Lower Radiator Hose Block Heater
/ Lower Radiator Hose Block Heater #1
Brian (with an i)
NE Ohio
Mahindra emax 22 S
Sorry if this has been beaten to death but how effective are the lower radiator hose passive flow heaters? I am wanting to install a block heater kit on my emax 22s but not sure if the inline lower radiator hose type allows enough heat into the engine since it isn't pump driven like the circulating type. Is there an ideal location in the lower hose, like closer to the water pump or closer to the radiator? Does enough heat get into the engine to make it worthwhile? I know the freeze plug heater is probably better, but looking for something a little less invasive yet still effective. Any thoughts?
Thanks
/ Lower Radiator Hose Block Heater #2
I've had them on cars and they were very effective. You need to make sure when they are located so the heated water rises into the engine and not the radiator, but that's usually easy.
/ Lower Radiator Hose Block Heater #3
Hi Brian, my dealer installed the inline on my eMax 25s and it works fine. I usually give it 20 minutes minimum but try to hit 40 minutes. At that point the cab heater starts quickly and the engine is smoother. Mine has the Daedong engine and is a bit cold blooded....
/ Lower Radiator Hose Block Heater #4
I put one on the Mitsubishi engined Hurlimann. It works GREAT!
That 1.5 liter K4F-D engine is entirely cold blooded. With the lower hose heater, The engine starts straight off after about 1/2 hour on electric power.
Below about 32 f, I don't even consider starting the tractor without the heater .
This tractor has some sort of "auto-magic" pre-heater control that just doesn't seem to do the job/
Yeah I have the Daedong as well and like me, it doesn't like the cold very much either! Have you had the issue I read about where the heater heats the coolant up enough that the ECU won't turn on the glow plugs because the coolant temp sensor reads an already warm engine? Even though the engine is "warm", it still needs the direct cylinder heat from the GPs, I have read. I suppose you could manually cycle the glow plugs via left key turn and hold, but not sure if that overrides the ECU/temp sensor lockout.
Good to know it is working for you. Some folks say they've had no issues with cold starting (on the eMax 22) but mine is not a fan. I even replaced the glow plugs (which are all working) but unless I use both my 250watt heat lamps for 3-4 hours on the side of the block and under the oil pan and cycle the GPs half a dozen times, it really struggles to start below 32F. Fuel is good but she just hates being cold!
/ Lower Radiator Hose Block Heater #7
Yes, the long story short, I would crank it a bit without the glow plugs coming on, stop cranking for a bit, then the plugs would come on. I think what would happen is introduction of cold air and cold fuel introduced to the engine cooled it enough to trick the plugs to come on.
/ Lower Radiator Hose Block Heater #9
For starting, the important part to warm up is the HEAD.
Warmer water floats over cold, so a coolant hose is a great place to add heat to the head.
Ok, I will test that. I did install the heater (Kats #16400) in the lower radiator hose tonight. I did manage to get the tractor started and ran it to temp to settle any air bubbles and top off the coolant, so I can't see if the heater helps cold starting until tomorrow. I did notice that after it was up to temp, the ECU does lock out the glow plugs even in the key left-turn manual GP position. Just for giggles, I unplugged the harness on the coolant temp sensor and that allowed the glow plugs to cycle even with a warm engine. The point is, I think if it becomes an issue with the heater warming up the temp sensor but still needing that extra heat from the glow plugs, I may wire up a switch on the dash to disable the temp sensor so I can still cycle the glow plugs when needed. I'll see how it goes first with just the heater.
/ Lower Radiator Hose Block Heater #11
Sounds good Brian. Let us know the initial test results. By the way, where does the temp sensor connect? I should check my connection....
/ Lower Radiator Hose Block Heater #12
I've also used a heat gun to warm up the air going into the air filter/ intake. That is sort of a PIA but does work when the engine just needs to get going!
That's not a bad idea. A heat gun and a shot of starting fluid should get things going on those extra cold days.
On my 22, it's on the side of the thermostat housing at the front of the engine where the top radiator hose connects. I assume it's the same on the 25.
/ Lower Radiator Hose Block Heater #15
I use block heaters 24/7 on the diesel generators.
OEM was a inexpensive freeze plug heater that averaged 2-3 years.
I went to in-line and only replaced once in 7 years.
Hospital standby generators start full throttle and must transfer load within 10 seconds… everything bad for longevity.
Having the block at temp makes a world of difference even where temps seldom drop to freezing.
/ Lower Radiator Hose Block Heater #16
Sounds like a great opportunity to use "waste heat" from heat pump systems to provide "ecology points". ;-)
/ Lower Radiator Hose Block Heater #17
No heat pump systems here…
The exception would be new construction where all electric mandates exist.
Most homes/small offices here are not air conditioned and heat is natural gas.
At work we do have steam boilers but about as far away from the generators as possible… part of not having all critical infrastructure in one location…
Without the block heater the generators start just as quick but the governor hunts to achieve required speed…
Sounds good Brian. Let us know the initial test results...
Ok, with an ambient temp of 22F in the shed and engine block temp of 18ish (it got down to 13F last night), I ran the Kats 16400 heater for 1.25 hours this morning and it raised the block temp to 45-50F as measured just above the freeze plugs and 90-100F at the water pump and thermostat housing. Only negative thing was it did warm things up enough for the coolant sensor to tell the ECU to not run the glow plugs, and the tractor still didn't want to start with just the heater alone. So after cranking for way too long, I unplugged the temp sensor which allowed the ECU to power the glow plugs and I cycled them two times and the engine fired right up and ran smooth like it was all warmed up.
Before using the heater, it would not start, or not start very easily at all in these cold temps with the glow plugs alone, so the inline heater definitely made a difference. I will still probably wire up a switch to disable the signal from the coolant temp sensor when using the heater so I can still cycle the glow plugs, but the moral of the story is (for my cold-blooded emax 22 anyway) the Kats heater in conjunction with the glow plugs works great! I didn't try using a heat gun on the intake air as suggested but wiring in a bypass switch will be much simpler for me overall. Being new to the diesel SCUT world, I was skeptical this little 400 watt heater (actually measured at only 368 watts) would do the job, but it does. Next time I'll leave it on a little longer and see if it lets the tractor start without the glow plugs, but for now it's a keeper.
/ Lower Radiator Hose Block Heater #19
We have a 3616 that is about 7 or 8 yrs old. Glow plugs are a consumable and I changed out ours last winter after the tractor got harder to start. Disconnect the buss across the top of the glow plugs and measure the resistance between the top of the glow plug and the block. There should be some. Very high means the glow plug is done. They weren’t that expensive.
/ Lower Radiator Hose Block Heater #20
I've had both frost plug and lower rad hose heaters. Both have similar life spans. Both work effectively. Depending on access to the port the frost plug might be a little easier to install.
On the minus side rad hoses get brittle over time and the frost plug ones corrode. None of us are getting any younger either so pick whichever one appeals to you or is easier to install.
