I keep breaking 1/2 ratchets on my lug nuts.
/ I keep breaking 1/2 ratchets on my lug nuts. #41
I like the SK triple tooth contact Pro ratchets, they have held up. For stuck lug nuts and a few stubborn axle nuts, I try with a 3/4 set up, then bought a 1" advertised 4280 ft lb. air Impact for when that fails and so far it has worked but I need to add a reserve air tank with large lines to make it work at full power. Supposed to have 175 psi and 1/2" air lines.
In reality, 135 PSI works just fine so long as you have sufficient CFM. Nice thing about running ANY compressor at 135 versus 175 is, the compressor will last a Lot longer, make less condensate (which ruins air tools). I run 135 for all my stuff but I use high flow couplers as well as large diameter air hoses. The higher the static pressure is, the less time the compressor will last and mine are large as well as expensive. I have over 35 CFM available at 135 psi which is more than adequate for any air tool or impact wrench. Both my compressors cost me over 8 grand. I usually only run one but if the plasma table is running production parts, I run both at the same time. One is a Quincy pressure lubed unit and the other is a Sullaire screw compressor. Both are 220-3 btw. I could run them both on 480 if I wanted to but the only advantage to 480-1 versus 220-3 in how fast they spin the meter.
We use a lot of air in the shop, every day. Both have automatic timed drains on them and the screw unit has a built in refrigerated dryer but I still use Motor Guard cannister filters on the inlet of the plasma cutters as any moisture in the supply line air is death on consumables.
Far as Cracksman tools are concerned, the old stuff was good, the new stuff is on par with Harbor Freight's Pittsburg line, IOW, Chicom junk. Used to have a lot of SK-Dresser tools but over the years they have either failed or sockets gave out so not many anymore. Mostly either Snap On or MAC or the Harbor Freight premium line (ICON). Problem with SK is getting them replaced if broken. Same with Snap-On and MAC but never an issue with HF Icon. I break them and take them back and they give me a new one. One time I broke an Icon impact socket and took it back and they didn't have one to replace it, so they gave me a complete set instead.
/ I keep breaking 1/2 ratchets on my lug nuts. #42
Sad to see even the SK Pro line is now made in China as well. still charging close to $100 for a 1/2" rachet though.
I have thought about lowering the pressure down on the compressor pump cut out, but the impact and the bead breaker on the tire changer sometimes need that extra bit sometimes it seems.
/ I keep breaking 1/2 ratchets on my lug nuts. #43
You are imagining that. Cut it to 135 psi but switch to high flow couplers and large inside diameter air hoses. Even my large IR 1" drive impact runs fine on 135 psi. Keep them well oiled as well. I use IR air tool oil in the pint squeeze bottle and it sits where my employees can get it easily as well.
In reality, all 175 psi does is build carbon on the reed valves quickly and then they need cleaned or replaced and the receivers run hot and that causes even more condensation. I run a 100 gallon receiver on the Quincy and an additional 250 gallon vertical receiver in the corner of the shop. The screw has a 75 gallon horizontal receiver under the mechanical stuff, built in.
/ I keep breaking 1/2 ratchets on my lug nuts. #44
Of course.
The next question though is, has anybody calibrated their torque wrench?
Actually if you do a real research torque wrench "calibration" is sort of myth as most are within reasonable limits to be accurate enough for just about everything but space agency devices.... Was a few good youtube videos a while back showing several different wrenches in differing conditions and error factor was almost negable....
/ I keep breaking 1/2 ratchets on my lug nuts. #45
I suspect the prices on the made in China tools will go up quite a bit to cover the tariff's. Quality will remain the same however...lol
/ I keep breaking 1/2 ratchets on my lug nuts. #46
Just to make sure it is clear, a Torque Wrench is not the same thing as a Torque Multiplier.
A Torque Wrench is used to make sure that a bolt is as tight as you are supposed to have it, and a Torque Multiplier is used to loosen nuts and bolts that are too tight to get loose without breaking your ratchet or having to use an extension to increase the force. A Torque Multiplier uses a planetary gear system to use a smaller force to increase the torque to loosen a nut.
David from jax
If that is so why do torque multipliers state in instruction how to apply torque (with a torque wrench) above and beyond the rated value of a torquench to tighten nuts and bolts....?
/ I keep breaking 1/2 ratchets on my lug nuts. #47
Probably correct in as much as I own a torque master and every time I check them, they are always close to spec. Problem that most people don't quite understand is, if you put an extension on a torque wrench or you don't apply it at 90 degrees to the fastener you are torquing, the value of the torque applied changes. Then there is the wet thread versus dry thread issue as well.
