Slab pour in cold weather with night freeze.
/ Slab pour in cold weather with night freeze. #1
joea99
Marbletown NY
Kubota B21, JD 240GT
I'm putting a 12x16 addition on the south side of house. Foundation is poured, 2" EPS insulation, 6 MIL poly, mesh and PEX (for radiant heat) is in place.
However, the weather has turned here in NY with forecast for daytime temps in the mid/upper 30's and lows (nights) in the mid 20's.
Contractor, said to do a lot of commercial as well, says the slab pour will be fine, as he has insulated blankets that can stay in place for a few weeks and the concrete will generate enough internal heat from the curing reaction to prevent any freeze damage. Forecast for a week after the pour, if it happens, includes a couple of rainy/snowy days. Which may very well freeze those blankets in place.
Feeling a bit uneasy about this. While I do fully trust the concrete guy, my natural inclination is to wait for a break in the weather, just to be safe. I understand he is motivated to get this done now (for final payment, if nothing else), so feel it may be unfair to press him to delay this until, well Spring, the way the forecasts look.
Any experience with such things?
/ Slab pour in cold weather with night freeze. #2
Poured my 40x60 building slab with similar conditions. Covered it with the blankets and it turned out fine. Keeping the blankets in place with our Wyoming wind was a bit of a challenge. I'd follow the advice of your contractor.
That's a LOT of blankets!
Thanks for the reply.
/ Slab pour in cold weather with night freeze. #4
I think there were 14 of them.
/ Slab pour in cold weather with night freeze. #5
We pour or lay bricks in mild freezing temperatures. My mate in Finland pours to minus 10 when the concrete is made with hot water and preservatives added to increase heat production.
When it freezes during the day, i would wait. When its only some night frost i wouldnt worry, the concrete is a huge mass that needs to cool down before it actually freezes.
/ Slab pour in cold weather with night freeze. #6
When it is early in the season like this and it is just turning cold, you can get away with it more reasonably. Once the ground is fully frozen, then no. Right now the ground should not be frozen, especially since you said you have foam down. A little non-chloride accelerant would be a decent idea to give you even more confidence, along with the blankets. If the blankets have to remain frozen in place, so be it. Not like he will need them much as it will get too cold for any work that isn't inside. Once you have it enclosed and get some heat in there, then they will thaw out. And framing + sheathing something that small shouldn't take very long.
I poured my basement slab in similar conditions 11 years ago. It was mostly enclosed (windows and doors not in) by that time, so it was not heated. It turned cold early but the ground was not yet frozen beyond the surface, and I had foam and tubing in place also. Worked just fine and didn't use any accelerant either. That ended up being a brutal winter. Perfect time to build a house! :rolleyes:
Thanks for all the confidence builders.
I had hoped to get this at least framed and sheathed by now, but, a lot of the materials, windows and doors, were delayed by a month or so, due to disruptions by the hurricane.
Too late to start that now. I went for an "engineered kit" for this addition (4 season sun room) and hope to delay final shipment until spring. The supplier and I both agree that my on site storage, simply "under cover" is not wise, so we have to work something else out.
/ Slab pour in cold weather with night freeze. #8
The blankets help. I’d put a few inches of straw on top of the blankets too.
/ Slab pour in cold weather with night freeze. #9
I did the slab for my shop when it was cold like that, I was worried but it turned out just fine...
/ Slab pour in cold weather with night freeze. #10
The conditions you describe aren't an issue, especially with blankets. You should trust your concrete guy.
/ Slab pour in cold weather with night freeze. #11
I would rather put some tarps over it, a few inches off the ground so the air insulates. With the heat from the curing cconcrete, its going to get comfy under the tarp 😅👌
/ Slab pour in cold weather with night freeze. #12
The blankets that the contractor has are basically two layers of tarp with an insulation layer sandwiched between. They're used regularly at temperatures much colder than what the OP is talking about.
/ Slab pour in cold weather with night freeze. #13
When my basement floor was poured, the contractor had some sort of anti-freeze added to the mix on site. That was 58 years ago, floor is still smooth without major cracks; which I suppose is due to all the old worn-out stone mill saw blades,woven wire and re-bar I had him use first.
