when placed upstream of your moisture control system, and this would be the same. But you'd probably have to live two livetimes to ever see it actually fail.
This is the connector hose I had from my tank to the lines. I thought it was a hyd hose but now looking at it, I don't think so. The connection on one end says maybe this was specifically for an air compressor? Anything wrong with using it again? It's in great shape.
/ Air compressor lines for stationary air compressor. #47
Probably fine. I’d personally replace the rusty iron with brass, but I’m fastidious like that. What you have there will likely hold fine for many years.
I wouldn't want anyone to think I was less than a perfectionist but there comes a time when advancing age changes your perspective on priorities.
/ Air compressor lines for stationary air compressor. #49
View attachment 3285590 .View attachment 3285591
Looks like a hydraulic hose from this armchair...
I think this is really your call about fix before it breaks versus fix after it breaks. A new hydraulic hose from Baileys or Surplus center isn't that much.
If you were changing things, my only $0.02 would be to put a valve on it where it attaches to the tank, so the hose doesn't have to stay pressurized.
All the best,
Peter
All the best,
Peter
Yes, I had a valve at the tank and drained lines and tank after use. I don’t use much now and don’t want to leave with pressure or moisture in tank. I’ll look at hose and likely replace. I’m not into cheap.
/ Air compressor lines for stationary air compressor. #51
If you drain the tank at each use, I'd say there was no need for a valve. :)
All the best,
Peter
/ Air compressor lines for stationary air compressor. #52
There is really no practical way to remove "moisture" from the tank. Even just one drop of standing water assures that the inside of the tank is at 100% relative humidity.
/ Air compressor lines for stationary air compressor. #53
Nothing worse than fisheying an automotive grade paint job... I always put a final in line filter at the gun even though I don't like having it attached to the gun. Next job going to add a short whip and I ordered an amazon "special" 3/4" aluminum/poly pipe with accessories.
All these years and vehicles I painted in different garages and never had any thing but rubber hoses...
Finally getting a "better than hoses" from a filter at the compressor should be a big improvement and as 5030 has said that volume at the 1" impact gun should really pep up the stuck bolt /nut busting loose ability.
As much as the really high quality black pipe and etc. cost, it would be really, Really nice but for what it costs I think these Aluminum poly kits will work for the work I plan to do. Being Pushed to get the wifes AMX on the road again, maybe even push a paint job through soon. maybe.
/ Air compressor lines for stationary air compressor. #54
My only comment is not only are the outlet fittings not very large in diameter (ID) but the hose is as well. The larger the ID, the more CFM you can flow.
/ Air compressor lines for stationary air compressor. #55
I tend to use DuPont 10FEE fish eye eliminator if I use a spray gun, which is rare. I'm a rattle can person actually.
/ Air compressor lines for stationary air compressor. #56
3/4" ID 1" OD on the kit I bought and made sure to get a couple hundred feet - but yeah they do shrink down some of the blocks and fittings.
The kit:
Definitely going to limit the line pressure to ~135PSI after reading the 140* pressure rating...
I totally missed that when I ordered the kit.
If it fails in short order I Will post it up with pics. Have never worked with this material before, we will see.
/ Air compressor lines for stationary air compressor. #57
Nice kit for the home shop I'd say but in my case with employees, I really had to run all black iron. I'd cut my pressure to 135 anyway. All I run my shop system at, always have. Your compressor will last a lot longer, you'll make less moisture to remember, all air tools like CFM not pressure. 135 is sufficient for any air tool, it's the air delivery that counts.
/ Air compressor lines for stationary air compressor. #58
The kit:
I looked at the ad. 200 psi at 73F and 160 psi at 140F.
/ Air compressor lines for stationary air compressor. #59
There also comes a time when advancing age means you've collected so much brass in your hardware drawers, that they won't close anymore, and you're just looking for excuses to use it! :p
/ Air compressor lines for stationary air compressor. #60
I'm with you on that. If I use something for a project and don't think i will use it again in my lifetime I don't replace it.
2020 John Deere HPX615E Gator 4x4 Diesel Utility Cart (A61572)
2020 John Deere...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
2002 Vermeer SC252 Walk-Behind Stump Grinder (A61572)
2002 Vermeer SC252...
2005 Ford F1-50 Ext. Cab Pickup Truck (A61573)
2005 Ford F1-50...
2015 Sealine F380 Flybridge Motor Yacht Boat (A59231)
2015 Sealine F380...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
