Just another junk chainsaw
/ Just another junk chainsaw
Hard to believe the husky decals going NLA here is US. Having to order from overseas like did on the 346 last time.
Echo 501 #2 cleaned and ready to test.
In the rain it looks like. SMH
Less then 2 mins to use this Oregon K095 bar. Now to see if oils good. Appears it is lined up just like K216
K095 oils great no adjustments needed for that.
Wasn’t the upper left av plastic being stripped out. 359 2
Some CFS put a limiter fastener in it.
Put one on right in and all good. Trade in 359. :cool:
Took on trade a OE 346 running parts saw. Lot of stuff been taken off for other saws.
A past owner ran 2 long of fasteners for lower handle.
Heat gun , flat blade, razor then flapper did it. Just want to make it a better redneck repair.
Some info I put together from Joe dyno. Just your avg work saws that last forever, nothing extreme done.
Echo 501 4910, Husky 550, Stihl 261 all woods ported by Joe and checked on dyno. Sheets below.
PHO but both tanks filled up and weighed by Joe. 550 13lbs 5.9oz, 261 12lbs 6.5oz, 501 4910 11lbs 14.7oz
Then figure in cost of each to begin with. IMO why alot of folks going the echo route.
More info I had researched last week in my group with porters.
Leaving dyno numbers out of this because they dont always tell the tell in the cuts.
Muffler modded echo 501 4910 will see gains of 18% 20% 22% give or take from it in cut times.
Add woods ported port work with that you can see another 20% 23% 25% gain in cut times.
/ Just another junk chainsaw #1,966
View attachment 2466693View attachment 2466694
I have several 50cc pro saws, including the 4910, 261 and the 550. I will choose my 4910 any day over the other two when I grab one of them. When I am cutting wood I usually take 3 saws with me back on the tractor, my Husky 562, the 4910, and the 2511T.
All of them still stock? No muffler mods or ported?
Can I ask why because if all stock the 550 261 eat the 4910 501 as them come and both the 261 550 smooth due to coil spring antivibe used. If no muffler modding done.
Is it the lighter weight like I am seeing as used even when compared to my NE 346 too? Plus cut right with the NE 346 too with muffler mods.
18" 325 full both
550 MKII weighs way more then 346 or the OE 550 I owned too.
/ Just another junk chainsaw #1,968
18" 325 full both
View attachment 2466919View attachment 2466920
Muff mods on 550 and 261, muff mod and engine mods on the 4910.
Throwing this OE 346 on the shelf till I get in the mood. Was told a running saw that was used for parts for others in series.
Someone hack ported the exhaust and base. Wasnt going to use the 42mm anyways.
Was wanting to use for a tester saw for fun for different aftermarket topends out for these now.
Sometimes I just shake my head at my DA self. 🤦
Going over my parts I got coming and the OE 346 I got here for project tester. For aftermarket cylinders in this series some day.
I just realized I forgot to put a top handle on my list of things to get. 🤣
I found OEM tank, recoil, clutch cover, cylinder cover already and heading my way.
Handle 503909301 537301701
So making sure running the numbers, seems 345 346 350 351 353 all used the same handle. So that will make this easy for sure. 😎
/ Just another junk chainsaw #1,971
Last night I was putting back together an 026 I was rebuilding, only to discover SOMEHOW I managed to lose the clutch cover and the filter cover. The saw, and the parts for it NEVER moved from that bench in the two weeks since I started the project. Only thing I can figure is the dogs knocked them off and they fell into the trashcan and got hauled off. Oh I was so mad!
OEM 346 handle in route.
Gave the 42mm topend to a guy with lathe so he can save it. Cut base and squish. For helping me out finding parts for project packrat.
SOB while making shopping list and thinking of needed smalls. No chain brake handle LMAO at myself and list grows longer. Project packrat turning into moneypit.
/ Just another junk chainsaw #1,974
At least you can blame the dogs...
/ Just another junk chainsaw #1,976
I have two young labs. If you know anything about Labs, they are responsible for most accidental things. :ROFLMAO:
I know all about labs. My first is why I am missing my good axe, as well as my favorite hammer.
Also a $1600 electronic data collector years ago... With 3 days of work on it which I had to redo.
/ Just another junk chainsaw #1,977
Sounds like you definitely know! :ROFLMAO:
We had 3 labs in the 3 main colors. Ya they can be trouble. :ROFLMAO:
But boy this one blonde yellow was something else. Buckwheat. :giggle:
He would pin a wounded yote till I could catch up with him.
Many other stories too.
None of the others was like him.
I have never been a light bar user. If I had one come In trade on saws I sold them off.
But these versacut Intrigued me. Priced right and light too as I seen posted by others.
But I thought couldn’t be much difference in a small mount 16” 050 325 66dl right.
Well here is 2 of my regular bars with replaceable tips in same small mount to compare.
Then the 20” K095 3/8 050 72dl versacut compared to my GB 3/8 050 70dl K095.
For you guys with the echo 4910 490 with plastic handle and plastic rear grip. If you notice the vibrations to your hands.
Here is the echo 501 metal with rubber coating parts. The av will still be the same rubber and vibrate more then coil spring.
But I dont notice it on the top handle using the metal rubber coated handle on the 490 4910.
Arrow Quip MAN-STBR Sternum Bar (A64047)
Arrow Quip...
INOP/NON-RUNNING 2011 Ford F-550 Cab and Chassis Truck, VIN # 1FDUF5GT9BEB33435 (A61165)
INOP/NON-RUNNING...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63118)
2023 Kubota U48-5...
2013 Bobcat T750 (A64047)
2013 Bobcat T750...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2005 Great Dane Dry Van Trailer, VIN # 1GRAA56185K270688 (A61165)
2005 Great Dane...