Any concrete contractor who tells you his pour will not crack should not be trusted IMO.
/ Slab pour in cold weather with night freeze. #14
As a Contractor, my experience with Concrete Contractors puts them into 2 categories. Hacks and Pros. Almost all of the residential concrete Contractors that I've dealt with are hacks. If they do commercial work, they are required to follow the Engineers instructions, and do it right. The difference is night and day.
In my opinion, the easiest way to tell the difference between a Pro and a Hack is looking at the rebar. Hacks will try to use wire instead of rebar, and if they do use rebar, they try to leave it on the ground and not put it on chairs. The one thing every Hack will say is that they will lift the wire or rebar while they pour it, and it will remain in the middle of the concrete while they walk on it spreading and floating the concrete. This is the most common lie told in all construction!!!
If your Contractor has rebar on chairs, odds are pretty good that he is a Pro.
The second thing to watch for is on the day of the pour. The concrete has to have slump to it. That means the concrete will pile up on itself and not spread out. Slump is measured, the more you have, the stronger the concrete will be. Hacks will add extra water so the concrete is easier to spread, easier to float and gives them more time to work on it. Water creates volume. When the excess water evaporates, the loss of volume creates cracks in the concrete. These cracks will show up in the first week of curing.
A Pro will not add water to the mix. Sadly, the homeowner needs to be there during the pour to take pictures of the concrete as it comes out of the truck, and piles up. The homeowner needs to tell the crew not to add water. You have to be very direct with them, and you have to stay on top of it, because they will want to add water!!!
Concrete is poured in cold conditions all the time. It's not an issue for a Pro. It's not something to be worried about if the guy knows what he's doing. If he's a Hack, you are in big trouble no matter what the weather is like. If they do the basics right, odds are good they will finish the concrete right.
/ Slab pour in cold weather with night freeze. #15
Eddie, that's a great post. Thanks.
Thanks. Post came a few days after the pour happened.
The fellow says he does mostly commercial work, or did, and came recommended by someone that did right by me in the past. When I discussed concrete suppliers, he said he would not use the outfit I first mentioned as their stuff was cheapest, by a lot, but often never cured properly or pass strength tests.
The walls did have rebar and steel panels were used as forms. The rebar was not the minimum size, but I forget now what number it is. Was 4000 psi mix.
The slab did have "chairs" but mesh was used, again said to be over minimum. The concrete did not slump all that much, to my eye, but did need to be raked out and "coaxed" into corners. Said to have used hot water and cold weather additives.
He put down insulated blankets, and my own "billboard tarp" over those. I pulled those back yesterday and did not see any obvious cracks and the slab felt quite warm to the touch. Also noticed the pressure on the PEX test gauge was a few PSI over what it had been, which only means it got hotter. Not that unexpected I guess.
In a week or so may pull all those off, but it snowed about 7 inches last night, so, weather dependent.
/ Slab pour in cold weather with night freeze. #17
Eddie,
If I am reading this correctly, you're saying the higher the concrete piles up on its self, the stronger the concrete will be.
But it reads in my mind just the opposite...the more slump the stronger the concrete.
People who don't know much about concrete might misunderstand.
/ Slab pour in cold weather with night freeze. #18
Eddie,
What exactly are we talking about ? How much water is added? Untill it self levels ?
My father kept spraying fresh cast concrete 3 times a day in summer, to prevent cracking from too fast drying in hot weather.
/ Slab pour in cold weather with night freeze. #19
Residential concrete contractors, you mean guys pouring driveways and walkways, and commercial concrete contractors, you mean construction companies ?
/ Slab pour in cold weather with night freeze. #20
Keeping the finished concrete wet helps it cure. It is bad to add water to concrete prior to finishing it
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A61306)
2023 Kubota...
25' SINGLE AXLE VEGETABLE TRAILER 5TH WHEEL (A60430)
25' SINGLE AXLE...
24220 (A56859)
24220 (A56859)
APPROX (20) 9'-3"X3" SQUARE TUBING (A60432)
APPROX (20)...
2023 FABRIQUE CARRY-ON -TILT 60"X8' TRAILER (A60430)
2023 FABRIQUE...
