Wanting to buy new tractor
/ Wanting to buy new tractor #22
/ Wanting to buy new tractor #23
If you can find A Yanmar dealer anywhere close sounds like the YT359 would be perfect and you will really like the IHMT tranny, I traded my Case 45C in on this and it has twice the power and I have the YT347 which has a little smaller engine but it is a great tractor with a ten year warranty at a reasonable price. Good luck.
/ Wanting to buy new tractor #24
On our tractor you can see all four tires no
problem to see anything and the mirrors you
can see very good behind you and you can
see the 3 pt hitch and the linkage
willy
/ Wanting to buy new tractor #25
Do you use the clutch when shifting? Andy at Yanmar says I should; everyone else, including my dealer and many other dealers on YouTube and Yanmar's website, says clutchless.
/ Wanting to buy new tractor #26
you can use it but it isn't required but it does make it easy to shift the range lever and if you want to ease into a tight spot but for normal use it is like a forklift or back hoe just shift into forward or reverse and it works really well.
Thanks for all of the replies. I have been impressed with the Yanmar. I haven't seen one or know of any dealers, but I do know they have good engines and make tractors with brands other than Yanmar.
/ Wanting to buy new tractor #28
I picked up a Yanmar ym342 a few months ago. It's been fantastic. I do some bucket work. Clutching has been a non issue. Zero inconvenience. And, the heavier frame, lift capacity is great.
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
RoadTec RP190 (A61307)
2014 FORD F-550 XL SUPER DUTY SERVICE TRUCK (A59823)
2014 FORD F-550 XL...
CFG QK20R (A60463)
CFG QK20R (A60463)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
