Front end coming up while plowing snow with FEL mounted snow plow
/ Front end coming up while plowing snow with FEL mounted snow plow #21
I have an l3301 with a heavy 7' blade /gravel driveway in the Catskills. I lift the loader until the blade just skims the surface. Also angle is important. blade wants to be perpendicular to the surface That's what works for me
This also puts weight on the front tires adding traction.
/ Front end coming up while plowing snow with FEL mounted snow plow #22
Good work on limiting the "jackknife" effect. I agree it's too difficult to keep adjusting the loader to a fixed height.
I found out (the hard way of course), that tractor weight matters. I found the jackknifing effect hugely problematic when I had the backhoe mounted. When you're in float mode, the tractor (and front axle) doesn't get the benefit of the big heavy bucket way out front. When you're in float mode, the bucket weight doesn't help keep the front end down any more, and because the loader hinge is so high, any pushing resistance takes even more weight off of the front axle. Reducing the weight behind the rear axle, and adding LOTS of weight to the front keeps my front wheels on the ground, and keeps my ability to steer while pushing in float mode!
Having said all that, I now used a rear blade to plow snow :)
/ Front end coming up while plowing snow with FEL mounted snow plow #23
I gave up on using the loader to gather snow unless the ground/gravel was frozen solid and flat. I use the bucket to move snow when needed. I use a box blade to plow snow both forward and backward as needed. Works great except when the snow is wet and packs up in the box. When it's wet I use a ice scraper that I keep in the loader cross tube to bang the packed snow out.
/ Front end coming up while plowing snow with FEL mounted snow plow #24
Keep a can of cooking spray handy as well. Spraying the blade surface every so often really helps keep the snow from sticking.
/ Front end coming up while plowing snow with FEL mounted snow plow #25
Speak for yourself. If you have shoes on the bucket, it works fine. I run in float almost the entire time on my gravel driveway.
Same here. Been doing it for 14 years.
/ Front end coming up while plowing snow with FEL mounted snow plow #26
I have a Curtis plow that was a pin on loader mount. I converted it to SSQA with a floating/ chain mount blade.
It works pretty much like a truck/frame mounted plow.
The PVC pipe is for storage so the SSQA plate remains upright. I'll remove it before doing any plowing.
/ Front end coming up while plowing snow with FEL mounted snow plow #27
Yep. That's the best way to do it.
/ Front end coming up while plowing snow with FEL mounted snow plow #29
It probably is but when you have a solid mount Kubota blade you work with what you got.
My Curtis blade was originally a solid mount. I modified it to a floating blade.
I helped convert other solid mounts. It usually isn't that hard or expensive.
If you post a photo of your setup I'm sure the folks on the forum could help you redesign it if you want to.
/ Front end coming up while plowing snow with FEL mounted snow plow #30
I used a regular FEL on three different tractors without issues. I DID run into trouble a few times when trying to skim some topsoil. The edge of the bucket grabbed and the front wheels wanted to come off the ground.
With a snow blade, the only way to go is with a chain so the blade only floats. An exception is if some more down pressure is needed for packed snow.
King Kutter II Tiller for sale.
King Kutter II...
John Deere Gator (A60463)
John Deere Gator...
4004SFL (A59228)
4004SFL (A59228)
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
2008 CHEVROLET TRAILBLAZER LT (A59823)
2008 CHEVROLET...
