Loaded tires psi
/ Loaded tires psi #1
CK732
Member
Massy
I have a problem when I put the chains on the back tires after I put on the tightner.
I'm thinking it pulls the chain to tight or the tire needs more air.
/ Loaded tires psi
I would have to buy the gauge to check loader tire to find out how much is inside.
/ Loaded tires psi
The size should be on this.
/ Loaded tires psi #6
14.9-28's should be good at 12-20 psi depending upon the load being carried.
Being liquid filled has no bearing on the tires load capacity;
these are 14.9-24's which would actually have less of a capacity then the 28's
/ Loaded tires psi #7
The problem isn't with the tire or it's air pressure. As I mentioned in your other thread, the chains need to be shortened.
/ Loaded tires psi
OK how do I shorten the chain? What end do I start at.
/ Loaded tires psi #9
/ Loaded tires psi
The twisted wire is to keep the chains they do damage when they come off.
I wish I had cams on the chains you turn up and hook into a link. In the Spring I will buy new chains for the tire size.
/ Loaded tires psi #11
The hook that you have the wire on is installed wrong. That hook is the "cam". It's supposed to go completely through the last link in the chain and hook back onto the chain. You really need to watch some of those videos carefully. This is something that is better explained visually. New chains aren't going to help if they're installed incorrectly like the current ones are.
/ Loaded tires psi #12
Being liquid filled …
12psi with liquid filled is asking for leaks around the bead imo
Or even worse the bead unseating loosing your fluid.
/ Loaded tires psi #13
Shouldn't
/ Loaded tires psi #14
Like this:
/ Loaded tires psi #15
It also looks like the OP’s inside side chain may be not tightened enough and that might help.
Ruffdogs picture of the latch is correct!!
2019 Kenworth T880 Tri-Axle Dump Truck (A61573)
2019 Kenworth T880...
(4) TRANSPLANTER UNITS FOR PARTS (A64278)
(4) TRANSPLANTER...
Hydraulic Tank (A64556)
Hydraulic Tank...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
2022 EZ-GO ELITE...
2003 Proclaim Tanker Trailer (A64194)
2003 Proclaim...
