Packing/sealing a gravel road after 'resurfacing' / land plane
/ Packing/sealing a gravel road after 'resurfacing' / land plane #21
It is Often overlooked by people, but there is a good reason ditches and road side shoulders, as well as pond banks are grassed, and it's not for appearances. You need vegetation to hold the soils in place against water. There are a lot of people who seem to obsess about keeping grass out of the center of a gravel driveway? Why, as long as it doesn't build up enough that you rub in the center, that grass is holding stuff in place. (I get the guys dealing with snow not wanting it).
I just mow the road if grass in the center gets too high.
/ Packing/sealing a gravel road after 'resurfacing' / land plane #22
So, a frequent source of erosion is the edges of the travel way, ie shoulder and/or front slope of a swale/ditch. Those areas really do need to be stabalized, generally with grass, but there are also natural jute mats, and other things. Waters erosion ability is based on volume (gpm) and speed (fps). You can sometimes control volume, by retaining and slowly releasing/perking, but generally you can only really control speed, using ditch blocks, dissipators, as well as shape of ditches. A Long ditch, at a steady fall will wash, and soon take the front slope/shoulder and eventually the driving surface. You can break those long straight runs up, either by allowing multiple outfall locations, or ditch blocks, or even the general shape (straight let's it flow faster, and erode more).
Another source of erosion, no offense, is guys not leaving stuff alone. Once you have an established drive, Stop grading it, unless it really needs it. Every time you grade it, you loose moisture (need to keep it all together), you break up aggregates, you segregate aggregates, you loose compaction, and you loose fines needed to bond it all together. If you are regarding even 1/month, you really need to solve another problem.
I’m wondering if the OP’s gravel movement issues are due to having uniformly sized gravel with no fines mixed in? It’s impossible to keep that kind of gravel in place.
/ Packing/sealing a gravel road after 'resurfacing' / land plane #23
There is a rancher about 40 miles south of me. Six years ago he had his 200 foot driveway "resurfaced" with screened, washed, round river rock. About 1" to 1 1/2" inches in size. It was about a twelve inch thick layer. I was going to visit him three years ago. Went down on my BMW cycle. Took one look - no way was I going to get mired down in that mess. Parked at the county road and hoofed it in the 200 feet.
I see this year - as I make my normal loop down south - he has the entire surface redone - again. Fines have been added and the driveway is now hard as concrete.
Live and learn. Of course - this could have been his plan all along. I highly doubt that.
/ Packing/sealing a gravel road after 'resurfacing' / land plane #24
It Can work, but there are some wrong approaches. If you have a washed rock type material, and it gets slowly pushed into the natural soils, that will eventually stabalize. It's not ideal, but there is a trend of people wanting to use washed rock, And fight it getting pushed into the native soils (loosing your pretty bought rock). Stuff like placing a fabric, and then a washed rock... Thats never going to turn into a single cohesive base material. A typical construction entrance detail, is going to be like 3.5" crushed concrete, (for multiple reasons, to clean tires, to hold up heavy trucks, ect), and it eventually gets forced into the native soils, and becomes very stabile; but passenger vehicles tend to just push it around.
Washed rock is more expensive too (atleast locally, and it would be hard to explain a case that it wouldn't be?). It has its places, and works well in wet areas, that ground water can't be dealt with, it can bridge that, it also doesn't compact, so, it's already compacted, so wet pipe back fills, ect. As a general driveway material, look at what your local city/county/state department of transportation or public works specs for road base, and about 50% of the typical road base will work as a very good driveway.
Most threads are with people wanting a 1 and done solution, and that is great; however, generally, there are worse things than being in a load or 3 of material every 5 years to deal with trouble areas.
/ Packing/sealing a gravel road after 'resurfacing' / land plane #25
So, our OP is in roughly Lexington Kentucky area. Attached might be helpful when our OP talks to material/trucking guys, for what the local names are. Kentucky DOT refers to it as CSB (crushed stone base) and DGA (dense aggerate base). Also attached are pictures, and brief material descriptions of the two materials from local rock mine, that probably helps picture the difference between base rock and "gravel"
/ Packing/sealing a gravel road after 'resurfacing' / land plane #26
Here are two sets of two pictures each, of the material you don't want, from the same mine
/ Packing/sealing a gravel road after 'resurfacing' / land plane #27
The drive ways is the city were taxed if cement so what
we did was fill the drive way with crushed rock and then
mixed sand and cement and filled the drive way and watered it down this way you didn't see the cement
so you didn't get the big tax for a cement drive way
willy
/ Packing/sealing a gravel road after 'resurfacing' / land plane #28
I re-ditched and re-crowned most of our hilly 1/4 mile driveway this fall. I finally crowned it more than I would think you need, and now the water gets off fast and not run down the gravel at all.
