Does anyone have an easy way to remove snow from equipment after use
   / Does anyone have an easy way to remove snow from equipment after use #21
one thing that helps is the snow not sticking to begin with, each fall before the snow starts to fly i will polish the backblade and bucket with an inexpensive car polish, if i end up plowing a lot sometimes i will reapply.
I do also this on my walk behind blowers, and sometimes the plow blades. A great product that is very easy to use is "Protect All". Use on paint, glass, plastic, rubber... What you don't wipe off dries clear.
   / Does anyone have an easy way to remove snow from equipment after use #22
I use my heated garage to remove the snow.
In all seriousness, Is the melted lake of water in your garage creating an issue? Does it migrate over to things you don’t want sitting in water?
When I built my shop I didn’t want floor drains for a few reasons. I opted to put a 2% slope on the floor. Any water easily migrates towards my garage doors. If it’s more water than what will naturally evaporate off the floor, sometimes I’ll use a floor squeegee to slick it out the door.
Since adding a floor drain or re-sloping your floor is likely out of the question, my mind goes to some sort of containment boom like the link below, or one of car containment mats like car detailers use catch water on the floor (second link below)….to keep the water under your tractor and not getting into your other stuff.
   / Does anyone have an easy way to remove snow from equipment after use #23
Just wondering if anyone has an inexpensive easy way to remove accumulated snow after using the tractor blower etc. my uit is in a heated garage and when it snows enough every day to use the unit(s) it melts amd makes a small lake LOL.
I've tried a windshield scraper which is somewhat OK but is time consuming and leaves a lot behind.
Also tried compressed air which works somewhat well but again is a bit time consuming.
They flat air nozzles but I'm not sure if they would work that well LINKY Another version of a nozzle LINKY 2 .
So i thought I'd ask here TIA and 🍻
   / Does anyone have an easy way to remove snow from equipment after use #24
I brush off what I can. I have an unheated barn so it doesn’t melt. On the next good day I just back it outside and leave it for the sun to take care of it.
   / Does anyone have an easy way to remove snow from equipment after use #25
I installed a hot/cold freeze proof faucet outside my garage. When done plowing, I would simply hot wash the tractor, then drive it inside.
This also got rid of the salt residue
   / Does anyone have an easy way to remove snow from equipment after use #26
Yesterday when I was done blowing, I set the temperature in the shop to 55 degrees and put the overhead fan on.
I have a little more to blow today and do the same thing. I have a 3 inch drain that works good.
Tomorrow I'll shut the heat off, because it's going to warm up. The heat is off unless I'm melting snow off tractor or doing some work in the shop.
A few years ago we didn't get much show and like a dummy I didn't make sure my drain was covered with snow and it froze.
Shop was at 60 degrees, I took the air coupler off of the hose and put it down the drain up to the ice.
I put the air going, don't remember how much, but the water was kicking up in the air over a foot.
1 1/2 hours later the ice melted and back to normal. Right now I probably have 4 feet of snow on that drain to keep from freezing.
   / Does anyone have an easy way to remove snow from equipment after use #27
Park outside and cover with a tarp and bungee cords
   / Does anyone have an easy way to remove snow from equipment after use #28
move to florida?
   / Does anyone have an easy way to remove snow from equipment after use #29
I clean a little around the auger, fan, and chute so it will function smoothly if it freezes. My garage floor drains towards the door.
I started to leave my blower outside when used because one day the door seal froze to the concrete and I could not get the door to open.
   / Does anyone have an easy way to remove snow from equipment after use #30
I have heard that Pam helps the snow fall off the blade, so a consideration might be applying that to the worst surfaces for snow buildup. This may make cleaning surfaces easy with a broom.
Chris
   / Does anyone have an easy way to remove snow from equipment after use #31
How about one of those little propane heaters? They require power for the fan, but you could aim it at the blower and move it around as required!
I have hot water in my garage, so I usually hose everything down with hot water then pull it into the (Heated) garage!
Honestly, I’m diggin the “Move to Florida” comment!
Cheers,
BN
   / Does anyone have an easy way to remove snow from equipment after use #32
If you have a place out of the way with access to a water hose, simply wash it off with a garden hose w/sprayer nozzle. Anything that has a function like a loader, or rotates like a blower, let it drip dry for a few minutes, then move the functional parts, or rotate the blower slowly for a bit. Park it inside, then grease them to push any water out.
We did this, and they still do for equipment we used on snow & ice removal. From dump trucks with plows & spreaders, graders and occasionally dozers. Just have to dress for the occasion.
