walhondingMF
- Joined
- Mar 30, 2022
- Messages
- 795
- Tractor
- 2012 MF2400
That's exactly what it is. It is a first gen 562 but looks like the same part. Thank you. Its been frustrating me.
Yep I checked 12 year old IPL just now too and same.That's exactly what it is. It is a first gen 562 but looks like the same part. Thank you. Its been frustrating me.
I'd try it myself.It almost looks like something I could make. I've got a bunch of foam similar to it. May try that first.
Next question...I'd try it myself.
Like said just to limit travel.
Tiny getting some more limbing time done. 12" under work. Echo 2511PN with Egan pipe for 28% gains over stock.
I honestly dont think I will ever be without the little rear handle one now.![]()
Plus have a TH version too. But the rear handle one is getting all the use now. Just cats meow for light use.
View attachment 3199360View attachment 3199361
I have never had to replace one. But sure looks like it just pushes over.Next question...
How do I replace the thing? I just pulled the old one off because it was brittle but is the pin supposed to pull out? Do I just stretch the new one over top?
Ya my wife wants me to teach her on this one. I really think she can start this one on her own.They are such a great saw for the small stuff. They are so small and light that you can really make quick work of stuff.
Great. Thats what the foam I have looks like. Should be pretty simple to do. Thank youI have never had to replace one. But sure looks like it just pushes over.
This one guy said he made one from high impact foam.
New tank to show limiter areaGreat. Thats what the foam I have looks like. Should be pretty simple to do. Thank you
Why I searched it and showed you. Just slips over.Doesn't look like that pin or the end of that post removes at all.
The antivibration on this saw is pretty good in my opinion but it does seem to have a good bit of "travel" to it, even with the foam intact. I may experiment with some other materials just to see if I notice anything different.Why I searched it and showed you. Just slips over.
Basically the pin is the limiter and the rest to make it easier on case. Buffer deflector. JMO
Many older husky the limiter is just metal.
