What can I spray in the woods to control unwanted growth but not harm trees?
/ What can I spray in the woods to control unwanted growth but not harm trees? #1
JeepHead
The hills of Southern Indiana
Kubota 2502H, HSI Pinnacle grapple, LP 48" forks, LP 60" BB, KK tiller 60", KK middle buster, Pat's QH
So my woods was partially logged right before we purchased the property 19 months ago. The woods is absolutely invested with briars, weeds, and saplings. Is there anything I can spray on this that will help control that overgrowth but not harm the trees? It’s a large area so I would want to setup my ATV or tractor with a spray and tank spraying large area at a time, not walk around with a handheld prayer doing pinpoint sprays.
/ What can I spray in the woods to control unwanted growth but not harm trees? #2
With clear cutting, it's normal for the forest to grow back brushy with briars, then the trees take over and there are fewer briars—but it takes 10 years before the forest returns. If a select cut was done there should be fewer briars and weeds.
Anything that kills the brush will also kill other trees - best would be to grind it up or bush hog if its accessible, or a small flail mower with the brush knives.
/ What can I spray in the woods to control unwanted growth but not harm trees? #3
Just about anything with 2,4-D in it will work. In most places it's controlled, but you can buy it in one quart bottles without needing a license.
The trick is in the timing of when you spray. You want the weeds to be actively growing because that's when they are drawing the most nutrients into their growth. I've been told that it takes five years of spraying every Spring to get rid of everything. I've done it once and had good results, but then I keep the area mowed and that helps a lot too.
My wife is a Master Gardener and they don't like using chemicals if there are other methods that work. Their number one way to control weeds in a paster is regular mowing. I've found that it works too, but it takes longer to get there.
I had to buy a 70 hp cab tractor and 12 foot batwing to maintain my place. Before I was using a 37 hp open station tractor with a 6 foot cutter, and it was too slow to get it all done. The heat also kept me from mowing when I should of, but there is a limit to how much I'm willing to suffer just to mow a pasture. Now with the cab, I can mow during the worse heat of the day, and with the bigger cutter, I can get a lot more done in less time.
/ What can I spray in the woods to control unwanted growth but not harm trees? #4
What is your planned use of these "woods"? Size? Wildlife LOVE "briars, weeds and saplings".
Do you have garlic mustard? I fought that every year. It's invasive and will take over everywhere. Hand pull (and bag/remove) or spray herbicide.
2-4-D or glyphosate will setback or kill most weeds. Briars or saplings can be cut/mowed - then sprayed with strong glyphosate when they sprout back. Tordon kills better, but will stunt/kill the surrounding trees.
Call out your State Biologist for a (free) walk around and advice. I did that when I first got my Indiana hunting land.
/ What can I spray in the woods to control unwanted growth but not harm trees? #5
Another thing that I did that surprised me was getting goats. I had blackberries all over the place and spraying them didn't have any success. The worse area was next to my small pond. I could only mow so close to the edge, and the blackberries just got bigger every year. The areas I mowed, the blackberries just spread wider and chocked out the grass.
The goats ate the blackberries to the point that there is no sign of them ever existing. I knew that they ate a lot of things, but those blackberries where full of thorns and the goats ate them like candy!!!!!
/ What can I spray in the woods to control unwanted growth but not harm trees? #6
I am in a very dense and overgrown forested area that I have been slowly pushing the underbrush back from around the house and areas I have been opening up for various uses. What has been working for me is to mix glyphosate (2.5oz/gallon) and Triclopyr (remedy ultra 1.5oz/gallon) in a backpack sprayer and applying to the actively growing leaves around all the larger trees being left in place. Spraying 2 or 3 times during the spring and summer will kill most of the underbrush and then allow complete clearing with a blade on my weed eater and anvil clippers for the heavier dead stuff. Then any new regrowth the next spring are easily knocked down with another application. I try to be careful and not spray on the bark of the trees I am keeping and so far there has been no problems with any of those trees.
Hunting is my ultimate use. But I am not wanting to spray and kill off everything around the woods. I have a lot of trails going all over the woods and just want to keep the trail sides knocked back enough to navigate without being bombarded with everything. The misses likes to walk the trails and doesn't want all of that junk on her. Thanks for the info, I will look into that!
Yeah, I have been through this once before with my last property. It takes awhile for sure. It will get so thick you can barely even walk through, but the animals will flock to it...
/ What can I spray in the woods to control unwanted growth but not harm trees? #9
Yes - we had a farm in PA that had about 20 acres of neighboring woods clear cut - for the next 5-8 years in deer season we would walk the thicket and usually drove 4-6 deer into the fields as they like the thickets.
/ What can I spray in the woods to control unwanted growth but not harm trees? #10
IMO, you don't want to spray heavily and don't spray the trees you want to keep. The herbicides that are effective against woody plants are not good for your trees.
2006 Dodge Ram Pickup (A56858)
2006 Dodge Ram...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
2023 John Deere 333G for Parts (A61306)
2023 John Deere...
2018 Bobcat T650 (A60462)
2018 Bobcat T650...
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
John Deere 12in Channel Tooth Bucket Excavator Attachment (A60352)
John Deere 12in...
