Help extending the range of my Dakota Alert System
/ Help extending the range of my Dakota Alert System #1
jk96
Elite Member
Missouri
Kubota L6060
I just recently installed the Dakota Alert DCPA 4K that uses the buried vehicle probe. The transmitter and receiver are located about 1/2 mile away however the transmitter is at the bottom of a hill and my alerts are spotty. Maybe 50/50 success rate at best. I know I can move it closer to the house however this is the preferred location due to being in a place in the drive that cars cannot go around it and also allows more time to alert us to incoming vehicles. In talking to Dakota support they cannot make recommendations due to FCC limitations. I know about zero as far as radio.
It looks like both the transmitter and receiver uses a helical internal 433 MHz antenna. The receiver antenna is about half the size of the transmitter antenna. Each antenna is soldered to the board and would be fairly easy to solder in a different antenna. Pics of each attached. Although both antennas are internal it would be easy to modify the housings if needed for an external antenna. So...............
What recommendations can you give me? Add a better external antenna to the receiver, transmitter, or both? And what antenna would you recommend? Because I am getting some alerts I don't think I need a huge bump in signal. Appreciate any help.
Jeremy
/ Help extending the range of my Dakota Alert System #2
I used and use now a cheaper setup ( Mighty Mule) for this as well as a WiFi for security video . Distance is never what they say. Trees hills even weather causes problems and if you are fringe it’s likely not gonna get better. In short you need a fairly strong signal or it will only work intermittently and bug you .
Things to consider . Receiver location is big. Steel walls brick walls really cut signal strength so try keeping the receiver in a window if possible. Keep that antenna tip directly in front of glass not casing and cross your fingers. That’s the single best thing I ever found to help if you can swing it. I did try an outside WiFi antenna to offset my barn video steel wall fringe issue and that was a total bust.
/ Help extending the range of my Dakota Alert System #3
You can try this cheap range extender antenna for garage door openers:
It will give you some gain. If it isn't enough, you may have to go for a more expensive model like this one:
In both cases, you'll have to cut the cable and solder the center connector to the transmitter circuit board.
If these don't do it, you may have to put this one on the receiver:
Good Luck!
Good Luck!
Would you recommend trying on the receiver first since it seems to have the smaller antenna of the two?
/ Help extending the range of my Dakota Alert System #5
I had a Dakota Alert system for a couple of years;lots of false alarms and deer setting it off.Replaced it with a cell based game camera and a solar panel.
There are some cost but have a picture in 2 minutes go directly to my cell phone no matter were I am.
Tactacam camera($119) yearly unlimited maybe $100(not sure I have 4 of them).Solar panel about $72.Mine works well and their tech service is good.
This one used the buried probe to detect metal so no motion alerts.
/ Help extending the range of my Dakota Alert System #7
I have had 3 Dakota Alerts motion detectors and a Guardline motion detector. When I buy another one, it will be a Guardline.
I'm not interested in motion. Had the dakota with vehicle probe at our previous location and worked great. I'm only interested in something that will detect vehicles, utv, etc to alert us when sleeping. If an antenna extension doesnt work Ill move it to the top of the hill . Just wanted this location due to the narrow choke point.
/ Help extending the range of my Dakota Alert System #9
I have the same system, no issues. But if I were you, I'd probably try replacing the antenna on the receiver. Because you say you are getting alerts, the signal does make it, just not consistent. But that's just thinking out loud...
/ Help extending the range of my Dakota Alert System #10
Yes, if it's easier and you don't mind spending a few extra $$.
That antenna is a Yagi design and is highly directional. It may take some time to get it aimed correctly.
AGT Industrial STSD10 QA (A60463)
AGT Industrial...
Zero Turn Mower (A59231)
Zero Turn Mower...
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
KJ K2030 20'x30' Metal Garage (A60463)
KJ K2030 20'x30'...
HYUNDAI HLF25-5 STRAIGHT MAST FORKLIFT (A59823)
HYUNDAI HLF25-5...
CFG Industrail MX15RX (A53317)
CFG Industrail...
