TX25H tractor and loader
TX25H Tractor & Loader $19,999
Atwoods • Family Farm & Home
Farm & Home Supply • The Home Depot
Runnings • Tractor Supply
Find Your Nearby Retailer
TX25H tractor and loader with backhoe
TX25H Tractor & Loader w/Backhoe $27,999
Ad top of page
Why Only 48" Rotary Cutter
/ Why Only 48" Rotary Cutter #1
AllanB4U
None yet
I was curious why Summit doesn't offer a 60" rotary cutter?
/ Why Only 48" Rotary Cutter #2
Yep, me too.
It seems the tractor should have enough power to run a 60" mower under normal situations. Curious also about this.
/ Why Only 48" Rotary Cutter #3
Interesting, no reply to this from other users or the company.
/ Why Only 48" Rotary Cutter #4
Perhaps they are aware of a weakness in the drivetrain to the PTO that they fear anyone using a larger mower may exceed. If you use larger aftermarket implements, not sold by Summit, maybe you void any warranty?
/ Why Only 48" Rotary Cutter #5
Who knows?
It could be. It would be good to see some response. My own thoughts are that whatever attachment I am using better at least cover the wheel tracks. I know there are scenarios that doesn't apply. I am primarily talking about mowers of some sort.
/ Why Only 48" Rotary Cutter #6
Who knows?
Good question on the RC size. For a 24.7, 18 PTO tractor, a 48" or 54" rotary cutter in the right choice. As much as working width, the density of the brush being cut factors in as well. While a 60" cutter will work ok in some conditions, it will not work well in all conditions, so we recommend 54" max.
/ Why Only 48" Rotary Cutter #7
That's what I was hoping to see :). A response.
I agree completely with the opinion expressed above.
Cutting conditions (material being cut, moisture level of the material and ground conditions) are as important as the width of the unit. As a company, I would think they will err towards usability and profitability as opposed to trying to bump to a bigger unit. As a consumer, I also have the responsibility of buying and using the right equipment. If I buy an unsuitable item for my tractor and it doesn't work as advertised, it is on me. No foul by the company at all. I don't have a Summit yet but planning to soon. As a long time owner and user of tractors, I am also sure I will opt for a 60" bush hog type mower for my waterways and field borders. No trees or brush to worry about, just grass and weeds.
I do appreciate honest input from the supplier. And i will also do my due diligence and make a decision that works for me and feel pretty good about it. And let's be real here, it is only 6-12 inches more than recommended. Not like I am trying to sneak an 8-10 foot mower behind it.
As a long time consumer of equipment, replies or responses and acknowledgment of the consumer is important. Not every contact means a sale but in the age of the interweb, word does get around if they blow off those who buy their products.
/ Why Only 48" Rotary Cutter #8
I have a Summit FMX60 Finishing Mower (a KingKutter RFM60 painted green) and a Dirt Dog RC100 48" Rotary Cutter. IMO using a 60" rotary cutter is pushing the limits of the tractor if you are cutting woody brush and saplings. I recall watching a YouTube video with the Summit tractor owner using both a 48" and 60" rotary cutter on the same high grass/hay field and his opinion was the 60" cutter was straining the tractor.
2022 CATERPILLAR 259D3 SKID STEER (A65056)
2022 CATERPILLAR...
Unused 2021 Unused Paladin MD60SC 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2021 Unused...
2022 INTERNATIONAL MV607 S/A 26FT NON CDL BOX TRUCK (A69167)
2022 INTERNATIONAL...
2013 MITSUBISHI FE 4X2 S/A 20FT BOX TRUCK (A69167)
2013 MITSUBISHI FE...
2017 Ford Explorer SUV (A66738)
2017 Ford Explorer...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A68842)
GENERAC MOBILE...
Ad bottom of page
