She's a little on the heavy side - TV620B
/ She's a little on the heavy side - TV620B #1
jk96
Elite Member
Missouri
Kubota L6060
Traded in the TV450 and got the TV620B home today. Only played with it enough to dial in the speed settings on the lift, curl, dump, track speed and pushed a bit into a gravel pile. First impression is this thing is a beast when it comes to pushing and lift capacity. It picks up my 84" CID cutter like it's not even there. I've got a good size gravel pile in the lot that my TV450 could push into but wouldn't move it. The 620 pushed into and moved the entire pile with ease. This thing is even heavier than the case spec sheet lists. I scaled my truck and trailer empty and on the way home after picking up the 620. Loaded with fuel it scaled out at 16,860. I'm looking forward to getting some work in with the cutter as well as a danuser intimidator I have ordered for pulling and digging trees/stumps. I'll post some updates and thoughts on the machine as I get some work in clearing some overgrown timber on our property. Will be interesting to see how it does on hills due to the weight of this machine and if it slows down much over my 450.
/ She's a little on the heavy side - TV620B #3
Do you have 10k or 12k axles on your trailer?
/ She's a little on the heavy side - TV620B #5
7K. Makes those axles flex under a heavy load and gives me a smoother ride. Those HD axles ride too rough.
Your brave enough to load a 7k axle to near 12k?
Before everyone takes me serious and we start the not safe or legal posts they are 14k. 10k or 12k wouldn't give me enough capacity to add my cutter if working offsite. Door decal with my company name and DOT# in the last pic is whited out for privacy and location. Truck is 6.7 HO with Aisen and 4:10 gears so my truck axels, GWR, GCWR are all good. I am a class A CDL driver with insurance as well so all basis are covered. 4 point chains on the machine. Bucket was strapped. Took it off and decided to snap pics.
/ She's a little on the heavy side - TV620B #7
Looking at that trailer, I knew you were joking!! But I could hear you tell it with a straight face. LOL :LOL:😁
😆 was just waiting to see how long it took.
Now on to the machine. She is big. Here's me standing next to it. I'm 5'10".
They have added a step to the back side of the bucket and grab handle on top of the loader arm to help entry/exit. I'll see how long that grab handle lasts in the timber but its pretty solid.
Hose routing looks very good. Walkaround video showing hoses. All are very well protected.
What I didn't know when ordering and I blame my salesman for not asking is a second set of hydraulic couplers is an upgrade. Machine only has highflow couplers and a switch in cab switches between standard and high flow. Not a huge deal but will need to either get a set of coupler adapters for my grapple and snow plow or swap coupler size on those implements. Probably get the adapters though as I would need them if renting something as well. I'll followup with more when I start working it.
Mower deck storage axles
Mower deck storage...
2014 INTERNATIONAL PROSTAR+ (A60736)
2014 INTERNATIONAL...
2002 Allmand Night-Lite Pro Towable Light Tower (A56857)
2002 Allmand...
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
Index Boxes (A59317)
2014 Parker Trailer Sales Trailer (A60352)
2014 Parker...
