Kubota B2710HSD front axel sheared off.
/ Kubota B2710HSD front axel sheared off. #21
The B2x10 series tractors had known issues with the front hubs failing like that. I believe the replacement has more area to the weld.
You are correct on the newer version of the front axels (see pictures); however, the older B series can't use the newer version of the front axel. Axel type is based on tractor serial number. You've got to dance with the one that brung you.
/ Kubota B2710HSD front axel sheared off. #23
I mean the replacment part for your model was changed to be stronger.
/ Kubota B2710HSD front axel sheared off. #24
Correct me if I'm wrong but I don't believe the loader will lift anything that will damage the front axles if properly counterbalanced.
/ Kubota B2710HSD front axel sheared off. #25
It shouldn't, however a lot of fast driving over rough ground or sharp turns in soft material, or striking something with the wheels turned can impart a lot of extra load on the spindle.
Apparently, the original design was weak in the welded area, the replacment part was designed to be stronger.
Family acquaintance had this the failure on his B2910.
/ Kubota B2710HSD front axel sheared off. #26
For traveling any distance it’s best to skid the logs with or without an arch. Carrying heavy logs for a distance with a loader is asking for trouble. Tractor loggers skid logs, they don’t carry them.
/ Kubota B2710HSD front axel sheared off. #27
Or just load the logs on an agricultural trailer. That's how I did sometime ago when I had to move some logs over a mile away. Granted I had to go on public road but I would've used the trailer regardless. These are just so handy, specially with dump feature.
Not that I can see. Replacement axel appears exactly like original part. According to Messick's web site the original axel fits 35 models of Kubota. It would be very interesting to see if the newer design, which only fits later versions of Kubota tractors, breaks as frequently. Currently the newer designed axels are available, but the original axels are backordered-not sure if that means anything. After watching several of Messick's YouTubes I’m under the impression that if you frequently overload the front axels they eventually will break, regardless of design. My future plans are to use my chipper as a counterbalance when possible, take smaller loads and drive slower when FEL is full. I live on pretty steep terrain and often retrieve 19” sections of trees from places where a trailer can't go. Besides learning about front axel load limits, this experience has given me pause about loaning my tractor to neighbors and ever buying a used tractor with a FEL.
I believe you are most likely correct, but to know correct counterbalance weight you'd have to know the front axel load capacity, the existing load on the axel with the FEL empty, the effective weight of the load you're putting in the bucket which will vary based on how high you raise bucket, and the effective weight of your counterbalance which will vary with distance from rear end of tractor. In addition to this it would be advisable to know the available load capacity of the rear axel as you will be shifting weight to this pivot point. As mentioned in prior post my intension is in future, when possible, to attach my 505 lb chipper to rear accepting it may not cancel an excessive load on the front axels, but will help. I, however, do need to look up the load capacity of my rear axels. I should add if you descend a long steep hill you will transiently transfer the load to your front axels in which case the counterbalance will work against you.
/ Kubota B2710HSD front axel sheared off. #30
Most any retailer like Motion Industries for instance will have accumulators of various sizes and capacities in stock. Use your search engine to find them.
Thanks for the name to look for. However, Motion Industries shares a common theme with accumulator big dollars.
/ Kubota B2710HSD front axel sheared off. #31
/ Kubota B2710HSD front axel sheared off. #32
Do you think one that’s just 0.5L work rather than the 0.75L?
Most kits offered use the 0.5L. Should be plenty for the cylinders on these compacts.
/ Kubota B2710HSD front axel sheared off. #33
Petdoc, Your going to need more data than what you mentioned because the loader arms and piston attachment points are between the front and rear axles. You've entered the arena of FEA/ Finite Element Analysis as it applies to structures. Way beyond the conversation on TBN.
As an aside, I asked and received an answer directly from Kubota America engineering, when I was interested in going from 6 ply to 10 ply tires for front on my M59. Kubota would NOT give me the specification for front axle design load. My interest in knowing the design load was to determine if I could unintentionally overload any part the front axle system because of the higher load bearing capability of the 10 ply tires.
/ Kubota B2710HSD front axel sheared off. #34
Far as hydraulic accumulators are concerned. The reason for the cost is vessel construction and what the vessel has to withstand pressure wise before structural failure contributes to the cost. That vessel has to withstand great pressure and pressure spikes so it has to be designed for that scenario, consequently the cost and I'm not sure it has to be of great volume either as all it's doing is absorbing the pressure sike and dampening the reaction and if I installed one, it would be in the main loader supply port on the loader valve itself. Kind of similar to a pressure relief vessel on a water supply line to mitigate 'water hammer' which is essentially the same thing but at much less pressure.
Concerning front axle failure of the outboards, I believe it has to do with the choice of bearings Kubota uses. I've always thought they should be radial roller bearings, not ball bearings, but I'm not an engineer and come to that conclusion from observance of the outboards, not from any other experience.
I do know from observance that hydraulic dampening units, even on large commercial forklifts aren't all that large, in fact they are quite small but I do know that charging one is beyond the capabilities of most people simply because the average user has no way to charge one with inert gas (hydrogen or argon) to the required pressure of whatever the installed in system is rated for, which would be somewhere around 2100 psi or whatever that particular tractor is rated for concerning hydraulic pressure. In my case I could using an inert compressed gas welding bottle and it's pressure gage. Normally. a fully filled gas bottle will register about 2300 PSI, which is more than adequate to pre charge one.
I do understand that the calculations I refer to are best done by rocket scientists that received an A in college physics. I am not and I did not. All I need is a ball park idea of where I am vs axel load capacity. In the Messick's YouTube I attached in earlier post the speaker referred to the opacity of Kubota on axel load capacity, but indicated they get it with spec sheets for tractors they buy. You might give them a call as they seem very helpful.
/ Kubota B2710HSD front axel sheared off. #36
Doesn't it have a tag similar to this one on my tractor, saying the permissible axle loads?
/ Kubota B2710HSD front axel sheared off. #37
Interestingly, neither of my M9 Kubota's have that sticker anywhere on them and to my knowledge, never have but, the maximum permissible axle loads are plainly spelled out in the owners manuals along with implement limitations.
/ Kubota B2710HSD front axel sheared off. #38
I don't think the manual for my tractor lists it either but I do have that info on the title of the tractor as well.
/ Kubota B2710HSD front axel sheared off. #39
Even if the manufacturer provides a written limit for front axle load how are you going to know when you have reached it given the mounting points of the FEL and their relationship to load transmission to both front and back end of the machine. That is exactly why, after Kubota America's engineer refused to provide me with a hard number, I realized knowing the number would not tell me what I needed to know, which is "What is the weakest link between the load carried by the bucket of FEL and the rest of machine. This is a FEA problem. Is it the loader arms, is it the loader arm pins, the bushings, etc, etc, etc.
You found a weak link ( the spindle to hub attachment ) but why must be answered if you are trying to craft a solution that assures a non repeat of this failure and there are many reasons for metallurgical failures.
/ Kubota B2710HSD front axel sheared off. #40
I have no titles for either of my Kubota's, just bills of sale. Must be different where you reside. Same with all the implements, bills of sale, only.
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2020 INTERNATIONAL...
2014 FREIGHTLINER CASCADIA T/A 6X4 SLEEPER TRUCK TRACTOR (A59906)
2014 FREIGHTLINER...
UNKNOWN  SPOOL TRAILER (A58216)
UNKNOWN SPOOL...
16ft x 8ft Flat Bed (A57454)
16ft x 8ft Flat...
