Straight pipe on yanmar 2TR series engine
/ Straight pipe on yanmar 2TR series engine #1
millard762
yanmar 165D
Has anyone on here put a straight pipe/stack on their tractor with a 2TR series of engine? I looked for videos on YouTube, but couldnt find anything. Just curious if it will actually sound decent or if it will be annoying/obnoxious. Plus, I want the exhaust exit up and away from my face. Thanks
/ Straight pipe on yanmar 2TR series engine #2
Being a 2 cylinder engine, I can only imagine being obnoxiously loud and uncomfortable to be even close to.
I had the muffler break on the Kubota B7000 I had, also 2 cylinder engine. That thing sounded so bad and was so obnoxious that I stopped the work I was doing to fix it right away. 😅
/ Straight pipe on yanmar 2TR series engine #3
We have a Deere M 2 cylinder with straight pipe I hate… but my teenage nephew loved it…
/ Straight pipe on yanmar 2TR series engine #4
Any diesel without a turbocharger will be obnoxiously loud. Turbocharged diesels are relatively quiet as the turbo breaks up the sound waves. If you don't want to have it 'in your face', install a down pipe instead.
/ Straight pipe on yanmar 2TR series engine #5
Never had just a straight pipe, but I did change my old B8200 from vertical to horizontal (and a 90 degree lateral tip ) to get the exhaust out of my face.
I did have the exhaust pointed down initially and I still got blowback. Maybe i will just install a taller pipe on top of the muffler to get it up and away. Thanks all
/ Straight pipe on yanmar 2TR series engine #7
Tow of my tractors have short vertical exhausts and I learned quickly my respirator is my best friend…
/ Straight pipe on yanmar 2TR series engine #8
Your tractor has a muffler, use it. The muffler mounts to the exhaust manifold on a square bolt pattern. Turn it 90 degrees so it points straight up and put a taller pipe on the top..
/ Straight pipe on yanmar 2TR series engine #9
Several of the 2TR YM machines have the exhaust pipe going straight up.
YM1300 2TR13
YM1500 2TR15
YM1600 2TR16
YM1700 2TR17
YM1800 2TR18
YM1900 2TR19
YM2000 2TR20
I currently have my exhaust verticle after it being horizontal for a while. I will keep it verticle, but I will take off the short extention and put a taller stack on along with a exhaust cap
/ Straight pipe on yanmar 2TR series engine #11
I currently have my exhaust vertical after it being horizontal for a while. I will keep it vertical, but I will take off the short extension and put a taller stack on along with a exhaust cap
Put a cap on it now, if water gets in there, costly repairs you would have to endure.
I keep it parked in my garage plus it currently has the factory short and angled extension
/ Straight pipe on yanmar 2TR series engine #13
When I got my YM155d the exhaust was horizontal and at times it would blow back in my face, so I positioned it vertically and that actually made it worse, so I put it back the way it was horizontally. I think the key here is to have a longer pipe vertically to solve the problem. I left if horizontally as it was the lesser of the 2 evils, and I use that little guy in the woods and don't want a taller exhaust, more to catch it on and or break it.
I ended up putting an extention on and a flapper. I still want to either straight pipe it or something like a glass pack
/ Straight pipe on yanmar 2TR series engine #15
When you do straight pipe it or glass pack it, be sure to post a video and pictures.
Ok
2023 KOMATSU D51EX-24 CRAWLER DOZER (A65053)
2023 KOMATSU...
JOHN DEERE 7200R TRACTOR (A64278)
JOHN DEERE 7200R...
JOHN DEERE 1705 - 6R36" VACUUM PLANTER (A64278)
JOHN DEERE 1705 -...
1/2" Quick Attach Blank Plate (A66408)
1/2" Quick Attach...
2000 INTERNATIONAL 4900 - 10 WHEELER GRAIN TRUCK (A64278)
2000 INTERNATIONAL...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
