Traded in the TV450 and got the TV620B home today. Only played with it enough to dial in the speed settings on the lift, curl, dump, track speed and pushed a bit into a gravel pile. First impression is this thing is a beast when it comes to pushing and lift capacity. It picks up my 84" CID cutter like it's not even there. I've got a good size gravel pile in the lot that my TV450 could push into but wouldn't move it. The 620 pushed into and moved the entire pile with ease. This thing is even heavier than the case spec sheet lists. I scaled my truck and trailer empty and on the way home after picking up the 620. Loaded with fuel it scaled out at 16,860. I'm looking forward to getting some work in with the cutter as well as a danuser intimidator I have ordered for pulling and digging trees/stumps. I'll post some updates and thoughts on the machine as I get some work in clearing some overgrown timber on our property. Will be interesting to see how it does on hills due to the weight of this machine and if it slows down much over my 450.
