Operating a Diesel Truck in the Winter
/ Operating a Diesel Truck in the Winter #1
LittleBittyBigJohn
Central Arkansas
John Deere 1025R, Kubota ZD1211
Well... I'm new to modern diesel truck ownership. This will be my first winter where I feel like I'm going to end up in the cold with one. I live in Arkansas so I'm not sure if we have winter blend fuel or not. I also don't have any idea about the exhaust fluid in the winter. I haul on the side several times a month and could end up anywhere in about a 500-700 mile radius or more from home. I was in Decatur IL last weekend, and it was COLD!
Is there anything I need to be doing to "winterize" my truck for cold weather use? Fuel or DEF additive or anything else? Idling while loading or kill it, etc? I have noticed it must have a high idle function when it is cold. Also, I filled up with DEF in the low 20s and it took several miles for the level to change on the dash, not sure if that was the sending unit freezing up a little bit.
/ Operating a Diesel Truck in the Winter #2
although i'm slightly NW of you, we're dealing with similar climate. can't speak for def recommendations as thankfully :) my diesel is pre Tier lV. i'd say gelling & moisture removal in our climate would be worth preventing with an additive.
you'll get lots of recommendation for an additive, keeping in mind the 4 reasons for using a diesel additive: anti gelling, injector lubricity, moisture removal, and anti algae/bacterial growth
personally i go with Howes...you might stop at a high volume truck stop & see what's on their shelves, maybe strike up a conversation with a long distance trucker on the subject. given our climate extremes today, you're wise to inquire, regards
/ Operating a Diesel Truck in the Winter #3
Instead of asking that question here, it’s best you consult your trucks’ owners manual. It will tell you specifically what/what not your should do with each manufacturer’s diesel engine.
I don’t mean to come off with an “attitude”, but your question is too general in nature. Each engine has it’s own recommended procedure for cold weather operation.
Asking a question like that will bring you dozens of different opinions. Follow the wrong opinion, and you could do irreparable damage.
Consult your owners manual. I have mine for Cummins diesel engine and it came separately with my Ram truck general operators manual.
/ Operating a Diesel Truck in the Winter #4
What Hey Dude said.
I will add this. Do not put anything in the DEF besides DEF fluid. No additives in that.
In my Duramax though, I do add PowerService (in the white bottle) to the fuel. Here in the D/FW area, we do have the winter blend fuel, so y'all should have it there also. If you go to areas that have temps below 0, keep PowerService 911 (in the Red bottle) handy and plug the block heater in if you shut it down for any extended time. ie. overnight. For prolong idling, use the idle up feature if your truck has it.
/ Operating a Diesel Truck in the Winter #5
First off, what model truck are we discussing? Others may offer better help and tricks knowing what you have. Winter fuel is pretty standard for most areas as travelers may be heading into colder climates.
/ Operating a Diesel Truck in the Winter #6
One thing that does make a difference is the type of oil. If you run 5W-40 synthetic in the winter the temperatures can be quite cold before it’s necessary to plug in the engine heater. Conventional oil has a higher temperature threshold where this is needed. Once again this information should be in your owner’s manual. At least they show this table in my truck’s manual.
/ Operating a Diesel Truck in the Winter #7
Actually, DEF freezes (slushy) at 31 degrees (f). Your DEF injection system actually has a built in heater in the DEF tank to keep it unthawed. Same applies to big emissions compliant heavy duty trucks. Just another thing to eventually fail in my opinion.
Your DEF might be slushy in the tank prior to starting but the ECM allows for that condition and 'waits' for the DEF to become liquid before initiating the injection process.
I have a 2 full IBC 350 gallon totes of DEF in the barn but all I use it for is fertilizing my hayfields as DEF is nothing but Urea and deionized water.
I buy out of use date DEF all the time. Much less expensive than 46 granulated urea and easier to apply as well. The issue with 46 granulated is the ever increasing cost which is directly related to the war in Ukraine as most 46 is produced there. Alfalfa isn't particular about what it gets fertilized with. I also spray it with 24D-B for broadleaf and I apply the DEF at the same time in the same sprayer tank.
24D-B has to be applied before the invasive species reach mature length so it works well in the spring. I fertilize and weed at the same time.
/ Operating a Diesel Truck in the Winter #8
I use 5-40 Rotella T6 year around in the tractors and my diesel farm truck. The lighter oil allows easier cranking when it's cold out and it's easier on the starting batteries as well.
It's a 2023 Duramax. I have been using 15W40 Rotella T6 for oil.
/ Operating a Diesel Truck in the Winter #10
Guy across the road has one as well with the Allison. He put off servicing the Allison and paid dearly for that. Don't know what oil he uses but he takes it to a 10 minute oil change place so I presume it's the cheap stuff, whatever that is. He's a millrite at GM powertrain and totally mechanically inept. If it wasn't for the union he would probably be gone.
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
TOYOTA FORKLIFT (INOPERABLE) (A60736)
TOYOTA FORKLIFT...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
iDrive TDS-2010H...