   / Does anyone have an easy way to remove snow from equipment after use #33
If you do not have a heated garage floor and if there is gravel under your slab. Let the water puddle then in the deepest spots drill like 3/8” holes and the water will never be a problem again. I’ve done this a few times and it is a quick cheap fix
   / Does anyone have an easy way to remove snow from equipment after use #34
I keep the tractor in a shed with a wood floor. I don’t want the snow melting and then refreezing in the plywood floor, so I keep the blower parked on a large, deep stall mat from tractor supply with a heavy lip around it that traps the water. I knock most of the snow off with a broom before I put it in the shed and whatever melts on the mat just evaporates in a couple of days. Did the same thing with my walk behind in the garage years ago.
Something like this
Tractor supply stall mat
   / Does anyone have an easy way to remove snow from equipment after use #35
My 6’ snowblower gets caked with pounds and pounds of heavy snow and sometimes a thin ice layer beneath, after I’m done with it.
A leaf blower wouldn’t touch it.
I use a long scraper bar, for large areas, and a plastic splitting wedge for the tight areas that get fully packed with heavy snow, like the chain sprocket area.
I always get ice, or very dense snow in the warm area near the gearbox.
I spend about an hour cleaning the best I can. Sometimes the auger is almost completely a solid heavy snow mess. I then bring it into the garage and I lower it into blocks to keep it elevated. If there’s still a lot on it , I place some low profile pans under it to collect dripping water
   / Does anyone have an easy way to remove snow from equipment after use #36
I use an aphalt sealer squeegee. You can get them at lowes, HD, etc.
   / Does anyone have an easy way to remove snow from equipment after use #37
Like you, my garage is heated and tractor gets loaded with snow. I always use my Echo PB9010H which easily removes 99% of it, and using soft brush along with blower does it all.
   / Does anyone have an easy way to remove snow from equipment after use #38
I use a gas leaf-blower to clear off sidewalks and steps; but, it must be performed ASAP after a snow, before it has a chance to pack.
Only downside, wind blowing in wrong direction makes you a snowman..
Is there a RIGHT direction? In my experience, no matter which direction I aim the blowing snow, it comes right back into my face - especially on windy days. :D
   / Does anyone have an easy way to remove snow from equipment after use #39
That's a really good idea. I'd bet just smearing Turtle Wax onto the plow blade would help a lot, even if you don't bother buffing it off. Application is even less work than the buffing. :D
This is a new problem for me. I bought a nice sparkling new Deere in 2019, and because it's only for personal use, I always figured the thing might still look damn near new when I sell it in 25 years with 2500 hours.
However, a friend had a single daughter move into a house just a half mile up the road from me, and he lives something like 40 minutes' drive away in good weather, probably an hour's drive on a snow day. So, to keep him from having to drive up here to shovel her out, I told him I'd plow her driveway whenever it snows. It really only takes me 10-15 minutes to drive the tractor up there at 10-20 mph, plow it, and drive back home.
But what I found on the first attempt last week, is that the mess of black salty slush on the road sprays all over the tractor, and in fact all over me! Now, this tractor which I never had to hose down or wash in winter, must be either washed after each snow storm, or left to rust a bit. Also, I come home with the sleeves and shoulders of my Carhartt inuslated coveralls all covered in black road water.
I'll try just driving much slower next time, but if I find I need to keep speed down at 3 mph (i.e. "trail speed"), it'll turn that 1 mile round trip into 20 minutes drive time... plus the few minutes it takes to do the actual plowing. I'm always in a rush to get to work on snow days, after having spent time to plow my own (much larger) driveway, and clear the walks by hand.
   / Does anyone have an easy way to remove snow from equipment after use #40
This was a factor in deciding to buy a larger tractor, for me. I was between the 2R-series and 3R-series from Deere, really preferring the ergonomics and loader visibility on the smaller model. But I really wanted to get rid of my damn snow blower, they just become totally miserable on an open operator station tractor in the winds we get following most snow storms, and the 2R-series is just a bit too small and light to push a plow of any reasonable size in the heavy wet snow we often get.
I used to sometimes come inside looking like a snowman, with at least an inch of snow covering every stitch of fabric on my body. I'd be constantly turning the shoot, trying to blow with the wind as much as surrounding obstacles would allow, but the wind would too often swirl and change direction close to any trees or structures. It was just about impossible to not get covered, on the windy days.
One year proving the plow in on the new tractor, and I sold that damn snowblower. :D
2022 John Deere 1025R (A53317)
2022 John Deere...
IRTPL LIFT (A58214)
IRTPL LIFT (A58214)
2017 Ford F-550 Bucket Truck - Power Stroke Diesel, ETI 40 Boom, 45 ft Working Height (A56438)
2017 Ford F-550...
2024 YANMAR TL100VS SKID STEER (A60429)
2024 YANMAR...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
Gravely ZT XL-52 52in Zero Turn Commercial Mower (A59228)
Gravely ZT XL-52...
