Straight pipe on yanmar 2TR series engine
   / Straight pipe on yanmar 2TR series engine #1
millard762
yanmar 165D
Has anyone on here put a straight pipe/stack on their tractor with a 2TR series of engine? I looked for videos on YouTube, but couldnt find anything. Just curious if it will actually sound decent or if it will be annoying/obnoxious. Plus, I want the exhaust exit up and away from my face. Thanks
   / Straight pipe on yanmar 2TR series engine #2
Being a 2 cylinder engine, I can only imagine being obnoxiously loud and uncomfortable to be even close to.
I had the muffler break on the Kubota B7000 I had, also 2 cylinder engine. That thing sounded so bad and was so obnoxious that I stopped the work I was doing to fix it right away. 😅
   / Straight pipe on yanmar 2TR series engine #3
We have a Deere M 2 cylinder with straight pipe I hate… but my teenage nephew loved it…
   / Straight pipe on yanmar 2TR series engine #4
Any diesel without a turbocharger will be obnoxiously loud. Turbocharged diesels are relatively quiet as the turbo breaks up the sound waves. If you don't want to have it 'in your face', install a down pipe instead.
   / Straight pipe on yanmar 2TR series engine #5
Never had just a straight pipe, but I did change my old B8200 from vertical to horizontal (and a 90 degree lateral tip ) to get the exhaust out of my face.
I did have the exhaust pointed down initially and I still got blowback. Maybe i will just install a taller pipe on top of the muffler to get it up and away. Thanks all
   / Straight pipe on yanmar 2TR series engine #7
Tow of my tractors have short vertical exhausts and I learned quickly my respirator is my best friend…
   / Straight pipe on yanmar 2TR series engine #8
Your tractor has a muffler, use it. The muffler mounts to the exhaust manifold on a square bolt pattern. Turn it 90 degrees so it points straight up and put a taller pipe on the top..
   / Straight pipe on yanmar 2TR series engine #9
Several of the 2TR YM machines have the exhaust pipe going straight up.
YM1300 2TR13
YM1500 2TR15
YM1600 2TR16
YM1700 2TR17
YM1800 2TR18
YM1900 2TR19
YM2000 2TR20
I currently have my exhaust verticle after it being horizontal for a while. I will keep it verticle, but I will take off the short extention and put a taller stack on along with a exhaust cap
   / Straight pipe on yanmar 2TR series engine #11
I currently have my exhaust vertical after it being horizontal for a while. I will keep it vertical, but I will take off the short extension and put a taller stack on along with a exhaust cap
Put a cap on it now, if water gets in there, costly repairs you would have to endure.
I keep it parked in my garage plus it currently has the factory short and angled extension
   / Straight pipe on yanmar 2TR series engine #13
When I got my YM155d the exhaust was horizontal and at times it would blow back in my face, so I positioned it vertically and that actually made it worse, so I put it back the way it was horizontally. I think the key here is to have a longer pipe vertically to solve the problem. I left if horizontally as it was the lesser of the 2 evils, and I use that little guy in the woods and don't want a taller exhaust, more to catch it on and or break it.
I ended up putting an extention on and a flapper. I still want to either straight pipe it or something like a glass pack
   / Straight pipe on yanmar 2TR series engine #15
When you do straight pipe it or glass pack it, be sure to post a video and pictures.
Ok
2012 FREIGHTLINER CL120 CONVERTED TANDEM AXLE GLIDER DUMP TRUCK (A59905)
2012 FREIGHTLINER...
2020 DRAGON ESP...
2019 TAKEUCHI TL10V2 SKID STEER (A60429)
2019 TAKEUCHI...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2018 Keystone Outback Super-Lite 330RL T/A Travel Trailer (A59231)
2018 Keystone...
John Deere 6195R (A60462)
John Deere 6195R...
