sandman2234
Super Member
- Joined
- Dec 4, 2005
- Messages
- 6,677
- Location
- Jacksonville, Florida
- Tractor
- JD2555 and a few Allis Chalmers and now one Kubota
I have an M7040SUHD with an LA1153 loader. For all practical purposes, this loader does a fine job. Occasionally I need to lift something that is closer to the max limits of the loader, and the lift cylinders just won't pick it up. Most of the time, I figure it is the distance from the pin, since the loader is rated at 24" from pin. Push it either further out, or push it right up against it's RATED limits, and it just won't do it. I can usually compensate by using the curl, but sometimes that isn't enough.
A friend has the same issues, and we talked about putting larger cylinders on the loader. My clinders "may" fit his smaller loader, so we could go together and just buy one set for my tractor. Another option is for me to buy a set and keep my originals in case the new ones have issues. A local hydraulic shop can be tasked into making new cylinders to fit, somewhere in the range of 1/4 to 1/2" larger in diameter. I am considering 1/4" larger, because I know me, and if I need to pick up something, I am probably going to push the limits right up to the max. 1/2" might be just enough to do the FEL frame in, so I am going to be a little more conservative.
Has anyone ever increased the size of their loader cylinders, and what was the outcome? Was it worth the expense, and just how much did it slow the hydraulics down as far as normal useage?
This is pretty much a pipe dream right now, but we are going to look into it, unless someone has already done it and can explain why we shouldn't.
David from jax
David from jax