Didn't get around to adding any more material as I am debating what to use. My driveway is mostly just pit run, packed flat by lots of big trucks during spring construction, with rocks up to football size and lots of fist sized ones, so disturbing that too much results in lots of picking stones off, filling some football sized holes...
The municipality uses grade A gravel, which 3/4" crushed with fines down to sand, and then apply calcium chloride, and their gravel roads can be smooth and hard as pavement. But Calcium Chloride bagged is ~$1300-1500/ton and I need a couple tons to do it properly. And it needs to be redone in a few years? And I need another $3-4k in grade A gravel to get a smooth base to salt.
THe other option that packs well is 1.5"-2.5" crushed stone, especially when it gets some fines mixed in and locking it up. That is even more than grade A gravel, but should never wash away, so its the most permanent.
The box blade is handy as I can ditch and it pretty much keep the dirt and gravel sperate in the box, so I can get a good pile of dirt, lift the box straight up and push the gravel to the middle, then scoop the dirt with the FEL and huck it down the other side of the driveway.
/ Packing/sealing a gravel road after 'resurfacing' / land plane #29
See if you can order some variable sized gravel with crusher fines mixed in. And I wouldn’t disturb your existing road bed; just add a new layer and pack and grade that.
/ Packing/sealing a gravel road after 'resurfacing' / land plane #30
Nice. Here's an article about the inventer of that process. John McAdam. His compaction process was innovative enough to earn him a knighthood. Before him, all-weather roads were made of fitted blocks. He figured out how to use small stones, fines for filler, and compaction.
/ Packing/sealing a gravel road after 'resurfacing' / land plane #31
So yesterday I picked up a 2 ton Bruthling B200 non vibratory roller for what I felt was a good deal. Im going to do some maintenance on it this weekend and if the ground isn't frozen ill try it out
/ Packing/sealing a gravel road after 'resurfacing' / land plane #32
Similar north facing hillside driveway. Managing fines important to maintaining durability. Landplane doses this with minimal disturbance the best.
Rented a ride-on vibratory roller once and did a good before getting a landplane. Looked for a used roller for awhile. Now after years of using the landplane has increased durability and lessened the need for compaction.
/ Packing/sealing a gravel road after 'resurfacing' / land plane #33
I had the mechanic I use for our o5her equipment come and take a look at the roller I bought yesterday.. the original seller was pretty straightforward about it’s known issues and the only big one was that the battery did not charge and he suspected there was a draw somewhere.. Well..they had the terminals backwards… one of the cables was almost completed melted and it cooked something in the charging system. .. But for now, new cables, new filters and fluids, ew battery and there is no draw when ignition is off…so it won’t kill the battery, but everytime I crank it, it will deplete the power of the battery itself. ..I’ll figure that out this spring
/ Packing/sealing a gravel road after 'resurfacing' / land plane #34
new alternator/voltage regulator?
/ Packing/sealing a gravel road after 'resurfacing' / land plane #35
Not sure. The motor runs without a battery so it makes its own spark. It does not have an alternator and I honestly don't know enough about charging systems to know where or how to check a voltage regulator.
/ Packing/sealing a gravel road after 'resurfacing' / land plane #36
Is it gas? Normally only the smallest sod rollers are gas powered. If diesel, in many cases, the single thing that needs power is the starter. Some do have electric fuel lift pumps, but many don't
/ Packing/sealing a gravel road after 'resurfacing' / land plane #37
It's got a 20 hp gas motor.. it's called a Carroll Stream . Looks like a Honda knock ofc of some sort. V twin horizontal shaft.
/ Packing/sealing a gravel road after 'resurfacing' / land plane #38
in that case it's probably a magneto set-up, which will still have a regulator. there will be magnets on the flywheel with a fixed stator to produce current for ignition and charging. see if you can find a service manual for the engine or a similar honda/briggs. there is a gap requirement between magnets and stator as I remember. Alternatively, anyone that works on small engines should be able to diagnose the charging system since all magneto set-ups are similar. the attached shows a kohler setup ad on fleabay
The rectifier bridge is in the regulator if I remember correctly, so if the harness is putting out AC, the regulator/diodes should be all you need.
/ Packing/sealing a gravel road after 'resurfacing' / land plane #39
Many of those motors have a very minimal charging/lighting circuit, as small as 15 or 20 watts.
/ Packing/sealing a gravel road after 'resurfacing' / land plane #40
A landplane seems pretty worthless for this kind of grading. What you need is a multiaxis blade that you can create a crown for drainage. Shaping the road in a way that the water flows off to the side, rather than down the hill, will make it last a lot longer.
1999 CHEVROLET C7500 UTILITY TRUCK (A59906)
1999 CHEVROLET...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58214)
2011 MULTIQUIP...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
