Front end coming up while plowing snow with FEL mounted snow plow
   / Front end coming up while plowing snow with FEL mounted snow plow #1
mike paulson
Yea I was here a week ago and couldn't get any real answers in how to plow my property in float and not have the tractor jackknife up. Couldn't be simpler and works splendidly
   / Front end coming up while plowing snow with FEL mounted snow plow #2
I mounted a third plow shoe under the center of the plow frame. It keeps the FEL arms off the ground when in float so they don't dig in.
   / Front end coming up while plowing snow with FEL mounted snow plow #3
Plow pitch angle (side view curl) controls this unwanted characteristic. Need a 3rd control to get this correct: lift, curl, yaw angle.
   / Front end coming up while plowing snow with FEL mounted snow plow #4
So the stroke limiters are limiting how far the FEL can float down but not how far it can float up. And, being that the FEL goes down when the front wheels come off the ground, the limiters are limiting that action. Float up but not down. I can see where this is an improvement, but a floating plow design would be better.
   / Front end coming up while plowing snow with FEL mounted snow plow #7
Loader float is useless when going forward. As you've seen loader angles mean the tractor always ends up trying to climb over the bucket or plow.
If you want float on a plow, you need to build or buy one with float on the plow itself. My first plow I made myself. 3pt quick hitch welded to a SSQA plate, then it pivoted on the 3pt lifts hooks. Chain on the top link for float. Other than hanging out way to far & being a manual angle, it worked well. My current plow is a hard mount with power angle. More effort to manipulate without float, but it gets the job done. 8 keep thinking about rebuilding itp with a floating mount. But I've had it 5-6 years now & haven't gotten to it yet, so likely won't.
The loader weight just makes the plow to heavy to not dig in. Also the hinge being way up high creates twisting forces. Bulldozers or truck plows have any hinges down low to keep forces in-line. On a tractor loader the forces go up then around a corner causing twisting & the tractor PTO try to climb over the plow/bucket.
Did you see the pics and my solution in my OP. Already tested and now works great in float with the cylinder limiters in pictures
   / Front end coming up while plowing snow with FEL mounted snow plow #9
Speak for yourself. If you have shoes on the bucket, it works fine. I run in float almost the entire time on my gravel driveway.
   / Front end coming up while plowing snow with FEL mounted snow plow #10
I have skid shoes on my loader mounted 9' power angle snow plow and I never use the loader in float.
Tried it, doesn't work worth a dam floating the loader.
Lone Star dump trailer (A55973)
Lone Star dump...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A60429)
2016 CATERPILLAR...
Hot Pressure Washer Trailer (A59228)
Hot Pressure...
2016 CATERPILLAR 330 FL EXCAVATOR (A60429)
2016 CATERPILLAR...
TANK MANIFOLD (A58214)
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
