Garden fence build
/ Garden fence build #141
I didn't know such a thing existed. That's really cool!
We're just using a gorilla cart which works fine. It's not the moving of the cart that's so much work, it's the shoveling from the dirt pile into the cart (screening as we go to get rid of rocks and large sticks), then shoveling back into the beds.
The gorilla carts do have a dump feature, but the height doesn't work out with 12" tall beds. I'll be looking at that some more today though.
Given flat ground, perhaps a modified gorilla cart would work well - give it a body lift so you can dump into the bed!
@EddieWalker how do you support your tomatoes?
I was not informed ahead of time that'd I'd have to build accessories for the garden. Had to figure out a way to support netting to protect broccoli and the like from cabbage worms(?) -- see attached rebar + 1/2" sched40 pvc -- and apparently I need to build something to support tomato plants.
Going to go with a 3d wood grid that is freestanding. I believe I have enough scrap wood for half of it..will have to go buy some more lumber to finish it.
Of course I just cleaned up the shop yesterday. Re-stacked all the scrap wood, swept and blew out all the sawdust and put up the saws after making a stool out of scrap cedar 8x8s to go with the tables for the garden.
/ Garden fence build #143
For tomatoes I built a frame from #3 rebar - about 6 1/2' tall legs (3 legs per 20' piece) - I think the frame is the next size up rebar (#4):
I like using rebar in the garden because it pretty much disappears when you take a few steps back, plus it's cheap and easy to get.
/ Garden fence build #144
We have a gazilion tomato cages. Most where bought used for a buck each, but there are dozens of the colored ones that are twice as thick.
This year she wants to use the cattle panels at an angle for tomatoes to grow into. We've never done this, so it's going to be interesting.
Here is a video of her tying grow bags for the first time. She's putting top soil and compost into the bags with potato starts.
/ Garden fence build #145
From what I've seen, I wouldn't use cattle panels. The tomatoes don't "vine" themselves; they will drape over tomato cages but they don't have tendrils like pole beans or grapes so they don't climb panels. I suppose with the panel at an angle the plant may drape into the holes?
Instead, to get tomatoes to go up and for max production, you trim some of the lower branches, and you tie or tape or velcro them to the support - which can be as simple as a bit of twine hanging from above. That's why we set up those rebar things, so there's something up there that you can hang lots of twine down.
We've used cattle panels for peas - they do readily climb with their tendrils, but it's kinda a pain because even with the big holes it's tough to reach through and pick peas on the other side because they end up hidden.
I agree rebar blends in well. I'm guessing these are welded together? Hrm, something I still have to learn how to do.
I don't understand all the details with tomatoes, but I believe our desire it to avoid having to tie the plants to anything. We'll see how the whole-bed tomato cage thing works out. I spent yesterday cutting down 2x6s into 2x2s and 1x2s. Will start screwing it together today, though I realized last night that at its finished width(38") it won't fit through the garden door, so I guess I'll be assembling on-site.
/ Garden fence build #147
We have over 100 tomato plants, so the cages work for us, but we still need more every year.
Our long-term goal is to double the size of the garden and also have a lot more tomato plants. I'm sure that we'll be buying more tomato cages too!!
The cattle panel idea is still in the thinking stage. It's something she learned about from one of her Master Gardener classes. Some of their ideas have been really good, so I'm hopeful this will turn out well when I get around to doing it. With storms expected for the next 5 days, it will have to wait another week.
/ Garden fence build #148
I have a small mig unit and use flux core (120v). It's messy and I only occasionally do it so I'm not great at it, but I've built 5 large (7.5x12') and two small (7.5x3') gates for my property fence that came out great and would've cost a ton more if I didn't make them, because they're made to match my fence pattern exactly, so it's honestly not that tough to do a decent job (seriously this isn't a humblebrag - doing it 'well enough' isn't hard, and joe homeowner doesn't need to be a $100/hr welder). It's basically hot glue, just... really hot.
The tomato tying thing is just to maximize yield and encourage them to grow higher than they would otherwise. They do fine with a normal cage and it's less effort, though don't think you won't be working the tomato plant arms to get to the right spot in the cage for a good hang... and then occasionally the cage starts tipping. There's always something to do, whatever method you use ;)
I need to buy more 1x2s tomorrow to finish it, but here's the wood 'matrix' idea I'm going with for our one tomato bed:
It's a 3x8 bed and we'll do one plant every square foot. So I'll run two more 1x2s the length of each level to split it into three on the long end, then staple 1x1s running perpindicular every 12" in the other direction.
The total height is 66" above the dirt, with each 'level' spaced 18" apart.
A complicated solution, but blends well with the beds themselves and gets a lot of scrap lumber out of my shop which I'm happy about!
/ Garden fence build #150
Bought some cone shaped metal tomato cages years ago that are still my favorites. They used to make them out of heavier wire. The ones today are so thin that they will bend over in a strong wind if you have a full grown tomato plant inside of them.
I'd like to find some made of wire about the same gauge used in cattle panels. IMPO, cattle panels do very well for growing certain types of beans that need something to climb onto, but not so well for tomatos.
This has been our problem - we have a handful of cages but they're so lightly built they start falling over, and also a few of the welds have broken.
Had a break in the series of stormy days (though man is it oppressively hot and humid!) so got a chance to finish the tomato trellis. Took $40 in cedar 1x3s to finish it out, the rest was scrap from previous projects.
We'll see how the wood holds up over time but it seems strong and stable enough, especially once we fill the bed with dirt.
Really hoping this is the last construction project for the garden this year.
/ Garden fence build #154
Did you screw the trellis together? I'm wondering if wrapping it together with wire would work better?
/ Garden fence build #155
Can you pull the trellis out of the box at all, or are you expecting to leave it there kinda forever?
It's free-standing so we can pull it out for the winter or move it to another bed if we want to rotate in a given year.
It's a mix of screws and crown staples:
  • The "frame" 1x2s (what you see assembled that I posted a few days ago) are screwed into the 2x2 legs with 2" screws.
  • The "interior" 1x2s (two at each level) are screwed to the short-side frame rails from below using 3" screws.
  • The 1x1s are attached to all 4 1x2s using 1 1/4" crown staples
I pre-drilled all holes (including counter-sinks) to avoid risk of splitting since it's thin cedar. Nothing split so I guess that worked, but probably should have used a thinner bit.
Most of the force on it should be gravity/the weight of the plants which led to the arrangement - everything is supported from below other than the frame rails on the short sides. 24 2-inch screws ultimately hold it all up.
Why do you think wire may have worked better? Lashing being more secure with smaller pieces?
/ Garden fence build #157
From what I've seen, wood seems to wear out around screws and then it all gets wobbly. I haven't done this; it's just an idea that hit me while looking at your pictures. If the wood was wrapped together with wire, it wouldn't get loose as it breaks down from being exposed to the elements.
Huh, makes sense. Part of why I wish I'd used a smaller bit when pre-drilling for a snugger fit.
On the upside, I can always go back and wrap/lash the joints if things start getting wobbly.
/ Garden fence build #159
Back the screw out and put a short piece of a zip-tie in the hole then the screw and tighten it.
/ Garden fence build #160
Ha! And you thought you were through? There is no end.
I suppose however, that that's part of the pleasure for you both. Keep the faith - rewards are forthcoming.
