Identification help Ford 3400
/ Identification help Ford 3400 #1
Mattmsleslie
1977 Ford 3600
Good morning all,
Trying to date and get as much info on my tractor as possible. I bought it for $500 truly for the loader (going to put it on another tractor I own), but it runs and I may keep it together if I can get some kinks worked out. The steering doesn’t work, and there are some leaks throughout.
I think it’s a 1972 Diesel and it’s a 6 speed
Model: C40*** can’t read the rest
Production code: 2B14B
Serial: C360891
Engine casting photos included as well (not sure how to read them)
Any help is appreciated.
/ Identification help Ford 3400 #2
You are correct, it is a 1972, Feb 14 build. The prefix of the model and the front axle verifies that is a 3400. Castings show that the engine is original.
Nor a bad tractor for $500.
With oul in the power steering pump, the steering doesn't work or the steering gear is bad?
It will not steer unless I lift the front end up with the bucket. Then it’s smooth. But the steering cylinders are disconnected
/ Identification help Ford 3400 #4
Oh, well that explains the no steering. Power steering pump probably no good
How do you know from the engine casting that it’s original? I can’t tell what the numbers mean.
/ Identification help Ford 3400 #6
The casting #, D0NN, indicates that it is a 1970 (D0) build design. The NN means it was designed for tractors.
Look at the RH front bolster of the engine for an alphanumeric stamping. The first part should be a 2, meaning it was built in 1972. Probably a 2B*** like the engine date code of 2B14B. It could start with a 1 as the engine could have been built earlier.
/ Identification help Ford 3400 #7
BTW, the true model number, C40*** should be C4011K.
C40 = 3400, 1st generation
1 = means vertical diesel
1 = no PTO
K = 6x4 manual reverse shuttle
1 = no PTO
There is PTO. But I’m not sure how to tell what type
/ Identification help Ford 3400 #9
Is there an ID plate still on the hood? The fifth number in the model code will tell. Alternately, you can check it out this way:
Code
2 Transmission PTO = The clutch pedal will stop and start both the PTO and transmission
3 Live PTO = You can disengage the transmission, but keep the PTO running by depressing the clutch pedal part way
4 Independent PTO = The PTO lever can be engaged/disengaged with the PTO lever only.
