TX25H tractor and loader
TX25H Tractor & Loader $19,999
Atwoods • Family Farm & Home
Farm & Home Supply • The Home Depot
Runnings • Tractor Supply
Find Your Nearby Retailer
TX25H tractor and loader with backhoe
TX25H Tractor & Loader w/Backhoe $27,999
Ad top of page
Why Only 48" Rotary Cutter
/ Why Only 48" Rotary Cutter #1
AllanB4U
None yet
I was curious why Summit doesn't offer a 60" rotary cutter?
/ Why Only 48" Rotary Cutter #2
Yep, me too.
It seems the tractor should have enough power to run a 60" mower under normal situations. Curious also about this.
/ Why Only 48" Rotary Cutter #3
Interesting, no reply to this from other users or the company.
/ Why Only 48" Rotary Cutter #4
Perhaps they are aware of a weakness in the drivetrain to the PTO that they fear anyone using a larger mower may exceed. If you use larger aftermarket implements, not sold by Summit, maybe you void any warranty?
/ Why Only 48" Rotary Cutter #5
Who knows?
It could be. It would be good to see some response. My own thoughts are that whatever attachment I am using better at least cover the wheel tracks. I know there are scenarios that doesn't apply. I am primarily talking about mowers of some sort.
/ Why Only 48" Rotary Cutter #6
Who knows?
Good question on the RC size. For a 24.7, 18 PTO tractor, a 48" or 54" rotary cutter in the right choice. As much as working width, the density of the brush being cut factors in as well. While a 60" cutter will work ok in some conditions, it will not work well in all conditions, so we recommend 54" max.
/ Why Only 48" Rotary Cutter #7
That's what I was hoping to see :). A response.
I agree completely with the opinion expressed above.
Cutting conditions (material being cut, moisture level of the material and ground conditions) are as important as the width of the unit. As a company, I would think they will err towards usability and profitability as opposed to trying to bump to a bigger unit. As a consumer, I also have the responsibility of buying and using the right equipment. If I buy an unsuitable item for my tractor and it doesn't work as advertised, it is on me. No foul by the company at all. I don't have a Summit yet but planning to soon. As a long time owner and user of tractors, I am also sure I will opt for a 60" bush hog type mower for my waterways and field borders. No trees or brush to worry about, just grass and weeds.
I do appreciate honest input from the supplier. And i will also do my due diligence and make a decision that works for me and feel pretty good about it. And let's be real here, it is only 6-12 inches more than recommended. Not like I am trying to sneak an 8-10 foot mower behind it.
As a long time consumer of equipment, replies or responses and acknowledgment of the consumer is important. Not every contact means a sale but in the age of the interweb, word does get around if they blow off those who buy their products.
/ Why Only 48" Rotary Cutter #8
I have a Summit FMX60 Finishing Mower (a KingKutter RFM60 painted green) and a Dirt Dog RC100 48" Rotary Cutter. IMO using a 60" rotary cutter is pushing the limits of the tractor if you are cutting woody brush and saplings. I recall watching a YouTube video with the Summit tractor owner using both a 48" and 60" rotary cutter on the same high grass/hay field and his opinion was the 60" cutter was straining the tractor.
Ad bottom of page
