2manyrocks
Super Member
- Joined
- Jul 28, 2007
- Messages
- 9,533
Every TBN member who either has or wants a 16hp or so chinese made mini-ex must be salivating at the sight of your cutter.Here is an hydraulic brush cutter I built for my backhoe a month or so ago. I suppose it fits the thread, since mostly about using chains. I do have a flail mower for the backhoe, which worked fairly well, but it's just an heavy attachment and I wanted something lighter.
Cutting width is about 50 cm or nearly 20". Using 3/8" grade 80 chains. Rotor speed is about 2000 RPM.
It has been painted since, I just haven't taken any pictures of it yet. Still need to test it properly but for that I need to haul the machine over to the remote propriety, however I still have digging work for the backhoe here at home.
I wouldn't have expected a 17hp backhoe to have enough power to run a cutter?
Could you explain the way you've oriented the skid shoes perpendicular to the tractor? They also appear to be very wide compared to most brush cutters I've seen.
Your fabrication work is astounding.
