Plowed Snow - Yanmar Content
/ Plowed Snow - Yanmar Content #1
aba4430
Yanmar SA425
So I do not have much experience using a snow plow; bought one a few months ago. Yesterday put it use, learning and getting used to it. Worked reasonably well with the loader in the float mode on our concrete pad and gravel driveway. Equipment - Yanmar 6' front blade with skids on a '23 SA425 tractor in 4WD.
/ Plowed Snow - Yanmar Content #2
Depending on the plow, Float is not the way to go. Is this a custom made plow with a hanging chain (like on pickup trucks) to create plow float, or is it mounted solid causing you to use the Float on the tractor arms?
With tractors, it does take a bit of learning to get the 'bucket tilt' set correctly.
Stone driveway.... even more critical than blacktop/concrete. Gotta finesse it until you get a nice compacted snow base or you will continue to rip up the stones.
SA series standard 6’ Yanmar blade, 5-position manual angle adjustment and the loader valve/arm has a standard float function.
/ Plowed Snow - Yanmar Content #4
Ok, so no float on the plow itself, from what i saw..
I'm surprised you didn't dig in on the stones when using the Float on the tractor. Good job
Plows, on tractors do not clean the driveway as well as a truck. Its just the nature of the beast. You have the Curl on the bucket that you dont have on a truck. That throws of the plows angle if not curled to the correct position.
/ Plowed Snow - Yanmar Content #5
View attachment 2147471View attachment 2147475View attachment 2147474
That is a really good job in my book. Especially considering it is your first. What are you using for skids ? They look to be working well.
gg
/ Plowed Snow - Yanmar Content #6
Darn nice job done (y) couple more storms of plowing will become second nature.
Another snow removal attempt a couple of days ago. Tractor in 4WD with engine at ~2000 rpm, transmission in low and loader in float mode. No strain on the blade or tractor.
/ Plowed Snow - Yanmar Content #9
I can't really tell from the pictures, but does the plow have a trip? That's more important than how it floats (although I would rather have the plow blade float than the loader arms). If it doesn't trip, it will plow fine until you accidentally hit something and then the loader arms will be bent.
See post #7 for details (use link) on the snow blade. It does have a trip function.
/ Plowed Snow - Yanmar Content #11
Yanmar uses their own type of quick hitch on the loader attachments?
Correct, I have a 72” Yanmar snow blade for my SA425.
/ Plowed Snow - Yanmar Content #14
View attachment 2777957View attachment 2777956
Im not sure where you live, but it appears you dont stay below freezing all winter long. Floating the tractor arms when the ground isn't frozen will result in rolling up dirt. With your ground soft and only an inch or two of snow, you might better off backblading the driveway. The plow wont Dig.
UNUSED RAYTREE RMA42 HYD AUGER (A62131)
UNUSED RAYTREE...
(INOP) GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
(INOP) GENIE...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61568)
2020 Chevrolet...
20 Yard Roll Off Dumpster (A61165)
20 Yard Roll Off...
3PT 10' Rolling Cultivator (A60462)
3PT 10' Rolling...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
