Looking for some help.
/ Looking for some help. #1
minnesotaredleg
Oliver 1600
Bought a small farm that came with an old Oliver 69hp tractor (1965 I think). Got it running good but was way too much tractor for what I need. Sold it and bought a MF gc1725mb. Tractor is fine (should have went a little bigger but hindsight). Looking to put a brush hog. Am looking at 48" but conflicting opinions as to if my Massey will run it or if it will destroy my tractor. Counting on the wisdom of crowds here. Thanks.
/ Looking for some help. #2
Size of Brush Hog is not major concern, you can probably run up to 60 inch, but how you use/abuse it will be how you hurt tractor... Tractor Data dot com states you have full 24.5 HP at PTO (claimed)... General consensus is it take about 5 hp per foot of "mower" width....
/ Looking for some help. #4
I owned a Massey GC2400, essentially the same tractor as yours. I ran a 48" cutter with no issues. It will handle it just fine. Use the speed of the tractor to determine what you can cut. If the RPMs are dropping, slow down. It doesn't matter what tractor, that is the case. Get the 48" and go cut some $hit.
Sounds fairly unanimous. Looking forward to leveling some unruly vegetation. Thanks fellas.
/ Looking for some help. #6
IMO, you just as well trade-up now. You will not be satisfied with either the tractor nor the results of using a 4' brush cutter.
That SCUT might power a 4' brush cutter IF you go slow enough; use your lowest gearing possible.
That MF is for a hobby farm, less than 5 acres, and not already overgrown.
/ Looking for some help. #7
Agreed...
I suspect the tractor-data horse power chart is a typo in this instance. They are usually pretty accurate.
Massey Ferguson GC1725M Power
Engine (gross)24.5 hp
18.3 kW
Engine (net)23.9 hp
17.8 kW
PTO (claimed)24.5 hp
18.3 kW
/ Looking for some help. #8
Agreed...
18.3 kW
Engine (net)23.9 hp
17.8 kW
18.3 kW
Definitely a typo. 17.5 hp for the pto would be more accurate.
/ Looking for some help. #9
what your cutting, along w the height and thickness is very important. You also have to consider the incline(s) and speed.
2022 EZ-GO ELITE...
2012 DRAGON  130BBL VACUUM TRAILER (A65643)
2012 DRAGON...
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Lot of (18) Hedge / Black Locust Posts (A66408)
Lot of (18) Hedge...
2025 MACK GRANITE GR64F DUMP TRUCK (A63276)
2025 MACK GRANITE...
