PTO problems
/ PTO problems #1
Muley Gil
Member
'49 Ford 8N
Let's try again. My friend's newish JD 1025 is having a PTO problem. There are three positions available. All the way forward is 540, middle is 2100 & 540 and the rearmost position is 2100. When in the rearmost position, the PTO shaft is not spinning.
Thoughts/comments?
/ PTO problems
Back to the top with better info.
/ PTO problems #4
Does the mid PTO spin in the middle when both shafts should be turning?
/ PTO problems
I'll have to check with my buddy. Presently, he has the PTO cover off, trying to figure out the problem.
/ PTO problems #6
If checking, verify the PTO,s are working correctly in the other two lever positions. I.e. rear 540 only and both 540 & 2100 in mid position.
That should provide some information on if the shift linkage is operational for PTO selection
/ PTO problems
That should provide some information on if the shift linkage is operational for PTO selection. The PTO works in those two positions.
/ PTO problems #8
Is this newish enough to still be under warranty? If yes I would get the dealer involved before tearing anything apart.
If not under warranty I would look very closely at the shift lever and all the linkage to see if something is preventing it from moving fully and engaging the mid PTO only. I.e. a stick, mud, grass, etc. possibly preventing full movement.
/ PTO problems
Well, my buddy took the PTO apart & everything looked good inside. No chipped gears, nothing broken or out of place. He put it back together & the PTO works in the forward position, the mid position but not in the rear most position.
/ PTO problems #10
Did your buddy confirm the shifting fork movement to engage the different gears in all three positions? Sounds like a shift collar is not being moved properly to engage mid PTO only.
2002 POLAR TANK (A60736)
2002 POLAR TANK...
CATERPILLAR 108" WHEEL LOADER RAKE (A52707)
CATERPILLAR 108"...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
EZ loader trailer (A56857)
EZ loader trailer...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
Deere 333G (A60462)
Deere 333G (A60462)
