   / Share Pics of People Hauling or Towing Something Wrong #21,961
Yes, $300 is a bunch. But it is a very high quality hitch. I've had a 10" drop version of it since I got my 2017 Ram 2500. It was right about $300 back then. It works great and it is just simple. Sure, your scale/jack stand idea works, but that's an awful lot of futzing around vs simply looking at the hitch to see where it is sitting. No disconnecting the trailer, no nothing. If you are trying to set up a trailer for a single type of load you'll repeat continually then maybe your idea makes sense to "mess with it once and you're set", but if you transport multiple combinations of equipment and cargo that's a pretty painful way to save $150 (versus another brand/model of quality aluminum adjustable drop hitch).
As for 1 7/8"... I haven't had a trailer with that size ball hitch for about 20 years now. I guess your situation makes you an outlier from most folks towing situations. If I had that I'd just have another cheap hitch with that ball.
That said, to each their own. You must have a system that works for you. Weigh Safe works for me.
I have a system that works great for my boat trailers, since they’re both lighter, and also relatively un-changing loads. But I am still looking for better solutions for my landscape trailer, which is used for hauling logs, yard debris, and occasionally my tractor with implements. This Weigh Hitch, if available in WDH configuration, might be good for that.
I did something stupid with my landscape trailer, when I mounted the winch to it, which I use for skidding logs onto my trailer. I bought a 12V winch and mounted two big (group 38?) RV/Marine batteries, all on the tongue of the trailer. It’s a 7000 lb. trailer, so ideally 700 - 1k lb. tongue weight when loaded evenly with logs (axles positioned accordingly), but now I’ve added probably 300 pounds of extra weight straight onto the tongue. It’s too much.
I had been planning to move the batteries aft of the axles, probably one either side of the rear fenders, to balancing things out a bit, but haven’t gotten around to all the planning, welding, wiring involved. Now I’m thinking I might do better to just get the batteries off the trailer altogether, either placing them at the front of the truck bed, or even ditching the 12V winch for a 240V winch and a portable generator in the bed of the truck.
The batteries would be much lighter in the truck bed, than my portable generator. But generators don’t require replacement every few years, and they never die in the middle of a loading job, or suck down your truck battery while charging.
   / Share Pics of People Hauling or Towing Something Wrong #21,962
I don't think it was stupid to put the batteries there. Just look at them as (permanent) cargo and shift the loads back a bit on the trailer accordingly.
Unless you're running out of load capacity, I'd leave them where they are.
   / Share Pics of People Hauling or Towing Something Wrong #21,963
Well, you can just load the logs 4 inches further to the back to get your c.o.g. right... i often release a ratchet and tighten another to balance a vehicle on the trailer when i dont like how the suspension rides the bumpstop, or how the trailer reacts to steering.
   / Share Pics of People Hauling or Towing Something Wrong #21,964
Thanks, guys. Logs are generally cut to 15' lengths, and the trailer box is 16' long, so I don't have much leeway in how they're loaded. I'm usually pulling them as close to the front wall of the trailer as possible, just to ensure nothing interferes with closing the gate at the end of the session.
My thinking was that, if I'm adding 150 lb. of winch + stand to the tongue, I should have added the 150 lb. of combined battery to the back, to keep an already-well-engineered trailer balanced.
   / Share Pics of People Hauling or Towing Something Wrong #21,965
I took my DWs SUV for ADDED window tinting due to her complaints of LED trucks and other bright LEDs vehicles are running behind her. It has helped her a great deal.
The window tinting companies are now making money hand-over-fist and requires a scheduled appointment 1-month in advance due to LED headlamps in this era.
Most of the tinting companies offer the tint in an anti polarized film now to cut over 60% of the LED glare while still seeing out the windows. Only at certain angles can you see the yellow anti-glare in the film.
I know where to adjust my inside rearview mirror, so a car following me gets their bright headlamps reflected back at them. Grandkids are always messing with knobs & things in my truck___, if i'm ever questioned.
   / Share Pics of People Hauling or Towing Something Wrong #21,966
I'll give them a quick flash to let them know they're on their brights.
If they don't adjust I'll just hit and hold my brights.
The worst though is the super high output bulbs some cars have. They shine that clear blue and I have to think they are brighter than is legal.
A number of times I've flashed them and then received their brights.
Put your hands up in front of your eyes and you'll get a X-ray view of your bones.
How that's legal I don't know.
Almost forgot the idiots that run with their fog lights on all the time.
In this jurisdiction that is a ticketable offence if the conditions don't call for it.
However it seems every a-s with a Jeep and jacked up pickup has to prove they have them.
Perhaps 30 years ago, a gang was shooting at folks that flashed their bright lites at them.
   / Share Pics of People Hauling or Towing Something Wrong #21,967
I think youre overthinking it. If 150 pounds is going to do it, your tow vehicle is probably too light. Or theres too much junk in your truck bed.
   / Share Pics of People Hauling or Towing Something Wrong #21,968
The issue is that it puts me across the threshold for requiring a WDH. At 700 lb., the truck runs fine without, which is nice considering the terrain and tight spaces I'm often turning. At 1000 lb., I most definitely need a WDH. I'm always floating right around this territory, with that trailer.
   / Share Pics of People Hauling or Towing Something Wrong #21,969
Currently my trailers range is 1”, 1 3/4, 1 7/8, 2 and 2 5/16 for trailer ball size.
The 1” actually takes 2 ea of the 1” balls as the camp trailer has a single center pivot tire circa 1950’s
   / Share Pics of People Hauling or Towing Something Wrong #21,970
I have heard of people doing this. I don't know how it could cause problems for you anyways as it's their lights shining back at them.
Unless they are Mongo's cousins with a bad attitude.
2008 Caterpillar G23G Scraper, S/N CAT0634GADBY00493, Cat Turbo Diesel, 12,763 Hours Indicated, (A59076)
2008 Caterpillar...
Vivohome Single Stage Vacuum Pump, Model VB150, 1/3 HP, 110 Volt, Vivohome Gage Set (A59076)
Vivohome Single...
Skid Steer 43" Disc Mulcher (New/Unused) (A59225)
Skid Steer 43"...
2014 RAM 2500 (A58214)
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
2016 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A55973)
2016 Chevrolet...
