WinterDeere
Super Star Member
- Joined
- Sep 6, 2011
- Messages
- 13,312
- Location
- Rural 'burbs, north of Philly
- Tractor
- John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
I have a system that works great for my boat trailers, since they’re both lighter, and also relatively un-changing loads. But I am still looking for better solutions for my landscape trailer, which is used for hauling logs, yard debris, and occasionally my tractor with implements. This Weigh Hitch, if available in WDH configuration, might be good for that.Yes, $300 is a bunch. But it is a very high quality hitch. I've had a 10" drop version of it since I got my 2017 Ram 2500. It was right about $300 back then. It works great and it is just simple. Sure, your scale/jack stand idea works, but that's an awful lot of futzing around vs simply looking at the hitch to see where it is sitting. No disconnecting the trailer, no nothing. If you are trying to set up a trailer for a single type of load you'll repeat continually then maybe your idea makes sense to "mess with it once and you're set", but if you transport multiple combinations of equipment and cargo that's a pretty painful way to save $150 (versus another brand/model of quality aluminum adjustable drop hitch).
As for 1 7/8"... I haven't had a trailer with that size ball hitch for about 20 years now. I guess your situation makes you an outlier from most folks towing situations. If I had that I'd just have another cheap hitch with that ball.
That said, to each their own. You must have a system that works for you. Weigh Safe works for me.
I did something stupid with my landscape trailer, when I mounted the winch to it, which I use for skidding logs onto my trailer. I bought a 12V winch and mounted two big (group 38?) RV/Marine batteries, all on the tongue of the trailer. It’s a 7000 lb. trailer, so ideally 700 - 1k lb. tongue weight when loaded evenly with logs (axles positioned accordingly), but now I’ve added probably 300 pounds of extra weight straight onto the tongue. It’s too much.
I had been planning to move the batteries aft of the axles, probably one either side of the rear fenders, to balancing things out a bit, but haven’t gotten around to all the planning, welding, wiring involved. Now I’m thinking I might do better to just get the batteries off the trailer altogether, either placing them at the front of the truck bed, or even ditching the 12V winch for a 240V winch and a portable generator in the bed of the truck.
The batteries would be much lighter in the truck bed, than my portable generator. But generators don’t require replacement every few years, and they never die in the middle of a loading job, or suck down your truck battery while charging.
