A better boot dryer?
/ A better boot dryer? #1
ArlyA
Super Star Member
Houghton MI (the Lake Superior snow belt) USA
Outlander1000 6x6, Ego lawn mower and shopping for tractor
Our quality American made Peet boot dryer failed in 2 years. What dryer are you using that's held up? Need a replacement asap!
/ A better boot dryer? #4
I have 2 dryers, a 25 year old Peet and a 4 tube no name from Menards. Go to dryer is still the Peet as it is low and slow while one is noisy and fast which is bad.
I agree, I'd buy another Peet and get ahold of them and I bet they will refund or at least replace.
If you have bootSSS, (plural) to dry, 2 dryers is a good thing.
We already have 2 but the other is smaller and used for gloves. Both used each day.
/ A better boot dryer? #6
But we have boots to dry today. Its a daily thing here.
Simple answer... Park them over a heater vent....lol Interesting comment about your failed Peet. Not much to fail in them and ours is going on 15 years now with no issues. I did add a new on-off toggle switch however.
Peets warranty is rather worthless.
Register within 10 days​
To take advantage of our warranty, please register your PEET® Dryer within 10 days of purchase. If you require warranty service or need to use the 30-day money-back guarantee, follow the instructions below or, for more information, please contact PEET Customer Support or call 1-800-222-PEET (7338) to talk with a representative.
/ A better boot dryer? #8
Not much inside of one anyway. Just a short Nichrome wire for heat and an on-off switch. Nothing to really break except for a few connections. Never looked at the warranty candidly. Nothing I could not repair in a few minutes anyway.
The timer flailed, then whole board quit. If you dig and dig through their web page, you can find its actually 25 years warranty. I called them, then emailed them amazon screen shot of the purchase. I solder the wires in the unit after removing the control box. Do have an operable unit again.
/ A better boot dryer? #11
You must have a much more expensive unit than we have... Ours just has a simple on-of toggle switch.
Far as drying boots and shoes however, your best bet is still a floor register and it has an added benefit...
As it dries them, it imparts moisture in the air and in the wintertime, moisture in the air is a good thing. Keeps wood from drying out, no static electricity sparks from your fingers and if your ambient moisture content inside is above 50%, you can turn the heat down and not feel cold.
We keep our abode at 55-60% RH all the time. We have 2 large Honeywell evaporative humidifiers in the house that run all winter. Amazing when you have humidity, no crusty noses either.
From amazonie today
You have received a message from the Amazon Seller - NetRush​
Order ID: 113-0961142-003343​
B09M4BNCRC
PEET, Advantage Plus 4-Shoe Electric Shoe and Boot Dryer with Fan & Heat Settings, Made in the USA, Black​
B09M4BNCRC​
Count: 1​
