Can you still pull off a geared tractor and crank it?
/ Can you still pull off a geared tractor and crank it? #1
part-time-Farmer-NC
Kioti DK45Se
Many moons ago we would/could pull a straight drive tractor/car and it would fire up. Granted these were gas best I remember. Made me wonder if its possible to pull off a more modern tractor?
I did try to pull start my kioti last Sept or so and it didn't/wouldn't crank. I ended up finding that one of the low/med/high range selectors wasn't engaging a switch (I guess anyway as it did crank when I jiggled it as I was turning the key over).
But it did make me wonder is this even possible now and is/was it possible for diesel's?
/ Can you still pull off a geared tractor and crank it? #4
Not an HST nor a computer controlled tractor, but certainly a geared tractor with mechanical injection. I've started both my M's like that in the past. Even bump started them when facing downhill by just rolling.
/ Can you still pull off a geared tractor and crank it? #5
Even if it's EFI you should be able to push/pull start it. You're just replacing the starter motor's functionality.
It may be a challenge to get enough traction to turn the high compression diesel motor over.
My reference was indeed targeting tractors. When I tried cranking mine I tried every gear to no avail. But it wouldn't crank normally either as stated above. I guess I gotta test the theory to pull it off when it will start normally should i need to in the future.
I knew the HST wouldn't work, tried that with the f1445 mower. Just slides the wheels.
/ Can you still pull off a geared tractor and crank it? #7
If 100% geared then yes should be able to pull start. Use a higher gear on tractor being towed and it will turn engine over easier vs sliding rear tires. The exception might be if they have a hydraulic clutch that engine to be running to engage or disengage the clutch.
HST, shuttle shift, power shift will not pull start since they require hydraulic pressure to engage the clutch
/ Can you still pull off a geared tractor and crank it? #8
Actually, on my Kubota's with the hydraulic shuttle, when the motor is off and not running, the hydraulic clutch is engaged. When the motor starts is when you can disengage it. I can pull start both of mine if necessary. IOW, the hydraulics disengage the pack, not engage it.
You always pull start in a high gear, never a low gear.
/ Can you still pull off a geared tractor and crank it? #9
It’s the only way I start the 1949 Cub and my 1905 Oldsmobile…
/ Can you still pull off a geared tractor and crank it? #10
Not necessarily on all makes/models . My power shuttle uses hydraulic pressure to disengage the secondary clutch, not to engage it. With the engine off, the wheels are hard geared to the engine
/ Can you still pull off a geared tractor and crank it? #11
I think it’s have to be 100% mechanical injection. So many newer machines the injectors are fired electronically.
You can pull start an electronically injected automobile, as long as it has a manual transmission. I don't think it's the injection system that would make it not work on a tractor.
You can pull start a gas or diesel automobile. Diesels can be more challenging, just as they're more challenging for an electronic starter. Don't know why it wouldn't work with a tractor with the right transmission type, unless there was some sort of safety device getting in the way.
/ Can you still pull off a geared tractor and crank it? #12
My error but if you can’t disengage the clutch can you put it in gear while standing still and pull it or do the wheels just slide?
/ Can you still pull off a geared tractor and crank it? #13
Mine has a mechanical link floor pedal for the primary clutch, that you would use for push/pull starting it
Mine has a push clutch too. So I am thinking its not hydraulic. It feels the same whether its running or not when I depress it.
/ Can you still pull off a geared tractor and crank it? #15
Many of the newer ones will not keep the transmissions engaged to pull start. Most of the power shift and power shuttle will not tow start.
The mechanical geared transmissions and dry clutched tractors will pull start, if it has an electrical fuel shutoff a jump pak or good battery will still be required.
/ Can you still pull off a geared tractor and crank it? #16
Have you actually attempted to tow start your M9000's with hydraulically operated reverser? Please explain if your tractor has hyd shuttle what engages forward shuttle clutch when attempting tow starting. Yes I'm aware that damper clutch remains engaged 100% of the time but what do you think engages shuttle forward clutch with ZERO hyd pressure? My M7040 with hyd shuttle(reverser) will roll off if left in gear, shuttle lever in forward position if parking brake isn't applied or frt end loader bucket/bale spear isn't sitting on the ground & I'll bet your M9000's are identical!!!!!
/ Can you still pull off a geared tractor and crank it? #17
What are you referring to as a "push clutch" the foot control pedal? If your tractor has a hydraulically powered clutch or hyd shuttle IE hyd reverser it can't be tow started. My M7040 has a foot clutch pedal that simply operates a hyd valve that controls hyd pressure that is applied to the forward or reverse clutches in the hyd reverser. No hyd pressure due to engine/hyd pump not operating = to no hyd pressure to engage shuttle clutch = to no tow starting.
My Kioti, is not hyd trans, has I think they say 12 gears. I have a forward/reverse lever mechanical it appears in the dash area, then l/m/h range selector followed by the 1-4 gears. The clutch appears to me to be mechanical, but honestly never looked for the hydraulic reservoir if indeed its a hydraulic clutch.
I do remember reading that periodically the clutch may need adjusting to ensure the clutch petal isn't partially engaged and wearing it prematurely. I haven't seen a need to do that yet. I have play at the start of depressing it that when depressed the tractor doesn't stop moving. I have seen other clutches with little to no clearance and when barely depressing the clutch it stops the drive train. This one doesn't feel that way.
/ Can you still pull off a geared tractor and crank it? #19
So a mechanical shuttle transmission with a dry clutch, to shuttle I'm assuming you clutch/stop/select forward or reverse then let your clutch out to move.
/ Can you still pull off a geared tractor and crank it? #20
You’re right. I checked my power shuttle today.
My bad
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
large capacity skid steer bucket (A56857)
large capacity...
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
JOHN DEERE 850K WT CRAWLER DOZER (A62129)
JOHN DEERE 850K WT...
2019 Chevrolet Cruz Sedan (A60352)
2019 Chevrolet...
2015 PALMER MACHINE WORKS 24' DUMP TRAILER (A59823)
2015 PALMER...
