PTO problems
/ PTO problems #1
Muley Gil
Member
'49 Ford 8N
Let's try again. My friend's newish JD 1025 is having a PTO problem. There are three positions available. All the way forward is 540, middle is 2100 & 540 and the rearmost position is 2100. When in the rearmost position, the PTO shaft is not spinning.
Thoughts/comments?
/ PTO problems
Back to the top with better info.
/ PTO problems #4
Does the mid PTO spin in the middle when both shafts should be turning?
/ PTO problems
I'll have to check with my buddy. Presently, he has the PTO cover off, trying to figure out the problem.
/ PTO problems #6
If checking, verify the PTO,s are working correctly in the other two lever positions. I.e. rear 540 only and both 540 & 2100 in mid position.
That should provide some information on if the shift linkage is operational for PTO selection
/ PTO problems
That should provide some information on if the shift linkage is operational for PTO selection. The PTO works in those two positions.
/ PTO problems #8
Is this newish enough to still be under warranty? If yes I would get the dealer involved before tearing anything apart.
If not under warranty I would look very closely at the shift lever and all the linkage to see if something is preventing it from moving fully and engaging the mid PTO only. I.e. a stick, mud, grass, etc. possibly preventing full movement.
/ PTO problems
Well, my buddy took the PTO apart & everything looked good inside. No chipped gears, nothing broken or out of place. He put it back together & the PTO works in the forward position, the mid position but not in the rear most position.
/ PTO problems #10
Did your buddy confirm the shifting fork movement to engage the different gears in all three positions? Sounds like a shift collar is not being moved properly to engage mid PTO only.
CFG H15R (A60463)
CFG H15R (A60463)
2004 Freightliner FL70 Garbage Truck, VIN # 1FVABTCS64HM47795 (A61165)
2004 Freightliner...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2001 VERMEER E550 VACUUM (A60736)
2001 VERMEER E550...
Giyi GY-TB47 Forklift Telescopic Boom (A60463)
Giyi GY-TB47...
2022 Iron Bull 7' x 20' Trailer (A60462)
2022 Iron Bull 7'...
