Time to check out the generator.
   / Time to check out the generator. #131
(y)(y)
For critical loads, that's what I have always done. Enough UPS systems with the power and capacity to run the full load for ten minutes (aka as 20 min) to give the generators enough time to power up, warm up, and stabilize before the load was transferred. It helps the equipment under protection as they never lose power, and it can help the generator with the load transfer, especially if the UPS systems transfer at slightly different delay times.
All the best,
Peter
I had to slow the transfer slightly to keep breakers from tripping.
Transferring motor loads in the 10 to 20hp size to quickly was the problem and the motors are required for air exchanges and to maintain positive room pressure for surgery.
I like this thread as it makes me pay attention. Today was dedicated to starting and running every ICE, I have and checking fluids: 11 engines.
Two push Lawn Mowers
One Riding Mower
Motorcycle
Generator
Chainsaw
Weed eater
Water pump
Two cars.
Took all day, but now I know it was done at least this year, and they all run. :)
   / Time to check out the generator. #133
We lost power again for two days with air temps around 20F. It wasn't a crisis because I have a 3500 watt inverter generator that powers the 120v stuff in the house (fridge, lights, internet so we can work, etc.) and I have a kerosene heater that maintained a 65F temperature in the living room. But, if we had continued to be without power for a longer period of time it would have started to become a hassle.
This summer I'm going to get my fuse panel rewired to accept 240v input from a larger generator. Currently it's wired for 120v input and I do have a safety transfer switch. I want to get it swapped to accept 240v so that I can buy a larger generator and power the heat pump, water heater, and stove. That way we can take showers, keep the entire house at a levelized temp, and make food.
I have some questions:
Will 9500 watts be enough to run a 2.5 ton heat pump and a water heater?
Do I NEED to pay more for the inverter generators, or will the "standard" ones be fine?
When they change my transfer switch wiring to accept 240v input, will it automatically power everything in my fuse panel, or is this a one or the other situation? In other words, the 120v and 240v stuff will all work off the generator automatically?
   / Time to check out the generator. #134
It will power everything up to the generator breaker limit.
I’ve powered all I needed but not at the same time because I’ve never owned a generator large enough to power all simultaneously…
   / Time to check out the generator. #135
It will be dependent on the transfer switch you have installed. The smaller stand alone switches only cover the loads wired into them.
Then this type which will allow all loads to be powered on a generator, they are available as manual as shown or as automatic transfer switches (ATS)
Here is a decent article on transfer switches;
Generators and Transfer Switches: A Comprehensive Guide
   / Time to check out the generator. #136
A larger transfer switch will enable a larger generator to power more. A 240V transfer switch should enable both 120 and 240V circuits.
A whole house transfer switch would enable the most support for keeping things backed up. (Usually 200A) Whole house generators often have options for their own automatic transfer switches.
The primary benefit to inverter generators is, I think, that they have an eco mode and can reduce their fuel consumption when demand is low. If you have a reasonably maintained, reasonable quality generator, the power should be good enough for most things. If the power quality isn't good enough for something, I think it is more practical to put those things that require "better/cleaner" power on an online UPS.
I always suggest that folks think about how long they might need power and then triple that number. Odds are that outages are going to get longer. That leads to how does one store enough fuel for the longer outage, and in the case of non-propane generators, how will does one keep the fuel fresh? Sometimes the available fuel dictates the generator and the generator fuel.
Whether 9,500W of claimed power is enough to run a 2.5T heat pump will depend both on what kind of heat pump it is and what the LRA and FLA is for the heat pump and your choice of generator.
All the best,
Peter
   / Time to check out the generator. #137
Mine is an "interlock kit" style, similar to this:
I shut off the main breaker powering my 200 amp service fuse panel, then slide the plate blocking that switch, then flip the breaker for generator input. That's how my setup is isolated. So I guess the breaker they installed for the generator is what will determine how much input it will handle? I'll have to look when I get home and see what amp rating that one is.
   / Time to check out the generator. #138
They are a decent very inexpensive way to go.
   / Time to check out the generator. #139
Generally, the breaker is sized to the generator, and thus usually much less than the panel it is supporting. (E.g. 40-60A for a 200A panel) I think of the breaker getting sized to protect the generator.
@Blue Mule Like @LouNY, I think that they can be a simple and cost effective solution, but each panel takes its own particular interlock, and not all panels have interlocks available, and not all panels can have the generator breaker bolted down as is required in some AHJs. Bottom line: it may not work for your panel in your area, but it might.
All the best,
Peter
   / Time to check out the generator. #140
I test my generators monthly and use a similar interlock switch. I've been doing it for many years and each time I manually trip that 200A main breaker, it makes me wonder just how may duty cycles these main breakers are designed to handle.
Sure, they can be replaced if you can find one for an older breaker panel. Requires pulling the meter or working with live conductors though.
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
Willmar 4550 Wrangler Articulating Loader (A57024)
Willmar 4550...
UNUSED FUTURE BC63 57" HYD BRUSH CUTTER (A57193)
UNUSED FUTURE BC63...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
20ft. Deer Gate (A53424)
20ft. Deer Gate...