/ I keep breaking 1/2 ratchets on my lug nuts. #49
What I found to be interesting is that the Icon wrenches are just as good and sometimes better than the high buck Snap-On or MAC wrenches. Now when it comes to small torque values, I use a Snap-On 1/4" drive dial torque wrench. Not cheap by a long shot.
/ I keep breaking 1/2 ratchets on my lug nuts. #50
And another thought, how may people are really conscientious about the few drops of oil in air tool every once in a while.....
Probably not many but it's a good habit to get into and why I have a couple bottles of IR air tool oil sitting about the shop. Not just any oil either but specifically formulated air tool oil. Those fast rotating carbon vanes in the motor like to be lubricated, often.
/ I keep breaking 1/2 ratchets on my lug nuts. #51
Depends I guess but there is also (other than mechanical torque multiplier) as torque wrench extension.... Are we talking a bar or socket extension...
/ I keep breaking 1/2 ratchets on my lug nuts. #52
I may actually do that 5030, It really does sound like a good idea. I do need to put up some legitimate decent sized air line piping.
/ I keep breaking 1/2 ratchets on my lug nuts. #53
I'd be interested in seeing that, as I worked in an industry where our wrenches had to be re-calibrated every year, and many were found to require re-adjustment. I have also personally taken brand new torque wrenches purchased without NIST certs out of the box, tested them myself, and found them off by as much as 20%.
As someone posted previously, the beam type is always accurate, if not damaged, and a good method for checking your clickers. But clickers tend to be all over the place, depending on how they're handled and who calibrated them at the factory.
/ I keep breaking 1/2 ratchets on my lug nuts. #55
Not just any old plastic pipe, use only air line certified plastic or steel.....
Yeah, I don't need any PVC shrapnel bombs in my garage.
/ I keep breaking 1/2 ratchets on my lug nuts. #56
Or
/ I keep breaking 1/2 ratchets on my lug nuts. #57
Like 5030 said, very few people read the instructions!! I haven't!!
I do understand the mechanics of a Torque Multiplier, and it would increase the torque going to the nut or bolt. That number can be calculated, but I wouldn't trust it.
David from jax
/ I keep breaking 1/2 ratchets on my lug nuts. #58
Years ago when I first built the shop, I ran all my air lines prior to setting any machinery, I had my steel supplier deliver a bundle of 2" mill lengths 21 foot) black iron pipe and I bought all the fittings from Grainger. I own a Rigid pipe threading machine so I cut the pipe to the required lengths and threaded it for the required fittings. They also delivered a couple mill lengths of 1" black for the drops and they terminate in ball valves with a condensate drain on each drop as well. I had to do that as I have employees and liability could be an issue with anything else though I do believe you could use schedule 60 plastic pipe with solvent welded joints. It wasn't a cheap date even 20 years ago, but it will far outlast me. The compressors and receivers are flex lined (for vibration purposes to the hard lines) and I sloped all the hard lines away from the compressors and receivers toward the drops so I could drain out any condensate that might collect in the piping. Like I said, over 20 years ago and zero issues. If it was a personal shop and not a commercial shop, I probably would have plumbed it in schedule 60 plastic, but again, because I have employees, liability was a concern so I did it like I did it. I see you can get flexible air line now that utilizes compression fittings. None of that was available 20 plus years ago. I've seen pictures of exploding air lines under pressure as well as exploding compressor tanks that weren't regularly drained and they weren't pretty. My Quincy as well as the Sullaire both have timed electric condensate drains on them. Bought the drains from Suburban Manufacturing but I see Compressors Direct have them as well. I also see Amazon has them listed and I presume they are Chinese. I wanted a domestically made condensate drain so I went with Suburban and after 20+ years they work flawlessly. Receivers stay dry all the time and the condensate drain hoses exit through the shop wall out to the grass beside the shop. keeps the grass watered...lol Like I said previously, 135 psi static pressure all the time. 175 psi is way overkill so long as you have adequate CFM.
/ I keep breaking 1/2 ratchets on my lug nuts. #59
I worked for a company for a brief time back in the mid 70's and ran a lot of pipe in a new shop that a power company was building. I dropped by there last year, and those pipes were still there for the most part. Some modifications as could be expected, but still handling the huge volume of air from the dual screw compressors.
David from jax
2012 INTERNATIONAL 4300 4X2 26FT NON CDL BOX TRUCK (A59908)
2012 INTERNATIONAL...
2013 FORD F350 SUPER DUTY 4x4 CREW CAB PICKUP TRUCK (A59909)
2013 FORD F350...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
2023 Global Trailer (A61568)
2023 Global...
2025 Pabreak 6-Way 84in. Serrated Hydraulic Dozer Blade Skid Steer Attachment (A61567)
2025 Pabreak 6-Way...
Toro Workman HDX-D Utility Cart (A61567)
Toro Workman HDX-D...
