Tractor Diesel Fuel Additive
   / Tractor Diesel Fuel Additive #71
If one uses Howes for example like I do, is it ok to also add the biocide on a normal fill with fuel?
I've never used the biocide and don't want to deal with the problems it could cause.
Just concerned about adding too many things to the fuel and causing problems too.
I've used Howe's and Killem (biocide) for years. No problems.
   / Tractor Diesel Fuel Additive #72
There is a very good video done by Projectfarm on YouTube.
And the Oil Geek also has a good one:
   / Tractor Diesel Fuel Additive #73
To kill bacteria, just get a bunch of copper pennys, and throw them in the tank. If you want to spend money buy copper washers, or just a foot long peice copper tubing. Copper kills almost all bacteria.
   / Tractor Diesel Fuel Additive #74
how do you store your diesel, in tank or 5gal containers? in general, usually storage tanks pose more problems re:algae/bacterial growth than individual containers.
i use Howes as well
   / Tractor Diesel Fuel Additive #75
Heyah Tractor folks,
I deal with many chemicals with my job, including Jet fuels.
I have many diesel powered pieces of equipment, including a F350. So what does an Engineer use?
Cheapest stuff that works:
Biocides and water dispersant:
SDS:
More expensive version:
(May be found for "Free" when idiots place an expiration sticker on bottle. Sorta like trying to argue with Quality Engineering when they place an similar sticker on Titanium or Nickel welding wire.....)
Oh this is important!
This crap is transdermally toxic - it will attack your liver if you get a splash on your skin. Wear gloves and don't be stupid...
  • FPPF008-SludgeBeGone-SDS-EN.pdf
   / Tractor Diesel Fuel Additive #77
All diesel fuel contains B2/2% biodiesel. It's not required to be marked as such unless the biodiesel content is above 5%. Biodiesel is the lowest cost, most effective lubricity additive.
If any diesel fuel retailer says their fuel contains no biodiesel, ask what other additive they add to replace the lost lubricity during the refining process to remove sulfur.
Everyone might find this HFRR wear study interesting.
You get a lot of blank stares when you start asking about bio percentages. Or, percentage numbers pulled out of the air. I've found many don't mark their pumps when the bio percentages are above 5%, as supposedly they are required to either. I always ask and have been told up to 10% and not found labels anywhere to advise of that percentage. It's a crap shoot when you buy diesel as to the percentage of bio in it.
   / Tractor Diesel Fuel Additive #79
i use Howes as well
I store my diesel in 5gal cans. I always keep the tractor full of fuel also, and have had no problems so far.
   / Tractor Diesel Fuel Additive #80
similar to my situation, think you're in good shape as is esp since you circulate storage fuel. i've noticed bio growth problems w/others mainly in storage tanks. in addition, your location also helps. now gelling & moisture....another story, worthy of an additive to address those concerns. regards,
2014 Freightliner M2 106 Ambulance (A50323)
2014 Freightliner...
2017 Kubota SVL95-2S (A47384)
2017 Kubota...
2017 Polaris 500 Ranger Diesel (A50324)
2017 Polaris 500...
Case Ih 1660 Combine (A50514)
Case Ih 1660...
2023 JOHN DEERE 30G EXCAVATOR (A51242)
2023 JOHN DEERE...
1994 PETERBILT 379 SLEEPER (A50046)
1994 PETERBILT 379...
