80" of snow this week.
/ 80" of snow this week. #21
So far haven't seen any snow but we did get some sprinkles
willy
/ 80" of snow this week. #23
Sort of wanted to see what 80"s of Snow at once was like, maybe the Metric System is still messing with my head but I see 12-14" (maybe) on the ground plus Banks.
The verdict is still out, if a Forward or Backward Blower for me, it seems you are still turned around most of the time with that much snow
I am turned around most of the time. If going a long stretch you may just look forward but only once you know exactly where you are not in a single opening driveway. 80" of snow turns into about 30 inches in less than a week. It gets pretty dense.
/ 80" of snow this week. #25
Yeah, lake effect 80" turns into nothing quickly with high winds blowing it into giant drifts.
/ 80" of snow this week. #26
we had 40" overnight once years ago. locked everything down for a few days. but they have the equipment up here to get things moving again pretty fast. it did take me quite awhile to get out to my tractor and get the place cleaned up though. we generally get about 100-120" per season here, but i doubt weve seen 6" so far this season.
/ 80" of snow this week. #27
We are cold enough here that the Snow doesn't really melt until March, but accumulations aren't like the old days. I have 1 year recorded at the Cabin of 147"s overall and total of 5' on the ground. Lake travel was almost 0, even Snowmobiles were having troubles.
This is about the Limit of Lake Travel and that is with 2' on the ground. Snowblower would be so helpful in eliminating the Bank and less Drifting.
A 1" Drifting would plug this road full
/ 80" of snow this week. #28
How would you find the road….. i dont see markers
/ 80" of snow this week. #32
screamin400 I switched from a kubota l6060 with a front mount mid PTO blower to a Deere 5115m with a 92” Cyclone and R34 Nokian snow tires. Unbelievable upgrade. Totally agree with you this is the way to go. We get 200+” of snow a year in the UP for Michigan.
/ 80" of snow this week. #36
Same Place 2 Winters ago.
After pulling the Lead Truck out of this hole, where he spent the night.
/ 80" of snow this week. #37
Not sure where you are, but I am just south of Sandpoint. Same here - very little snow. I plowed once but really only because I was all rigged up and wanted to test out a couple modifications I had made to my front blade.
Lots of rain - we would have been sitting on some deep snow if the temps had been 5 degrees colder.
/ 80" of snow this week. #39
Which Nokian tractor tire? They sell 10 tread types.
/ 80" of snow this week. #40
Nice tractor. Would he mind if you put 1"-2" spacers on the back wheels to keep the chains from rubbing ?
I tried to do this today but ran into a couple of complications. I brought along my 1/2” drive impact wrench and a set of impact sockets (I wasn’t sure what size the bolts were). I also brought along (6) 3/4” nuts which were the biggest I had in stock in my shop, figuring I could use them as spacers.
I wasn’t able to break any of lug bolts loose with my impact wrench. I’m certain they are metric bolts since this tractor was manufactured on Japan by Yanmar for John Deere in the 1980’s. My 1” impact socket fit them.
I tried my dads old Craftsmen 1/2” ratchet with a long extension and long pipe on the handle, but I couldn’t get them to budge with that with a torque less than it would take to break the ratchet or twist the extension (Ive got a pretty good “feel” for what I can get away with on that stuff from lots of experience).
My 3/4” nut spacers, if they even fit over those metric bolts, would have spaced the wheel out about 5/8”, which should be plenty to stop the chain rub. Another issue, had I been able to break the metric bolts loose, would be insufficient thread engagement in the backing hub, that only looked to be about 3/4” thick.
They had about 6” of snow in the driveway around the barn, so I used the tractor “as is” to clear that. The chain rub (on one side only) didn’t seem quite as annoying as it was the week prior. Nonetheless, I’m going to visit the hardware isle at TSC next time I’m there. Not sure if they will have metric bolts but if they do, I’ll pick up a dozen of the proper length, that measure about 1” across the flats of the head.
I’ll also pick up a dozen English thread nuts, that slide over those metric bolts, to use as spacers. I’d like to put them on both sides so it won’t matter which side I put the ribbing chain on in future years.
If I can find that hardware cheap enough (less than $20), I’ll bring along my 3/4” breaker bar and 1” socket, on my next visit. If I can’t, I’ll just tolerate the fender/chain rub.
I’m getting spoiled by my much more comfortable Farmall Cub with its front plow. My neck was getting sore after about 20 minutes of snow clearing today with the back blade on the cramped platform of that little JD 770.
2000 Ford F-450 Pickup Truck, VIN # 1FDXW46F5YEB20130 (A61165)
2000 Ford F-450...
203201 (A60429)
203201 (A60429)
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A63118)
2021 Unverferth...
1995 Chevrolet S10 Pickup Truck, VIN # 1GCDT19W7SK120441 (A61165)
1995 Chevrolet S10...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
New/Unused Wolverine 45in Bucket Clip on Pallet Forks (A61166)
New/Unused...
